Question about Samsung RB2155 Bottom Freezer Refrigerator
I have a Samsung RB215 refrigerator with a bottom freezer with ice machine. The ice machine is overfilling the ice making tray with to much water causing a water overflow inside the freezer. Is there an adjustment for this?
SOURCE: Ice Maker overflow
my icemaker overfill can you help
Posted on Sep 01, 2008
  • 15 Answers
SOURCE: Ice Maker Overfills With Water
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Posted on Jul 24, 2009
SOURCE: ice tray stuck
Hi My Samsung freezer was nor a RB2155 it is a RS2630SH however after not making any ice because the tray was stuck in the upside down position or thereabout after 6 weeks it suddenly started making ice again, we had not done anything to it but we heard it dropping ice one evening and we had a look in the ice container and low and behold the ice box was full to the top, I would still like to know why it went like that in the first place in case it happens again it is a mystery. Larry
Posted on Dec 23, 2006
  • 883 Answers
SOURCE: Ice maker water level too high
generally, there is a screw adjustment for this. usually, turning it clockwise sends more water during fill period (makes period longer). try it and adjust clockwise or counter-clockwise as necessary. Now finding the screw...try prying (or unscrewing) off the plastic cover over what appears to be the ice-maker unit (may also be on back side of frig.
Posted on Sep 17, 2007
  • 145 Answers
SOURCE: WHIRPOOL ED2
Not enough model to get the wire diagram. It sounds like a diode is out in the water valve harness. If it is using the triple valve on that unit.
Posted on May 15, 2008
Ice in the bottom of freezer ABB224WEB
If you have an ice maker, it may be overfilling. Ice makers have a trough that dispenses the incoming water to the tray. If the ice freezes in the trough the incoming water sprays all over the freezer compartment and settles in the bottom. I fixed the same problem by thawing out the trough with a hair dryer. Then I switch the cube size from "large" to "medium" to keep it from overfilling. I have not had the same problem for years.
Oct 31, 2013 | Amana ARB2217C Bottom Freezer Refrigerator
Kenmore refrigerator model 795
This is a simple fix but will take a little time to correct this. First of all, empty the freezer of food and shelving, ice maker if you have it also. The back wall in the freezer is a false wall, so gain access by removing screws and harness from top left corner. By the way turn off the unit or unplug it!! Now at the bottom of the unit far back you will see an ice glassier in the bottom middle is a drain hole that all the water is to exit after defrost. Well because its blocked with ice the water overfills and leaking into the refer section. Make sure you can use hot water to clear this out but make sure you cleaned out the entire drain system before reassembling this to restore cooling. Once clear you problem is solved.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 29, 2013 | Refrigerators
Rfg297aa won't make ice
Ice maker quit making ice. Ice tray in feeder was empty when I pulled it out. Water is working when I choose water but apparently no water is getting to freezer unit. What else can I check or do?
Oct 28, 2012 | Samsung RFG297AARS (285 cu ft) Bottom...
I have an Electrolux EW28BS71IS and I have water dripping from the ice maker. When I take the ice maker tray out it has water sitting in the bottom of it. I can't tell if it might be overfilling the...
i have an elecolux ice maker leaks water into the bottom trays from the back of the fridge and water always drips from the front dispenser. the ice freezes in a solid block can anyone help me please. ew23bc71is3 is the model double door freezer on the bottom tks.
Mar 31, 2011 | Refrigerators
My samsung bottom freezer refrigerator makes ice but wont drop it in the bucket. whats wrong?
clean the ice tray hard water depossits some times cause the cubes to stick if it is clean it may be the heater on the bottom of the tray
Feb 21, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
There is water leaking in the freezer. I imagine it is the ice maker. There is an "ice puddle" on the bottom level and occasionally water seeps out onto the kitchen floor. Is this easy to fix for a...
my model is not exactly the same but check for this this anyway:
Take a flash light & check for ice in the back vent underneath the very bottom shelf in the freezer. If you see ice in there, completely defrost until the ice is gone & the plastic drip hole is unobstructed. The leak on mine was happening because that hole had frozen over & caused excess water to flow into the bottom of the freezer & out the bottom of the door instead of through that hole.
Apr 20, 2010 | Admiral 26 cu. ft. Side-By-Side...
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Overfilled ice tray lots of shattered ice, no "cubes"
Hold in the freezer temp and the power cool buttons for 12 seconds, when the display changes toggle the refrigereator button untill desplay sAYS 03. Then toggle the freezer temp button or poew freezew button to a lower setting than what you have now.
Dec 22, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung fridge rb215 bottom freezer ice maker
On most samsung Refrigerator ice makers there will be a button on it to test the functionality of the ice maker. Its a small button covered with clear rubber. When you locate it hold that down for 10 to 15 seconds and if it is functional it should run through its paces. Is it the ice maker in the left fridge door , the freezer compartment, or the one inside the fridge to the left?
Jan 11, 2018 | Refrigerators
Samsung RB2155 Bottom Freezer Refrigerator Logo
191 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
