Toshiba Satellite A300D-15 does not start 1/ The AC charger is able to deliver 19V (tested with multimeter) 2/ When we use its AC charger on another laptop (FUJITSU SIEMENS) having same charactéristics for AC power, it is detected by the Fujistsu and able to charge the battery 3/ When we tried to plug the Toshiba AC charger on the toshiba satellite, the AC is not detected (no led on) AND if just after having disconnected it I check the output with my multimeter, there is less than 1 volt. I have to unplug it the charger from AC and then reconnect it in order to measure 19 Volt again. 4/ If I use the AC charger of the fujitsu on the toshiba satellite, it does not manage to start too but what it is amazing is that the AC charger of the fujitsu checked with the multimeter continues to deliver 19 Volt output. My conclusion, I don't know why nor how but the satellite toshiba is able to block the toshiba AC charger output but not the fujitsu one. I think there is an internal configuration of the toshiba thinking that the battery is full while it is not the case and so is able to stop the AC charger. The problem is if i remove the battery and start only with AC, I have the same problem. Anyone can help me ? Why both AC charger have not the same behavior ? Is it a motherboard/mainboard problem ? Is there a solution to go out of this configuration ? Regards
SOURCE: My satellite M55-S331 Toshiba laptop screen went black
I had the same problem, and this article worked for me. Good luck.
http://www.daniweb.com/forums/thread41145.html
Posted on Jan 22, 2008
SOURCE: Toshiba Satellite Laptop Power Failure (A105-S1013 System Unit)
I tried to upgrade my RAM for my Toshiba Satellite A105-S1013, and thought the computer was turned off....WRONG!! Now my laptop won't boot up, did I kill my motherboard? The laptop will turn on, but it doesn't sound like anything is booting up.
Posted on Feb 24, 2008
  • 45 Answers
SOURCE: Toshiba Satellite A105 no power
try looking at the DC input. My brother's 1st laptop had that same problem. All we need to do is solder it. Remember-1st dc connection, not the one on the MB.
Posted on Aug 19, 2008
  • 4 Answers
SOURCE: FUJITSU SIEMENS S6010 WONT TURN ON, HELP!!!!
Hi, I have alot of Motherboards for that Laptop. Maybe a New Motherboard Needed. CPU May have Burned out?
Email: microxtremecomputers@live.co.uk
Posted on Feb 07, 2010
RescueTechLA
  • 2653 Answers
SOURCE: Laptop Toshiba Satellite A200 Model No. PSAF6A-02C01N fail boot
Try removing / swapping / reseating the memory.
Try booting with one stick only, if the top slot doesn't work, try booting the bottom slot. Try both sticks.
Let me know what happens.
Posted on Apr 04, 2010
Testimonial: "First step in a series to diagnose. On the journey. Useful thanks."
L655 Satellite won't start up.
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
Replacement Toshiba Satellite L655 AC Adapter 65Watt 19V 3.42A
Replacement Toshiba Satellite L655 AC Adapter 75Watt 19V 3.95A
Dec 17, 2012 | Toshiba Satellite Pro A210-EZ2202X...
My computer says plugged in, not charging
Dead battery. Test battery, try another cord/charger to verify.
Dec 01, 2012 | Toshiba Satellite A135-S4527 Notebook
My toshiba satellite U505 turns off suddenly when i turn it on. What might be the problem
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
http://www.chargerbuy.com/replacement-toshiba-satellite-u505-ac-adapter-19v-3-42a.html
Nov 22, 2012 | Toshiba Satellite U505-S2940 Notebook
Mini dell 910, no power
Possible causes:
http://www.chargerbuy.com/replacement-dell-inspiron-mini-910-30w-ac-adapter-19v.html
Nov 21, 2012 | Computers & Internet
My acer aspire 4730Z is not turning ON....battery is down....when am connecting dh charger pin to dh lap, dh green indicator of dh charger goes on blinking. Lap top is like completely dead dat even dh...
Possible causes:
Replacement Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Intocircuit Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Nov 19, 2012 | Acer Computers & Internet
Connecting charger and letting charge for sometime...charging light doesnt turn on and laptop doesnt turn on...any advise?
http://www.chargerbuy.com/replacement-toshiba-satellite-c655-ac-adapter-19v-65w.html
http://www.chargerbuy.com/replacement-toshiba-satellite-c655-ac-adapter-19v-3-95a.html
Nov 07, 2012 | Toshiba Satellite C655-s5140 Laptop
Power port not working on toshiba c655
You had better replace your laptop charger. Even if you go to repair it, it will cost you the same price of getting a new charger. So it is wise to purchase a new one. Here are two for your reference:
$9.99 for Replacement Toshiba Satellite C655 AC Adapter 65Watt 19V 3.42A
$12.90 for Replacement Toshiba Satellite C655 AC Adapter 75Watt 19V 3.95A
Nov 03, 2012 | Computers & Internet
Toshiba satellite L305-s5955 will not power up
If there is no power light and it can't charge your laptop, it is likely that the charger is dead. You need a new laptop charger. So try a new adapter to confirm the real issue.
There are two kinds of ac adapters for your toshiba l305-s5955
Toshiba Satellite L305 AC Adapter 75Watt 19V 3.95A
Toshiba Satellite L305 AC Adapter 90Watt 19V 4.74A
You should choose the right charger depending on your original adapter's specification. If the original one need 90w, you won't buy 75w that will bring damage to your laptop. If it needs 75w you can use 90w too.
Oct 14, 2012 | Toshiba Satellite L305-S5955, L305-S5956,...
Toshiba battery charger pa3468u-1aca for satellite L305-s5944 is beeping and the unit is not charging, what is wrong?
Probably a failed AC adapter. Please try to charge the laptop with a good, working AC adapter & see if the problem disappears.
Jun 12, 2011 | Toshiba LAPTOP AC Adapter Power Charger...
I have a Toshiba L35 Satellite S2174. I lost my power adaptor so started to use a HP adaptor of same 19 V , but Different Current 3.16A. I dont have the current rating of my original charger. The...
Hi Arsalan
To answer your question Its "yes". wrong power/ampere rating can shorten the battery life. I recommend that once you replace the battery include the AC adapter.Thanks
Feb 20, 2011 | Toshiba Satellite L35-S2174...
Computers & Internet Logo
546 people viewed this question
David Payne
David Payne
