Question about Dyson DC25 All Floors Bagless Upright Vacuum
My brusg stopped turning after sucking up a shoe
My brush stopped turning after sucking up a shoe string. I have removed it and anything else that may be stopping it from turning but it still don"t work. What do I need to do?
  • 438 Answers
Hi There is a reset switch on your Dyson that needs to be pressed when something gets stuck in the brushes. The reset switch helps protect the motor that spins the brush from damaging if something gets stuck inside the brushes. There is a little red pole that sits up behind the brushes on the vacuum head, I believe it's on the left side of the floor head as if you were behind the machine vacuuming. Try pushing this reset switch first. Did this fix your problem? If no, please let me know and I'll be more then happy to do some more advanced diagnosing with you.
Posted on May 03, 2010
  • 1 more comment
  • sterga4412 Sep 03, 2010
    I did what you said but the brush still doesnt spin. what should i do now?
  • shaggarty Dec 19, 2010
    i too have this problem but cannot see any red pole to reset ?
    any other ideas?
  • KarasGram Feb 06, 2011
    The re-set switch is actually on the RIGHT side of the ON-OFF switch. Worked perfectly after I sucked up a shoe-string!
My brush stop working
Barring any electrical failure or loose plug the most common cause for the vacuum brush to stop turning is belt clogged with debris or string.
Unplug the unit and check the brush for string or debris (Hair) wrapped around the pully on either end. Clear this and check the belt to make sure it has not broken, stripped or simply slipped off. Usually the bottom plate is held on with just a few screws. Easy to remove and check Belt slipped off or stripped replace. Belt slipped off you can sometimes put back on and be vacuuming in no time.
Anything wrapped around the spindle a pair of needle nose pliers comes in real handy here. If you have snagged a rug, sheet or sock etc.. check the manual for a reset button. Some vacuums have this and all it takes is clearing the chute then resetting the switch. Good luck hope this helps!
Apr 03, 2014 | Vacuums
The brush wont rotate on my windtunnel vac but it still has suction. Could this be a broken belt?
Yep - that's usually the culprit if the brush stops turning. However, pull off the skid plate (bottom panel) and make sure you haven't picked up any string or some other obstruction that's wrapped itself around the brush & stopped it from turning. Things like hair/string don't always end up in the bag/bin sometimes if they're long enough they just wrap themselves around the brush.
Jul 13, 2011 | Hoover Vacuums
Beater bar stopped after sucking up shoe lace
Hi choward40,
Yah, vacuums don't particularly care for shoelaces! :>)
Did you get the shoelace taken out of the beater brush?
Did the shoelace go all the way into the machine?
Please reply back. Thanks,
Handie Andie
Apr 16, 2011 | Dyson Vacuums
Brush not spinning
Remove the bottom plate to see if the belt came off of the motor shaft, or perhaps it broke in two when the brush stopped turning. Hope this helps!
Jun 28, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
The brush is not spinning
Do you have animals or maybe picked up some string? Check the brush and see if anything is stopping it from spinning. You might have to manually turn the brush to get the string or hair out. You can cut it but be very careful.
Apr 12, 2010 | Bissell Healthy Home HEPA Bagless Upright...
My oreck vacuum has stopped sucking up things.
It won't turn the brush because the belt is stretched or broke from the heat of sucking something too big up. If you have your service manual it should show you the location of the belt covers to replace it.
Dec 03, 2009 | Montgomery Ward Oreck XL Celoc...
I sucked up a shoe string. It pulled out easy, but now the brush wheel won't turn or suction.
take the brush roll sole plate off and make the brush roll is properly sat in its housing, also the belt isnt broken
Oct 03, 2009 | Dyson Vacuums
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Dyson DC25 All Floors Bagless Upright Vacuum Logo
1,312 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
