Question about Motorola Mobility A630
Broken bluetooth Dropped the phone. Now camera button and blue tooth don't work. Is there an easy fix?
    Brigadier General:
  • 7,752 Answers
Yea you can take the phone and have it check to see if it is better to have it fix or buy a new one
Posted on Mar 25, 2008
SOURCE:
Bluetooth has power and buttons click when pushed, but does not respond.
I just got my blue tooth ear phone to work with my laptop, sounds like you want blue tooth car to pickup on your phone speech and sound. You probably have to enable blue tooth on your phone and connect to the bluetooth receiver in the car. Probably be good if blue tooth receiver is on so phone sees the signal, that's the way mine worked, it showed that device, I clicked it to connect. Hope that helps.
Jul 08, 2016 | 2008 Hyundai Veracruz
How to pair my ilive blue tooth wireless head phones with a proscan tablet
Open the blue tooth menu on your tablet (usually -> Settings -> Bluetooth)
Turn on your head set. Usually there is a pairing button option, on your set, you need to turn the headset off, then turn it back on but hold the power button for 8 seconds until they will flash red/blue.
You should be able to find your headset then on your device.
How to pair bluetooth headphones to your phone
Nov 08, 2015 | Proscan 10.1-Inch Internet Tablet,...
Will a blue tooth work with my cell phone if the mic nolonger works
The mic on the bluetooth should bypass the mic on the handset, so if it is just the physical mic that is broken on the phone, it should work on the bluetooth headset.
Dec 11, 2013 | LG Nitro HD
How do I fix iPhone microphone Problems with headset and Bluetooth?
Go to the settings on your I phone select search for blue tooth device and at the same time hold down the large button on your blue tooth device until it flashes blue and red keep it pressed until it stays blue then your phone will be pared to you're blue tooth device.
Mar 15, 2013 | iPhone Apps
Ear loop broken-purchased loops and they snap and break
nujanitoral.jpgDon't spend lots of money buying blue tooth headsets Go to your local Walmart and purchase the Emerson Blue Tooth headset it comes with 2 ear loops that are made of a flexible plastic and 6 inner ear buds for a very snugged fit. The ear loops will also fit your LG blue tooth headset. You can also purchase the headset by following this link http://www.walmart.com/ip/Wireless-Gear-Bluetooth-2.0-Headset/15852098
Jun 11, 2011 | LG Cell Phones
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
Bluetooth
Sorry but you can not installed blue tooth on the dis device.
Blue tooth is not only a software. I t also requires hardware.
Sorry.
Aug 20, 2009 | Sony Ericsson W200i Cellular Phone
I am trying to program my nokia 2600 phone to my motorla h700 blu
First of all, the Nokia 2600 is not a blue tooth phone.
If you should get a Nokia phone that supports blue tooth your best bet would be to make sure any previously paired devices are turned off.
Then make sure that blue tooth is enabled on your phone. For most Nokia models its as follows;
Menu > Settings > Connectivity > Bluetooth > Bluetooth On
Then attempt to put your device in pairing mode.
Return to;
... > Bluetooth > Search Audio Enhancements
If your phone supports Bluetooth the phone should and device should pair after you enter the pairing pin, usually 0000.
Johnny_Nh, to answer your question, different Models are equipped with blue tooth when they are manufactured. Also, there are different versions of bluetooth, 1.0 and 2.0. If you have an older phone supporting Bluetooth 1.0 you will not be able to use a bluetooth 2.0 headset.
Dec 26, 2008 | Motorola Mobility H700 Wireless Headset
Setting up my blue tooth
You need to pair it with the phone, working on phone settings, what is phone model?
Aug 29, 2008 | Motorola Mobility Bluetooth Headset H3 for...
Bluetooth broken
dear,maybe its because of bluetooth recieving list saturation. so delete all previously detected bluetooth devices
regards
dont forget to rate it
Nov 07, 2007 | Sony Ericsson Z530i Cellular Phone
Motorola Mobility A630 Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
