Question about Garmin Nuvi 660 GPS Receiver
Cannot seem to get power with cord plugged into cigarrette 12V plug in in truck
    Sergeant:
  • 293 Answers
Hi and thank you for using fixya:
Please make sure your outlet in your truck is a 12V outlet.
Apply pressure inside and twist while doing it. Some times it is hard to get it in.
Good luck
Posted on May 02, 2010
Can I charge my device with a 12v lighter power cord? Does it matter if the power cord is 12v and the device is 12.9v? Bill Dobson.
i am looking into the same thing at the moment. apparently you can use a 12v car charger to charge this unit, you just need the correct size plug to fit. when the car is running, it generally outputs 12.3 to 12.7v through the dc plug, so it will charge the unit, just may take a little longer, best to charge while travelling to keep charge volts up. i got this information from a car battery shop.
Jun 01, 2010 | Logitech 984-000057 Pure-Fi Anywhere 2...
200/400 watt Powerline Dc to AC Inverter blows fuses
If the inverter is blowing the fuse immediately upon plugging in the inverter (before you even plug something into the inverter) you most likely have a short in the 12V power cord. If you have an Ohm meter, you should be able to check the resistance across the two contacts on the 12V plug of the power cord. Wiggle it around some. If you get a very low reading, and especially if it's intermittent, you have a bad cord, which should be pretty easy and cheap to replace. My experience with these cords has been that their quality is pretty poor.
If that is the problem, maybe you can cannibalize a cord from an old CB radio, but here's a fairly heavy duty one on Amazon (they don't give an amp rating though) http://www.amazon.com/Truckspec-TSPSCBH-2CP-12-Volt-Platinum-Replacement/dp/B001JT5QF0
Feb 23, 2010 | Powerline 0900-73 Slimline Inverter
My gps model# c330 wont turn on is totaly discharge
Check to see if you are getting power through you cord. You should have 12v at the plug end to the GPS unit. If not, you may have a blown fuse or no power at the plug. There is a fuse in the male 12v plug for your GPS. Unscrew the end to check it.
Dec 19, 2009 | Garmin StreetPilot C330 GPS Receiver
I need a 12v cable for Sharp Aquos (car to tv)
click at www.shopjimmy.com they have the power cord for your tv.or go to google and type
power cord .
Aug 18, 2009 | Sharp Aquos LC-19D45U 19 in. LCD TV
Fried HD?
Yep, it's probably fried, a little too much juice went in.
While the drive itself might be ok, the external casing is another story.
Try opening the case and removing the HD and plugging that in on your PC directly as a slave drive.
Sep 28, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Cobra XRS 757
There are 2 options for power plugs that can be purchased from Cobra for the 757. The straight 12V power cord is listed under item number: 420-030-N-001 and the coiled 12V power cord is listed under item number: 420-026-N-001. Both can be purchased from Cobra by calling their order line at: 773-889-3087 or visiting www.cobra.com
Sep 15, 2008 | XRS-757 Radar Detector
MAG INNOVISION
The socket for the AC power supply is located RIGHT ON the cord that plugs into your tower/graphics card. I just bought one today at the thrift store, ** power cord, but was looking for the input myself and found it there. Hope that helps.
Feb 18, 2008 | Mag Innovision InnoVision LT 765S 17" Flat...
New Power Cord Stopped Working
DO NOT use the HP power adapter that is 19V / 3.95A. That is too much power for the Scanjet, which is expecting 12V DC (and a much lower amperage). It's possible that hooking up this power adapter may further damage the electronics inside the scanner. If the second adapter has stopped working then it is possible that the internal circuit board has damage already and another adapter may not work. If you have access to a multimeter / voltmeter you could check for the 12V coming from the adapter. If you're getting the 12V, then the internal circuit board to the Scanjet is probably defective.
Nov 17, 2007 | HP Scanjet 4470c Flatbed Scanner
Garmin Nuvi 660 GPS Receiver Logo
114 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
