Question about Frigidaire FRT17G4B Top Freezer Refrigerator
A strong odor emanates from the back side of the refrigerator..spreading through out the kitchen and surrounding area..for almost a month now. The wires/tubings were brushed and cleaned, as the flooring in the whole area. Odor still exists..Any suggestions? Wiring on the back are warm/almost hot when the motor runs. Any suggestions?
  • 713 Answers
Hi,follow the stepwise solution provided below to help you get rid of the odor emanating from your refrigerator;
STEP 1 You have to get charcoal,For the charcoal you can buy regular charcoal briquettes and use a hammer to crush them into small chunks
STEP 2 Combine the charcoal, baking soda, citrus peel, cloves, and vanilla extract in a medium-size glass or enamel bowl. Stir mixture and let it sit for at least 1 hour.
STEP 3 Create a sache with the mixture by putting 2 tbsp of the mixture in the center of a nylon stocking square and then placing this packet in the center of a square of the porous fabric. Tie the corners together with the string or ribbon.
STEP 4 To use, tie a packet in an inconspicuous spot in the refrigerator or freezer. Or tie onto a shelf inside the door.
Thanks and take care
Posted on May 02, 2010
Smell strong odor around the refrigerator. the manual seems to point out to problem in the drainage area. need more specific help.
Check the fan located on the lower back side of the refrigerator to make sure it is free from dust or lint
Jan 01, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Smelly Jenn-Air Refrigerator
some of the most elusive odors can be developed by a rotted piece of fruit,hidden behind drawers,or stowed away inside door shelving somewhere...to remove odors/take about 5-6 charcoal briquettes and wrap them in newspaper this will absorb odor,and yeah-it actually works leave them in for about 2 days
Mar 10, 2010 | Jenn-Air JSD2789GEW Side by Side...
I have a problem with an older model (?) Kitchenaid side by side BUILT-IN refrigerator/freezer. There is a perasive odor (like toxic fumes...a pungent, rather a medicated odor that is extremely noticeable...
refrigerant doesnt have a smell hmm only thing I can think off try to look at the light at the top of the fridge did it melt the liner or plastic cause its a common problem with very strong toxic smell
Nov 04, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Chemical odor in freezer
can you verify the odor. Does the odor smell like burnt wire insulation or of that of burnt meat?
Jul 05, 2009 | Kenmore Freezers
Foul odor from back area of fridge/Kenmore bottom freezer
I had the same problem, but just fixed it. I have a maytag bottom freezer and when the fan blower comes on, there was a foul/stale smell that permeated the kitchen. There is no drip pan that I could remove to clean.
I just removed four screws from the back cover of the fan blower area, reached in with a small cup of organic odor remover and poured it into the drip pan just under the fan blower.
Any odor remover would work. probably vinegar or enzyme odor remover would work, too.
I now have fresh smell when the fan blower comes on.
Jul 03, 2009 | Kenmore 50522 / 50524 Side by Side...
A smell is coming from the ice dispenser. I need to open it.
Unlikely area for the smell to come from since with the unit off, there is no action in this area. Most likely cause of your smell: Residue in drain pan of freezer evap area. Remove panel in back of freezer section while unit is unplugged and clean drain and surrounding areas. Use a high concentration of bleach water and let unit air out completely after this. At some point in time, meat or related substance in your ref/freezer leaked and odor is caused by this as the unit was thawed. Use the product ICE AIDE, available at sears or by an A&E tech to continue to freshen your unit for 6 months. IF meat or some sort of undesirable juice dripped into the ice or door water dispenser, you can take this apart and clean as needed following your parts breakdown at www.searspartsdirect.com after you enter your model number off of the appliance. Make sure you work with an unpowered appliance.
Jun 14, 2009 | GE GSS20IEP Side by Side Refrigerator
Norcold 982 will not get cold.
If the there is a strong ammonia odor and no cooling, then you probably have a leak in the system somewhere. These types of absorption units must be repaired in a specialty shop. The most common place for a leak is the condenser coil, but can also be the evaporator inside the unit, if the odor seems to emanate from that area.
Apr 06, 2009 | Refrigerators
Bad Smell in Fridge
To remove odors:
1. Remove all items from refrigerator or freezer. Throw
out any spoiled foods. Take out removable parts and wash
them and door gasket with mild detergent in warm water.
Rinse well and wipe dry.
2. Wash interior walls and door liner with solution of 1-2
tablespoonsful of baking soda to 1 quart warm water, and
wipe dry. Leave door open and let it air out well, with a
fan directed toward inside, and opened windows if climate
permits.
3. If odor still remains, try one or all of the following
means of odor removal.
a. Spread baking soda out on shallow pans (like shallow
glass casseroles, pie plates, or jelly roll pans lined
with foil) and put pans on shelves to absorb odors, or on
the bottom and in baskets of chest freezer. Leave open
and unplugged.
b. Buy activated charcoal (which is specially treated to
remove odor molecules from air) at some department store
housewares sections, appliance store, or pet shop. Spread
out on shallow pans and put on shelves of refrigerator.
Turn refrigerator on low setting and run empty a few days
so odors will be absorbed.
c. Spread cat litter in shallow pan in cabinet, turn on
and run empty a few days. If odor is disappearing but is
not all gone, replace old litter with fresh litter.
d. Pour several ounces imitation vanilla (not pure
extract) in a shallow saucer, put on shelf and let run
empty a few days.
e. Put fresh ground coffee in cereal bowls inside the
refrigerator and let run empty several days. A slight
coffee odor may remain, but will disappear after washing
again with baking soda solution.
f. Pack each refrigerator shelf with crumpled newspaper.
Set a cup of water on the top shelf or sprinkle the
newspaper lightly with water. Allow refrigerator to run
for approximately 5-6 days. This method takes a bit longer
but has been effective in removal of strong odors.
g. Buy a commercial odor remover, and follow instructions
exactly. Several companies manufacture a liquid
concentrate which sells for about $3.00 for 1/4 to 1/2
ounce. A couple drops are put on a piece of cotton and
placed in the area to absorb odors, in the cabinet or
in a room.
Three of many brand names are: "Odor-Away" by Wrap-on
Co., available at hardware and hospital supply stores,
"SuperCD" IBL Household Products by Crackerbarrel Sales,
Avenal, New Jersey, available in pet supply department
or special products in grocery, or "Clean-Air" at some
appliance repair shops.
Hospital supply stores carry Dow Chemical Hospital
Disinfectant and Deodorant Spray. Spray into cabinet and
quickly shut the door. Repeat.
4. If none of these methods removes all the odor, then it
has probably penetrated into insulation. Contact an
appliance service company for an estimate on cost of
removing the liner and replacing the insulation. If cost
is too high you may prefer to get a new appliance. It
could be used for occasional cooling of soda pop where
the odor will not get into the beverage.
Nov 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Chemical odor...
from where does the smell come?
inside the unit or from the body?
does the smell spread to food items?
Jun 25, 2008 | Kenmore 53642 / 53644 Side by Side...
Frigidaire FRT17G4B Top Freezer Refrigerator Logo
130 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
