Question about Yamata FY700 Mechanical Sewing Machine
My sewing machine keeps tieing the tred under the needle in knots so what do i do?
Maybe the needle bar is too low,when stitching.
Posted on May 16, 2010
How to loch the stitch on Juki-562?
If there is no reverse on the machine, you can shorten the stitch at the beginning and end of the item. Or, you can sink the needle, pivot the item 180 degrees, sew a short distance, then pivot back 180 degrees and stitch over the first stitches. Other than that, tying the thread tails in a knot.
Nov 14, 2016 | Sewing Machines
How to threadle the needle
Thread the needle? Just insert the tip of the thread into the needle's eye. If you have vision problems, it helps to lick your index finger and then swipe it across the BACK side of the needle's eye. The thread end is attracted to the moisture and helps pull the thread into the eye. Some sewists swipe the thread tip with chapstick to stiffen it.
How to Thread Needle and Tie Knot
Sep 29, 2016 | Sewing Machines
Thread keeps knotting up under the fabric (bobbin area)
Could be what is called thread nesting or bird nesting.
The first thing to try is installing a brand new needle in your machine. Then try the following suggestions:
sewing machine birdnesting
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
3 Common Sewing Machine Problems and How to Fix Them
Nov 29, 2015 | Brother XL-5130 Mechanical Sewing Machine
I have a singer 201 knee control and I love it until today.
try these suggestions
rethread the machine top and bobbin, using every thread guide
try a new needle--one for the fabric being sewed--make sure the needle is inserted correctly into the needle holder
make sure the thread does not come off the thread take up lever
try a different bobbin
make sure the bobbin is turned the right way in the bobbin case
clean under the needle plate and in the bobbin area for lint
Oct 29, 2013 | Singer Sewing Machines
The thread on my empisal pacesetter10 keeps on making knots under the material please help
try changing the needle-make sure it's the right one for the fabric & thread
try changing the thread--may have some knots in it
try adjusting the top tension
Apr 11, 2012 | Sewing Machines
Can't set the tension on needle or bobbin to match
1. make sure your machine is threaded right.2. set the tension between 3 and 4 and play with the tension as you need it to adjust it.3. make sure the bobbin is threaded right.make sure to visit the site below; it has solutions to multiple problems and instructions how to thread the needle or bobbin. Good luck.htt://Fix Looping/Knotting Thread Fix Knotting/Bunching Thread Looping Bunching & Knotting Thread
Aug 03, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
Thread is knotting up on bottom of fabric causing it to stop
1.check the needle & see if it's bent--if so replace
2.lay the needle on a flat surface & roll the needle over if it doesn't roll true replace
3.check for blunt needle-if needle makes a popping sound when needle penetrates fabric
4.needle is not all way up in holder
on my mechanical sewing machine sometimes the threads come off the take up lever, that causes the thread to bunch up under something I'm working on
also check thread in bobbin
Jul 28, 2010 | Janome 4623 Mechanical Sewing Machine
How to tie knot using handy stitch machine how to tie off the thread so it won't come undone.
When you get to the end cut the threads long enough to be able to tie.
From the wrong side of the fabric, if you pull the thread slightly you will see the a loop from the top thread, pull this, so now both threads are on the wrong side, tie a square knot and cut close to knot, you can also put a drop of fabric glue on the knot to help secure it.
Hope this helps, and please rate if helpful or not
Moni
Sep 20, 2009 | As Seen On TV Handy Stitch Mechanical...
Thread Mess!
The symtoms you describe are typical to insufficient top tension.
First check the dension dial is on S for normal sewing and E for embroidery. If this is the case, re thread your machine with the pressure foot up and make sure the thread goes over the take up lever.
Dec 10, 2007 | Singer CE-200 Quantum Futura Computerized...
Sudden knotting under fabric
I have an Elna 2005 machine and had a similar but opposite problem whereby the tension up top was too tight - thread wouldn't pull smoothly. I found adjusting the feed dog lever slightly helped the stitches a lot, even though the needle tension up top is no better. Hope that helps! :-s
Jul 01, 2007 | Elna 2007 Mechanical Sewing Machine
Yamata FY700 Mechanical Sewing Machine Logo
74 people viewed this question
Top Yamata Sewing Machines Experts
Lyle Siemens
Lyle Siemens
Michael Kovalik III
Michael Kovalik III
Cleverer2
Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
