Question about Compaq MV 520 Monitor
Why is resolution so dark on my mv520 compaq monitor
  • 4 Answers
You turned the brightness down
Posted on May 02, 2010
I am using a compaq 1701 flat panel monitor. I installed windows Xp. The screen resolution is $4 bit color coz the driver is not installed. Looking for the driver for compaq 1701 flat panel monitor for...
The screen resolution and bit color is controlled by the video driver NOT by a driver for the monitor.
Install the correct video driver for your video card and you will be able to increase the screen resolution to over 1024 X 768 and bit color to at least 32 bits.
Jul 21, 2011 | HP Compaq 1701 17" Flat Panel LCD Monitor
My monitor compaq model MV520 is always blinking every time I open my computer, How can I fix it?.
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to answer and solve your problem. Your Compaq MV520 Monitor is always blinking every time you turn on your computer and you want to know how you can fix it? First, we need to troubleshoot the problem. I'm thinking you probably need to refresh the flicker rate on your monitor. The flicker rate is probably set on a low setting, which is causing you screen to blink (flicker). This can be bad for your health as well because it can cause eyestrain and headaches. Your monitor is a CRT (Cathode-Ray Tube) model. These types of monitors can cause a lot of screen flickering. Now that we've troubleshooted the problem, now it's time to solve the problem. There are two ways you can solve this problem. You can either refresh the flicker rate or you can buy an LCD monitor. LCD monitors flicker-free. My suggestion is that you refresh the screen flicker rate. To refresh the flicker rate, go into your System Preferences or Control Panel, click your operating system's appearance and display link and click your screen adjustment link. You may have to click your advanced settings link. Click your monitor tab and from there adjust you screen refresh rate. You may have to adjust your screen resolution before you refresh the screen rate. If you have to do this, make sure the screen resolution you choose supports you monitor's height and width as well as visibility. The higher the resolution, the higher the screen rate. The instructions I'm giving you may sound like this because I'm not sure what your operating system is. I'm not to familiar with Mac Operating Systems, but if you have a Windows Operating System and you need better detailed instructions, just reply back. I hope this decreases your screen flickering and gives you a better viewing experience.
Jul 07, 2011 | Computers & Internet
I have a compaq presario computer using a compaq monitor. I have a Gateway HX2000 LCD flat screen monitor (year 2009) that I want to us instead of my compaq monitor. I have disconnected the compaq monitor...
I'm guessing the different monitors are different sizes? The only thing a driver for a monitor will do will tell the computer the max resolution that the monitor will be able to go up to. However most 90% of monitors can use the built in windows driver without issues. Your best bet is going to be to change the resolution on the monitor. To do this you can either hook up the old monitor, lower the resolution, and then plug in the other monitor. Or you can boot the computer into VGA low resolution mode by pressing F8 as the computer starts up and selecting that option. From there you can lower the resolution, and then put it at something more desirable with the new monitor.
The other possibility being your Gateway monitor is actually malfunctioning and you just happened to hook up a bad monitor.
Mar 27, 2011 | Computers & Internet
My microphone suddenly stop working on my compaq mv520 monitor. can you tel me what can i do to fix it?
Try deinstalling the mic and redownload and install fresh driver see how that goes should clear up any glich
Dec 30, 2009 | Compaq S510 15" Color Monitor
Lost of colors
crt base dray soldrin, rgb vga cable 15" pin connector problem
Apr 07, 2009 | Computers & Internet
Problem with compaq MV 520 monitor
Your monitor is operating normally. After Windows starts it is setting the video resolution to something outside of the monitor's range. That's why you see the Windows splash screen, then the message from the monitor about the settings. Most likely the computer was used before with a monitor that had a wider range of resolutions available.
Restart the computer. When the manufacturer's logo screen appears, press the F8 key three or four times. This should get you a startup menu screen. Pick the option of starting in VGA mode, and Windows will start with video settings that your monitor supports.
Feb 01, 2009 | Compaq MV 520 Monitor
Schematic diagram
plz send me philips lcd monitor diagram power supply model 150B
thanks
regards
asif mansouri
Oct 20, 2008 | Computers & Internet
Sir Help me with my Compaq monitor MV520 it won't turn the power led flashing orange to green continously
it could be th epower supply and it could be the monitor.
power ON button should not flash orange regardless what you do. it should stay green. then orange. not orange to green to orange.
try the monitor on another PC if you can fine one.
the other thing is are the 2 monitor similar (CRT to CRT and LCD to LCD), you can't mix the the two, they will work but need different video driver to function correctly.
Oct 20, 2008 | Compaq MV 540 15" CRT Monitor
Help for compaq mv520
Here is what you have been asking. q901 --- K2645 q902 --- KSP44 u90 --- uc 3842P It seems you problem is in the power supply switching circuit. I hope this will solve your problem. Please let me know if this has solved your problem junr7
Aug 25, 2007 | Compaq MV 540 15" CRT Monitor
Compaq MV 520 Monitor Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
