CANNOT SUCCESSFULLY HOOKUP A DVD/VHS TO MY VIZIO MODEL NOS. DVD-v2000 25W
  • shay9920r May 04, 2010
    The ace who communicated with me didn't give me the complete information. From the vizio instruction it refered to the Wires blue green and red wires which i didnt have. I purchase same in Wal.mart for $10.00 came home and merrylee went pluging- some how i got the whole thing to work? Talk about the donkey who blew the flute.Thank you, however the monies spent was not worth the information.
  • 360 Answers
I was the person chatting with you earlier on, before the chat was disconnected. My system went off and I'm sorry about that.
I'm responding here in order to make sure your problem is solved.
LAST QUESTION THIS IS A DVD/VHS DUAL UNIT AND IS CON NECTED WITH THE wHIT rED AND YELLOW TO FROM THE COMPONENT AREA TO THE BACK OF THE TV
You can do the connection by using two different methods: (a.) you can use the component method or (b.) you can use the AV method.
Using the Component method: The component is a combination of red, green and blue wire connection which brings video or display.This three must be connected for you to have a display of your unit on your TV.
Connect the Red, Blue and Green wires respectively to their appropriate places on the TV, then the other part on your DVD/VCR. Note that this connection will only bring a display and no audio. You will have to connect the red and white wire from audio out of the DVD to audio in on the TV.
Once you have successfully done the connection, put on the DVD/VCR and your TV, then press "source" on your TV remote and select component 1 or 2 for you to get a display.
B. Using the AV connection: The Av connection is using the RCA wires which is yellow white and red, just as we discussed while chatting. Connect the Yellow, white and red wires, from the TV to the DVD/VCR, the select AV on the TV remote.
Unlike the Component which its video connection is red, green and blue for display, the AV is only Yellow for display. I hope you under stand this.
Please try to follow my explanations and let me know, if you don't understand and I will explain further.
It was nice chatting with you.
Take care.
Posted on May 02, 2010
I have copied a vhs to dvd but dvd won't play on other dvd players
DVD+R is a Sony format, so it may not play in the more common -R format players. Are you finalizing the DVD's if not they will only play on the deck that recorded them
Jan 25, 2012 | NEC Televison & Video
Can I record DVDs from a Sharp 13VT-N100? The only connection source is the coaxial antennae port. There are "In" sources so I can watch DVDs from a DVD player but how can I reverse that so I...
Recorded from tv shows to DVD Disc have to hookup AV RCA component cables to both to Tv and DVD recordable player model connections together.Yes,u will able to recordable VHS tapes to DVD Discs.But ur DVD player model u have it is must be a recorderable DVD player model?Not just a DVD Discs and VHS tapes player only model.Check ur owner manual all are in there.
Aug 20, 2011 | Sharp 13VT-N100 Combo
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
How i can successfully copied my VHS to DVD-R and DVD+R formats
You will need a dvd recorder and a vhs player so that you can play the tape and record it to dvd. there are several options. if you are not into technology i would look in the yellow pages for a photography store, or camera store. They will either do this for you or send you to someone who will
Jun 19, 2009 | Funai PY90VG DVD Player/VCR
RCA model F27688-attempting to hookup new VHS/DVD player.
you will need the orignal remote to do this either hit the av button or game or input select button!
Jan 24, 2009 | Televison & Video
Dvd hookup to my vizio 37
thankyou i fix the dvd by going in the back of the dvd and changeing the wire ot out that was my prolem thank you for the help
Jan 12, 2009 | Vizio L37 Television
Vhs hookup to tv
Try hooking up the AV cables, unless it's an older model(1993-1998) then you might require a coaxial cable. After this you simply plug it into the wall outlet, but I would suggest a surge protector for a Hitachi. If that does not work, then it is simply not compatible, but it should work, good luck
Dec 22, 2008 | Hitachi 42HDS69 42 in. Plasma Television
New dvd/vhs player but old tv
The easiest thing to do would be get a new TV plain and simple sounds as if you could use one n e ways. But first make sure you are hooked up through coaxal to the tv that will allow everything to run on channel 3. Let me know your current hookup.
Dec 24, 2007 | Televison & Video
Panasonic recorded dvds? what's up?
http://service.us.panasonic.com/OperMan/findmanual.aspx?model=DMRES40V
Try the Manual. It has a finalizing section. This is the link above.. Pat
Aug 02, 2007 | Panasonic DMR-ES40V DVD-Video Recorder
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
