Question about Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag bravos dryer belt needs to be replaced
Maytag bravos steam dryer fan belt came off, how do I get my hands in to get it back on??? There are no access points except the back.
    Novelist:
  • 145 Answers
Check in the back and see if the belt has a wide span on it. If it does, it doesn't only go around the fan pulley but also the drum (Which is usually the case). THis being the case you need to look for and screws you can find on the dryer outer casing because you will need to remove the outer casing to get to the drum. If you look for screw on the upper part just inside the door many times the upper deck is on hinges and will tilt backward so you can view the top of the drum with the belt on it. Remember how it came apart; it goes back together in reverse manner. Once you usually find the belt tension pulley through the back of the dryer compartment, let the tension off the pulley and slide the belt off of it. Once you get the belt off put it back on just like the old one.
Posted on May 02, 2010
  • Brad Jensen
    Brad Jensen Feb 17, 2012
    wrong, these units have a fan belt that is infamous for coming off.
My Maytag Bravos XL dryer will start but not heat at times. I was going to take the unit apart to inspect the heating element and the rest of the unit. I had unplugged the unit and removed the dryer v
Im assuming you have a steam dry option? If this is the case there are fuses attached to this system to avoid injury and bad this from happening. These fuses blow a lot. If you have a ohms meter, check the fuses on the steam dry unit for ohms. I bet one of them is blown and that is the reason your not getting heat during this cycle.
Nov 13, 2014 | Maytag Dryer. Bravos XL 7.3 cu. ft....
Ma secheuse maytag ne fait pas de vapeur
translation
My Maytag dryer does not make steam
Permalink
When I put on this function makes no steam
questions
1. is there water flowing to the dryer?
2. Is the dryer connected to a water source
3. Are there any clogged water filters or screens in the back of the Dryer.
4. If there are no water problems, then I would check for thermal fuses or defective control boards.
Oct 30, 2014 | Maytag Dryer. Bravos XL 7.3 cu. ft....
Replace belt on a maytag med6400tqo
bCheck out a video on youtube. This is a fairly simple do it yourself, but you will need to remove the cabinet of the dryer just leaving the barrel. Remove back cover, remove lint screws. Slide belt between cabinet and barrel. Lay dryer on back and around tension pulley and motor.
Jan 12, 2014 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Blower motor belt
It could be belt or belt idler problem or rollers or drum has twist on it or motor pully issues .
Every part of dryer drum and motor pulley and idler and belt should be examine and run dryer without top and check it with load and without load and try to isolate problem
Dec 06, 2013 | Maytag Bravos Series MEDB850WQ Electric...
Maytag Bravos dryer Model # MEDB850WQ0 Just gave my right arm to gave a service technician put my slipped fan belt back on my dryer. He wouldn't show me how to disassemble the unit if it happens...
Hello, Thank You for using FixYa. I will be helping you today.Use a putty knife to push in the lock tabs just under the lid or top in each corner push in firm and lift the top. When the top is open there are two screws one on each side holding the front on remove and lift the whole front. That's it....And if its the blower belt that comes off we are suppose to put locktite on the pulley to stop that from happening..
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My maytag dryer has plenty of heat and the drum is turning, but it is not blowing the hot air and moisture out the vent. I have checked the panel box and everything is fine. My dryer is a Maytag Bravos,...
pull the vent hose off the back of the unit turn it on and make sure it has alot of blowing power if it does blow good you have a clog in your vent hose somewhere,, if not your blower could be bad,, if i remember correcly that one has a belt just for the blower also check that
May 03, 2011 | Dryers
My bravo steam dryer is showing an F1 code, and I can't get it to start
this is a control board issue, you may be able to clear the fault using these steps:
1) Unplug or turn the circuit breaker off for 30 seconds.
2) Plug the dryer back in or turn the breaker back on.
3) Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
4) Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
If it will not clear then you will need to replace the control board, Good Luck Tim
Mar 05, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag Bravos 7.0 Cu. Ft. Electric Dryer Logo
965 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
