Question about Sony Playstation 3 (PS3) Console
How do you the screen to come on games to play
How do you get the screen to come on games to play again?
  • zoopmitty May 11, 2010
    if you are getting no video and everything else works fine you could try these 2 solution. i don't know if it works since i haven't ran across this problem... someone posted this...... I almost went crazy with this! I tried
    everything everyone was saying
    and nothing worked. Finally I came across a posting that said as
    follows: 1. Turn off ps3 at back. 2. Turn off tv, and unplug it,
    wait several seconds to reset. 3. turn on tv first, make sure your input
    setting is set for the ps3 (you may have to quickly switch after
    turning on the ps3 at front) 4. turn on ps3 at back, then turn ps3 on at
    front, wait about 2 seconds, then press and hold ps3 button and the
    screen should pop up asking you about the video settings
    this is another method i found on this site i
    got this from getupart from this site and he/she said.... 1.
    Turn Off in back (wait few seconds for it to re-set) 2. Turn on in
    back 3. Turn on in front and hold your finger on it 'till it turns
    off again - (you get the beep on then the three beeps for reset
    and it will eventually beep again and turn off) 4. Turn off in back
    (wait few seconds for it to re-set) 5. Turn on in back 6. Turn on
    in front hold finger for three beeps and damn it works!
Why dark manor game didnot support my monitor risolution
Windows XP
  1. From your desktop, right-click and select Properties.
  2. Click the Settings tab.
  3. Adjust your screen resolution to 1024 x 768 (or higher) and select OK.
  4. Try playing your game again.
Windows Vista
  1. From your desktop, right-click and select Personalize.
  2. Select Display Settings.
  3. Adjust your screen resolution to 1024 x 768 (or higher) and click Apply > OK.
Windows 7 and Windows 8
  1. From your desktop, right-click and select Screen resolution.
  2. Adjust your screen resolution to 1024 x 768 (or higher) and click OK.
  3. Try playing your game again.
Mac
  1. Open up the Apple menu.
  2. Select System Preferences.
  3. Click on the Displays icon.
  4. Select the Display tab to adjust your resolution to 1024 x 768 (or higher).
  5. Reopen your game.
    _
    Try this out it seems to work for some people, if that does not work try this out:
    Switch to Windowed Mode
    If you continue to have trouble playing your game in full screen mode, switch to windowed mode. Under the main menu of the game, select Options, and un-check Full Screen mode (or vica verse if you already have windowed mode on, switch to fullscreen)
    Thanks and I would appreciate a reply if that got fixed or not.
    Good Luck!
Apr 27, 2014 | bigfishgames.com
Game not playing
This happened to me, it was because the computer I was using was too old
Jul 08, 2013 | Video Game Consoles & Games
My PS2 is not loading Grand Turirsmo 4!
If your PS2 works fine with most of the games and won’t play a few..Then you should try this trick to play them too on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:6e4cb56.jpg
  3. Press the (triangle) Button to enter Version Information Menu that looks like9d90dc8.jpg
  4. Highlight the Play Station Driver as above and again press (triangle).
  6. Highlight the Disc Speed as above and press X button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the game loads itself. If your lens is in good condition then it will play game in first go else try again till it PLAY your game. If still your Grand Turismo 4 DVD wont work then you must clean your PS2 lens.Watch following video to learn about cleaning lens:
Thank you and Good Luck!
Dec 16, 2009 | Sony PlayStation 2 (PS2) Console
Vertical red lines on screen
try a dif game and send me a msg at kickop1@ymail.com
Jun 27, 2009 | Microsoft Xbox 360 Console
White screen when playing pc games
Sounds like 1- you have a virus or 2- your computer's graphics card is not sufficient for the game you are trying to play. Double check all the requirements, if you meet them you have a virus. Hope i've shed some light on the problem :)
Mar 18, 2009 | Video Game Consoles & Games
DS R4
ok well if you want to play emulators you need to patch the files!
http://chishm.drunkencoders.com/DLDI/#patchers has the r4 file and the patcher called win32.
run the dlltool32.exe file and add the patch file and the emulaotr then patch it add it to ur dss card and it should run! DS games may need a emulator
Feb 14, 2009 | Nintendo DS Console
When playing a game the screen goes blank after a while
Dude, all you have to do is restart your console and it should start up fine. If it doesn't, keep restarting it until it does. The new-age HD cables have to load a lot of **** to and from your TV to display properly, and if it has the smallest delay, it doesn't display ****.
Jan 25, 2009 | Sony Playstation 3 (PS3) Console
My Xbox 360 won't play Xbox 360 games
run through your initial set up again.
Aug 19, 2008 | Microsoft Xbox 360 Console
PS2 won't read games at all.
It sounds like the lens is either dirty or no good. If it is only dirty, you can get a DVD laser lens cleaner from a place like Best buy or Radio shack.
Apr 24, 2008 | Sony PlayStation 2 (PS2) Console
Sony Playstation 3 (PS3) Console Logo
15 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
