Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
My tb425cs leaks gas when it is running. It drips from the bottom of the gas tank.
    Scholar:
  • 47 Answers
Be sure to not overfill the tank. Just load it with gas up to the bottom of the neck and be positive you're not cross-threading the cap when twisting it on. If it only leaks when operating, see if there is fuel bubbling out through the vent(s) in the top of the cap or out from under it. Also wipe the tank clean and dry to be positive it is not leaking from a seam or crack in tank or around fuel lines. If leaking from cap, might have to replace as they do have an internal rubber seal that could have gotten dry or cracked. If it's from the tank seams or fuel lines replacement may be neccessary of either one or both.
Posted on May 10, 2010
GAS RUNS DOWN FUEL LINES FROM TOP OF GAS TANK
sounds like sending unit gasket is leaking. drop the gas tank...sorry
Aug 20, 2012 | 1995 Buick LeSabre
Gas leak at bottom of tank where fuel gauge wires come out 1998 road king classic
Hi Anonymous, replace you fuel sending unit gasket. Have nice day.
May 22, 2012 | Harley Davidson Motorcycles
Gas leak from carburetor into bottom of air intake elbow. Filled empty gas tank and within seconds after opening the shutoff valve under tank, gas started to drip from bottom of intake elbow. Shut off the...
It sounds like the needle valve in the carburetor is not seating properly to shut off the fuel. A badly worn needle or dirt/debris in the needle seat area can cause this. Disassembly of the carb and a good cleaning will be required.
Sep 04, 2011 | Garden
The fuel tank is cracked at the top by the cap.What site can I go
Can't help with the tank, but your better auto parts stores do sell an epoxy that is designed to seal plastic fuel cells.
Apr 26, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
96 Ninja zx6r Fuel Tank breather hose leaking gas
It sounds like that hose which runs fron the cap area (inside) the fuel tank to the back bottom is broke, if you take it to a Kawasaki dealer and have your dealer call Kawasaki there is a good chance it will get covered as long as the tank is damaged. Those hoses (metal) that run inside the fuel tak sometimes crack, there is really not way of fixing them unless you cut the tank open and then you would need to reweld it.
Apr 26, 2010 | 2000 kawasaki ZX-6R Ninja
Starts and then shut off Troy bilt edger
clean out carb and run gas cleaner throught the tank
Dec 27, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Smell of fuel and minor trace of gas on bottom of tank
Something is leaking, and you have fire risk.
I would normally pull the fuel tank, and if inspection showed nothing obvious, I would take the tank to a radiator shop and have them pressure test it...
Be very aware that any sparks will ignite the vapors, no need to burn, you know.....
Do not ignore this issue.
Sep 20, 2009 | 2005 Pontiac G6
My troy-bilt TB425CS gas string trimmer gas lines have gone away. In replacing those lines how far into the tank do they go?
far enough so that you can reach through filler cap and pull the line out to attatch fuel filter.
then you can pull it back in and let it rest on the bottom of the tank
Aug 14, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
I have a 94 priszm and have had to replace 3 gas tanks in the
If you have ANY DAMP SURFACE AT ALL on that Tank You DO Have a Leak and it Must be Found,
The Steal Fuel Lines around the tank Get Rusty and Leak You must ELIMINATE Any POSSIBLE Leak, as this can Turn into A Tragidy.
Jul 12, 2009 | 1992 Geo Prizm
Fuel tank leaking how to solve problem gas is not pouring out but is seeping through bottom of tank There is fuel leaking from the top of the tank, is it a fuel overflow release or is the seal on the fuel...
If your gas tank is cracked or has a hole in it, you have to drain the tank, remove the gas tank and replace it, or have it repaired (if possible). If the gas tank is just leaking from the top and dripping along the side and to the bottom, you will still have to empty the gas tank, and remove it to get a good look at the condition of the gasket. It is not uncommon for these gaskets to become cracked or fragile over time because of the harsh chemicals and cleaning agents used in unleaded gas. If you do decide to have the gas tank removed, I would recommend replacing the fuel pump and fuel filter if your car has high mileage. Please rate this response if you found this helpful.
May 29, 2009 | 1995 Jeep Grand Cherokee
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
277 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
