Question about Samsung SPP-2040 Thermal Photo Printer
Print problem spp-2040
Hello,when i print a picture, ther comes about 2.5 inch foto out of one side
not more , the rest of the foto wil not print
i have put a new cartridge
thanks and greats
peter
  • 1 more comment
  • jingster Nov 06, 2008
    Hi, I've got the same problem except it only prints half of the photo lengthwise. I've been pretty careful with this device. It just sits on top of the table. Thanks.  ~ Jing
  • michelguye Nov 10, 2008
    En francais : impression seulement à gauche
    Bad english : print only left side of picture, get new toner and paper
    please help me
  • lightworker Nov 13, 2008
    Printer started to print only half of the photo lengthwise (other half is blank!). I changed the cartridge and paper but still the same problem!
  • 5 Answers
This may be caused by a broken plastic lever for the thermal head inside the printer. This is not particularly difficult to fix, but it not be attempted if you have more than two thumbs.
  • The case is not difficult to open, nor is removing the pc board in the printer, but I suggest getting a service manual on the web for disassembly instructions. Reconnecting the LCD cable is painful. Search for "SPP-2040 service manual."
  • Remove the printer assembly from the case.
  • Remove the PC card from the printer assembly being very careful of the cables.
  • From the top, look at the shaft that controls the up/down motion of the thermal head. At the end opposite the motor, inspect the white plastic lever. There should be no cracks evident, nor should the lever be "loose" with respect to the shaft. If this is not the case, this is not your problem. There is a "flat" on the shaft that should keep the lever from rotating.
  • Remove the "upper plate." Two small screws and a spring at the opposite end.
  • Rotate the lever so that it aligns with the "flat."
  • Using small buss wire (or a paper clip), wrap the wire around the round part of the lever.
  • Twist the ends of the wire tightly and as close to the lever as possible. There is not a lot of space here. Trim off the excess wire and position the wire as shown.
  • Reassemble the top plate & spring.
  • Reassemble the printer & test.
Hope that this has helped. al
Posted on Dec 21, 2008
  • 6 more comments
  • warp3 Feb 26, 2011
    Thank you very much :-)
    This worked for me.
  • danyabdallah
    danyabdallah Jul 23, 2012
    This was what I need. Great Job.
  • danyabdallah
  • Pialmedia Jul 29, 2012
    Thank you. My printer works fine again.
  • Carpentier Michele Jan 14, 2013
    I works. I hardly blieve it. Paper clip remains a tresure.
  • metal404
    metal404 Mar 09, 2013
    thnaks a lot for the tip!! it works great, no need to buy another expensive one!!
  • dEstaintot
    dEstaintot Jan 01, 2015
    Great hint! Not so easy to twist properly the wire, but when done, the printer works again like new... Many thanks for this fix which I would not have found myself!
  • Siro Maxenti
    Siro Maxenti Aug 27, 2017
    Thank you i have solved problem with my Samsung spp 2020 it now work fine
Printer head problem. I followed the directions and it still comes up as to follow the step.
Hello and welcomeFollow the given instruction to solve print head problem:
  • Turn on the hot water until warm
  • Put about 1/2 inches of water in a cup
  • Put the print head portion (where the ink comes out) in for about a minute
  • Dry off the cartridge using a soft tissue.
  • Re-insert the cartridge into the printer.
  • Run the normal cleaning software routine a few times
Your Rating As Four Thumbs which are given below to this solution will appreciate me
Thanks
Mar 09, 2011 | Dell p713w AllInOne InkJet Printer
Installed new cartidge - white down the center of the sheet - print on each side of paper, about an inch wide
Make sure you pulled the seal tape out of the cartridge when you installed it. Remove the toner cartridge and while holding it relatively level shake it from side to side. Re-install the cartridge and test. If it makes a good copy now you are all set. If not then I would return the cartridge and get a replacement under warranty.
I see this all the time with new cartridges. Most of the time it is caused by the toner in the chamber being packed to one side or the other and shaking it from side to side wil even out the toner.
Good Luck and Thank You for using Fixya.
Sep 23, 2010 | Canon PC-940 Black and White Copier
Epson MX700 fault - piece came loose inside I need advice please on replacing a piece inside my Epson MX700 printer that has come adrift, and how to do it. I recently experienced a problem in the paper...
The piece that you showed in picture looks like it could be your ink absorber pad. This part is usually found at the side of the printer where the cartridges rest after each print job. You can run the printer without it, but if you can find exactly where it belongs it does catch the excess if that drips from the cartridges.
May 31, 2010 | Canon MX700 Office All-In-One InkJet...
Dell 1710 printer. When printing just tthe top 2
Have you tried replacing the drum? That is the part that the toner cartridge actually sits in.
Jan 28, 2010 | Dell 1710n Laser Printer
Black Ink Faded
Perhaps the print head needs cleaning.
Oct 06, 2017 | Dell 1320c Laser Printer
Streaks on printed page full length even after installing new cartridge
Check the glass (the one the paper rests on). The underside of the glass that is. This is what the light 'sees', so, it will print this!
Jun 03, 2009 | Konica Minolta PagePro 1350W Laser Printer
Dark band the length of the right side of the printed page
Hello sir; I suggest you go to replace a new cartridge, see what's happen.
Apr 07, 2009 | HP LaserJet 1020 Printer
I have a cannon MP160 printer. Color ink button is flashing. The color ink cartridge is empty. I replaced the black ink cartridge and want to print in blank ink only. However, I can't get the color light...
try to go into the software for the printer and find a rest ink cartridge button. This will make it think it has a new one which wil let you print in black by selecting black print only
Jan 08, 2009 | Office Equipment & Supplies
HP Laserjet 1100, band of unprinted area after new toner install
Hi Friend,
You have mentioned this is a 2nd hand printer,
you have to service the printer,(fuser unit)
if the problem exists after fuser service check Laser Scanner also,
Thanks
Lux5
Nov 28, 2008 | HP LaserJet 1100 Printer
HP deskjet 970cxi not printing red
Hello, usually the refilled cartridges doesn't work well.
You can try to fix your problem doing this:
1) Put some boiling water into a cup
2) Put the the cartrigde (print surface) close to the water to receive the steam (not inside the water)
Do this just a couple of minutes.
3) Put it back ther cartridge into the printer
4) Align or clean the cartridges with a printer program
5) Try printing again
If still does'nt work buy original cartridges or due the high cost of them buy a new printer.
Please don't forget to rate this solution! Have a great day!
Oct 07, 2008 | HP DeskJet 3325 InkJet Printer
Samsung SPP-2040 Thermal Photo Printer Logo
3,678 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
