Question about Samsung DLP HL-P5663W 56" TV
Samsung 56" DLP Audio/Video garbling
My Samsung 56" DLP started having problems with video and audio garbling, and then after 5 minutes no audio or video. TV is still powered on with fan/color wheel spinning but no audio or video. Looking for problem ID and expected cost to repair, THX!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with open the lamp door and check the lamp door switch, check if the lamp is working. Also check if the ballast is working fine as it is the power source for the lamp. However, from what you have described it can also be an issue with the Digital Board going bad, it is the large metal tin covered board in the rear of the TV where the VGA Cable is plugged in. All this is only recommended if you have electrical expertise and know how to solder/re-solder components. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on May 02, 2010
SMASUNG DLP 50 HDTV
defininatly the fan that cools the lamps is either not working or going out and needs replaced
Nov 12, 2007 | Samsung DLP HL-P5663W 56" TV
How to change lamp in samsung dlp 56
Check the following videos to find out how to replace the lamp (BP96-00826A) of DLP HL P5663W.
http://www.dataentryjobs.us/70091.html
Ajin
Feb 09, 2012 | Samsung DLP HL-P5663W 56" TV
My samsung dlp hl-s5686w turns for a minute video disappears audio continues and three lights flash the standby/temp,timer,lamp. all at the same time.
I'm having the same problem. Tried several things from dusting the inside with an air blower, removing the bulb and putting it back in, making sure the side panel is installed correctly and none of this has kept it from shutting off. Samsung's site says the three lights flashing means replace the bulb but I'm not buying it. My picture looks perfect....jsut that the TV keeps turning off. It all seems like a heating problem but my fans are still working. I'm scratching my head thinking what to try before forking out $150 for a new bulb.
Apr 30, 2010 | Samsung HL-S5686W 56" HDTV
Samsung DLP 56" tv,distorted picture
if you say that your picture gets distorted you mean like it moves to a side? do you see a black middle block?
if it's a yes?
so its probably the light engine. you need to change it!
try this link.. http://www.discount-merchant.com/1069179-HL-N5067W-p/1069179.htm
the price is more or less depends on your TV model... $279.00
Feb 02, 2010 | Samsung DLP HL-P5663W 56" TV
55 inch toshiba led tv audio sometimes gets garbled. must turn set off and on to correct
I have a Samsung 55 inch plasma that has experienced intermitent garbled audio, sometimes very frequent (a couple of minutes between episodes) and long in duration (several minutes). Switching to another channel and back would correct the audio.
I ran the auto program channel function a couple of times and it eliminated the gabled audio problem, except for infrequent (once every hour or two) and very short (a second or two in duration) episodes of gabled audio.
I found a thread on a CNET forum on this subject and it seems that the garbled audio problem affects a number of Samsung flat panel models.
Jan 16, 2010 | Televison & Video
Samsung 50" HD DLP TV video goes out
Common problem of a bad lamp call your local repair shop on price and availability of lamp.
Oct 22, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung ln t4665 black screen only sound
Ur backlight video board is dead,Need a new board.
Oct 03, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-S5086
Vertical problem and most likely a bad capacitor in the Vetical out circuit or IC.
Nov 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P5663W 56" TV Logo
Henry  Thomas
Henry Thomas
