Question about Brother DCP-135C Flatbed Digital MFC All-In-One InkJet Printer
How do I replace the ink absorber pad, where in the printer is it.
  • 4,041 Answers
Hi There
To get at the ink pads all the printer goto be taken apart it a big job, you cant miss the ink pads when you open the printer apart it one big mess of ink there.
All the best Pineworks
Posted on May 02, 2010
SOURCE: How to open Canon iP3000 and remove absorber pads?
my computer see the printer as ip3100 & ican`t load my driver
Posted on Mar 12, 2008
CAM THE MAN
  • 20 Answers
SOURCE: waste ink absorber
This is the ink counter reset instructions:
1. Service mode: Menu->Scan->Copy->Scan( one at a time in sequence)
2.Select "test mode"
3.Select "(8) ETC
4.Select "(4) EEPROM CLEAR
5.Select "(1) INK COUNT
6. press the OK button
7. Press the STOP/RESET button(returns you to the TEST MODE sub-menu
8. Press the ON/OFF button (which resets the printer).
There you go.
Posted on May 27, 2008
  • 49 Answers
SOURCE: Ink Absorber Replacement for Canon i70 Printer
Not easy for most people to replace or clean ink pads, but this will reset
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button.
(Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button.
(Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
(Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
Posted on Jul 06, 2008
  • 421 Answers
SOURCE: canon ip4300 ink absorber is full
You need to reset the waste ink counter. The printer doesn't know that you have replaced or cleaned the pads you need to tell it.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Hope that helps, if it does please rate my solution.
Thanks
Posted on Nov 14, 2008
SOURCE: MP760 - how to disassemble? (waste ink absorber almost full)
You really don't have to disassemble it. What would be helpful tho is some sort of long needle-nose forceps. Tho I bet you could get by with a pointy chop-stick in a pinch. There are two waste-ink absorbers on the right, and one spongy thing on the left. With the 'hood' open, allowing you access to the cartridges, you should be able to see the pads. Get a Petzl light on your forehead, you'll need a lot of light! The sponge on the left is covered by a small clear plastic trough that channels the ink into the sponge below. With enough poking and prodding you should be able to get all these out, rinse with water, dry with a hair dryer, blot out the pad areas with a kleenex, and pop them back in. Good Luck!
Posted on Nov 14, 2009
Canon IP90 ink pad is full
This may clear the ink absorber problem. There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Feb 11, 2013 | Canon PIXMA iP90 Mobile Printer
Tip
The Ink absorber is for waste ink when the printer cleans the printheads. All...
This error is common in all the newer variants of canon printers.. Canon charges 50-80$ to fix it! But it can be fixed by following the steps below:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with o
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
on May 01, 2008 | Canon PIXMA iP90 Mobile Printer
Where do I Find the ink absorber bottle
Inkjets do not have a bottle for the waste ink. Instead there are two sets of rubber pads that act like sponges. One set of sponges is directly below where the ink cartridges "rest" when the unit is not in use. They absorb the ink from the print head cleaning routine. The other set is at the bottom of the printer. You basically have to disassemble the printer from the top to reach the pads. The pads are in little plastic trays that hold some of the excess ink. If you remove the pads, blot the bulk of the ink off the pads and the trays on some paper towels.
The pads can be replaced or cleaned by rinsing under running water until the water runs clear. Let the pads dry before replacing them. Then you would need to reset the counter for the ink absorber. This involves entering the maintenance mode and depends on the printer model. The most common steps are: with the printer off, press and hold the Resume/Cancel button. Then press the Power on button. Hold the Power button and release the Resume/Cancel button. Press the Resume/Cancel button twice and then release all of the buttons. When you see a green light, press Resume/Cancel 4 times. Turn the printer off and then back on.
However, the components of most inkjet printers are near their expected failure point when the number of pages printed reaches the value that triggers the "ink absorber full" message. If your printer is under warranty and gets this message, contact Canon.
I hope this helps.
(resetting the ink absorber full counter without cleaning or replacing the pads will eventually lead to ink spilling out of the printer.)
Oct 21, 2012 | Canon PIXMA MP180 All-In-One InkJet...
WHAT IS AN INK ABSORBER
The ink absorbers are a set of rubbery pads that absorb the ink during the printer cleaning cycle. They can also absorb ink from borderless prints (where the ink goes out to the edges of the paper). Some of these pads are below where the print head goes when in standby mode. Additional pads are further down inside the printer.
To get at them, you need to disassemble the printer and it's a messy job to replace or clean them. The counter for the waste ink pad full is set to a value that usually should be reached near the expected end of life of the printer.
If the printer is still under warranty, contact Canon to have them deal with the problem and reset the printer.
I hope this helps.
(You may be able to find the reset command by Googling waste ink full and your model number.)
Jan 09, 2012 | Canon PIXMA MP170 All-In-One InkJet...
Ink absorber full on a canon mp190
my canon Mp 190 ink absorber all most full. How to do?
May 09, 2011 | Canon PIXMA MP190 All-In-One InkJet...
How can I change the foam pad that absorbes ink? What part is that called?
Hello
Its better to just remove them clean them up and replace it in the printer, because usually some printers require a reset code to re-set the waste ink counter. If the counter is not re-set there will come a time when then printer will refuse to print.
Here is how to clean your waste ink absorber;
Open the printer and locate the waste ink absorber near the ink cartridge.
Remove the absorber pad and hold it in cold water while squeezing the ink out. It would be wise to wear gloves while doing this, because the ink in the pad will leave stains.
Use paper towels to dry the waste ink absorber pad. Let it dry completely before installing it back in the printer.
Reinstall the ink pad into the printer and run a test page to make sure it works.
Apr 20, 2011 | Epson Stylus Photo R300 InkJet Printer
Locate waste ink absorber pad
canon pixma ip1000 printer, how do you access and clean waste ink absorber pad
Apr 13, 2010 | Office Equipment & Supplies
What is waste ink obserber? How it will be replaced?
waste ink pad absorber is like a waste tank made of absorbent pads, in here the waste ink is absorbed. In time this waste ink pad will be saturated or full. When it happens the printer will suddenly stop working. The printer needs to be reset to function again and the waste ink pad replaced to prevent flooding of waste ink inside the printer. The waste ink pad is replaced by disassembling the printer.
Jan 17, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Ink absorber replacement options - MP130 or how do I clean it? It is almost full according to error message
Removing & Cleaning the Absorbent pads.
The printer has 2 ink absorber pads that are located under the ink cartridges.
1. With power off the head assembly / cartridges can be moved into the middle for access.
2. Each of the 2 ink absorber pads are seated in a rubber retainer. The pads can be easily removed cleaned or replaced.
3. Carefully remove the pads using long nose pliers or tweezers.
4. Clean the using with running warm water, or use an isopropyl alcohol bath, or an isopropyl alcohol based aerosol if they are really dirty. DO NOT USE ANY SURGICAL SPIRIT OR ANY OIL BASED CLEANERS. At a push you can use a warm water mild washing up liquid bath but be sure to thoroughly rinse out the solution after cleaning. The pads should be white when they are clean.
5. Dry the pads – it may take some time and placing them in a warm environment or near a warm radiator will speed this up.
6. Clean away any ink on the retaining rubbers using a cotton bud or clean and soft lint free cloth.
7. Replace the DRY pads in the rubber retainers.
8. Replace the Ink cartridges.
9. Power on the printer and print a test page and clean and realign the heads as required.
10. If the E27 error message reappears then you will need to reset this.
Clearing procedures for E27 or Error 27 Code.
1. Power on the printer by pressing the Power button while pressing and holding the Stop/ Reset button.
2. When the Power led is green press the Stop/Reset button two times while pressing and holding the Power button.
3. When releasing the Power and the Stop / Reset buttons the printer will move into a service mode and will be Waiting for a menu selection.
4. When the Power led is green, press the Stop/Reset button 4 times for waste ink counter reset.
5. Power off the printer and Power it back on again to complete the reset.
Oct 23, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon pixma MP110 waste ink absorber full
1 - Turn on the printer
2 - press MENù SCAN COPY SCAN (it will enter in service mode)
3 - select TEST MODE
4 - Select PRINTER TEST in TEST MODE
5 - Select EPROOM CLEAR
6 - Select INK COUNT
7 - Press OK
8 - Press the STOP/RESET key and then press the ON/OFF key
9 - Change the waste ink absorber in the printer
Oct 24, 2008 | Office Equipment & Supplies
Brother DCP-135C Flatbed Digital MFC All-In-One InkJet Printer Logo
1,188 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
