Question about Canon PIXMA MP160 All-In-One InkJet Printer
Ive got un E3 flashing but i dont have any paper jammed please help me
    Scholar:
  • 67 Answers
You need to make sure you thorughly chek the paper path. Sometimes a tiny bit of paper is jamming a sensor that throws up the jamm error. Also, a sensor can become stuck and just needs to be freed. Do the above and turn it off/wait 20 sec/turn on. If it does not reset itself and clear the error, try the following:
1) Turn off. Turn on and when the ink carriage begins to move toward the center, quickly unplug the power cord from the rear or the printer. The idea is to stop the movement so that you can move the carriage by hand.
2) There is a 1/4" wide transparent "encoder strip" that runs the length of the printer from left to right. This strip passes through the rear sensors of the carriage, so be sure not to displace it. Using a Q-tip soaked in alcohol, carefully clean the strip on both sides along its entire length. Move the carriage with your hand as needed.
3) Give it a few minutes to dry, then plug it back in and power on.
If none of the above remedy the error, it may be that the pickup roller is slipping and needs cleaning. It's not easily accessible, so use a long Q-tip (type on the wooden stick) with alcohol to reach deep into the printer floor to the pickup roller, push-rotate as you clean. Try test printing again.
Posted on May 02, 2010
Error 3 indicated - what is it and how do I fix it
E3 means that there is a paper jam. If you are getting the E3 error and there is not an actual paper jam you may need to do is simulate a paper jam. Try inserting paper crooked to cause a jam so that when it starts trying to feed the paper through it gets jammed. Then lift the cover up and take the paper out. You'll then get a bunch of the lights flashing. Turn the printer off and then back on and you should be good to go.
Mar 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Canon pixma MP240: keeps flashing Error E3 paperjam but not paper can be seen inside the printer. Makes noises as though priniting but only puts blank pages through. If power is turned off and...
Hello thanks for using fixya
E3 error is mostly because of paper jam
. their may be small bit paper jam in side.
Even it feels that their is no any piece of paper inside the printer but actually it exist & inside of the printer makes paper sensor & its not function properly
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jan 28, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Paper jam (e3) BUT no paper jam
make sure you open all check points, if yours has a rear feed through, look in there also. it only takes a tiny piece of paper to cause it to say that. use a flash light, have had to use one to find several that way.
Feb 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon Pixma MP160 shows errors E3 and won't print
Error E3 : Check if the paper has jammed in the machine, reload the paper in the machine correctly and then press [Black] or [Color].
Paper Jams :
Cause : Paper jams in the paper output slot/ Auto Sheet Feeder.
Landscape Credit Card sized paper jams inside the machine.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn the machine OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will eject automatically.
2) Reload the paper into the machine and press [Black] or [Color].
* If you have turned OFF the machine in step , you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Important : You cannot load Credit Card sized paper in the landscape orientation.
Hope this helps.
Have a good day.
Dec 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error code E3 with no paper jam
it is problem your printer can not feed paper properly or problem paper feed sensor please try to resum button press when occard this E3 signal or clean sensor or claugth
Nov 21, 2009 | Computers & Internet
My canon mp140 keep on flashing E and then 2 whats the problem
e2 is no paper, E3 is paper jam, E4 is no ink, E5, wrong ink, E8 waste ink absorber full
Jun 24, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Printer all in one
E3 is a paper jam error, but I would use a flashlight and small mirror to check for any paper scraps or paper clips and remove them carefully. If you can't find anything then it's possible that the paper path sensor is broken and would require a shop repair.
Jun 22, 2009 | Office Equipment & Supplies
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
80 people viewed this question
old marine
old marine
