Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Carrier Weathermaker gas 8000 will not ignite
This gas furnace runs OK some of the time, but will not ignite sometimes unless I switch the thermostat off and on again (2nd thermostat-both problems). May run for days and recycle properly, then quit again.
  • 2 more comments
  • keymania Apr 01, 2008
    1. unit is 5 yr old and wiring has not changed, all connections tight
    2. thermostat sensing seems appropriate
    3. this is the third thermostat, have tried standard mercury switch as well as digital ,with the same results. These last two replaced both this winter.
    Comment- something is happening WITHIN the furnace control beyond the thermostat, and is intermittant. Works most of the time, then does not reignite. When the furnace fails to ignite, the exhaust fan runs continuously and has already been replaced. Turning the thermostat off and on recycles the furnace and works well.
  • PMCB May 21, 2008
    I have a Carrier Weathermaker 9300 TS and it does exactly the same thing!
    I have had 3 seperate repair companies look at it, clean the sensor, adjust stuff, etc. and they are basically suggesting I replace the furnace all together!! It is only 5 years old, but apparantly this is a real problem with these furnaces.
    In order to get mine starting, I have to turn it off at the main switch and then on again. This works only some of the time.
  • bill-bren Nov 26, 2008
    Every couple of days the furnace won't ignite. The new electronic thermostat is flashing for it to start, but it won't until the temperature in the house drops to about 5 degrees C below the setting or if I reset it. Once it starts it will be fine for a couple of days and then do it again. This is getting very frustrating. Any solutions??
  • Anonymous Dec 22, 2008
    I have a Bryant Plus 90 furnace. (15 yrs old) Every couple of days the furnace will not start. I need to turn the power switch off and then back on. The furnace then starts up. It happened a couple of times last winter, I replaced the air filter, SPACEGUARD, and had no further problems. The same problem began a couple of weeks ago, I changed the filter again but every couple of days the furnace will not start. The repair man was here for an hour and could not determine the cause. The thermostat will say "HEAT ON" but furnace is not running. HELP!
  • 86 Answers
1. check indoor unit wiring.
2 check sensar of thermostate.
3if not change thermostate
Posted on Mar 28, 2008
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Why wont an older model carrier gas furnace light when standing pilot light is lit at all times? Why would there be no gas at the burners
when it comes to GAS appliances , I do not recommend any self fixes . they can explode and do you serious damage even up to death .call a gas furnace repairman
Feb 28, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 58TUA doesn't work
The switch could be defective but more likely the furnace blower is failing.
Dec 17, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Feb 05, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Will not ignite. LED Code 31
Could well be the inducer motor Google carrier 31fault code there are 3 video's on this on u tube
Jan 15, 2018 | Carrier Weathermaker 8000 Gas Furnace 125k...
I have a Carrier Weathermaker 8000 furnace. it will not light.I tested the igniter on my upstairs furnace and it will glow and light that furnace. I can manualy light the furnace with a match. flame sensor...
If you're sure the igniter is good and the controller is sending voltage to gas valve to open, but not to the igniter then, yes, the controller is bad. The only way to know for sure is to remove the igniter's molded plug from the board and test voltage directly at the board. You should get about 100-120 vac to the igniter.
Mar 25, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Furnace wont run
First of all when you flip the switch, it goes thru a startup sequence. THEN it turns on the Igniter (notice the red glow). Then the gas turns on.
Now at this point check the idiot light and it should be giving you a code of 34. That 34 (3 shorts 4 longs) says that there was a problem igniting the furnace. After it cycles thru at least 4 times and fails to ignite all the blowers, then is when you get a code 14 (1 short 3 longs)
NOTICE what's happening with ALL the burner Tubes each time it attempts to ignite. If only one or two are running....then this is your problem.
To fix all you do is take out the burner Tubes, look for debris, blow them out (blow from the front where all the jets are), and replace them in sequence from left to right (the tabs overlap).
Jan 23, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker 8000 - furnace does not ignite
having a problem with a weather maker 8000. It will not come on at all unless I shut down the switch on the side of the furnace. filters is clean. it will start to light then stop
Dec 10, 2008 | Heating & Cooling
Your hot surface igniter may be bad. It may be cracked which would prevent it from starting the burner flame.
May 21, 2008 | Heating & Cooling
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
1,088 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
