Question about Intel D865GSA (BOXD865GSAL) Motherboard
How can i use headphones on my computer - Intel D865GSA (BOXD865GSAL) Motherboard
    Genius:
  • 1,354 Answers
Just cahck on your motherboard ther will be audio biten slote just cahck the back of you CPU
open your headphone ther wil be 2pins one for microphone and second is for speaker
Posted on May 02, 2010
Why compucessory headphones not working
Did you plug them into the headphone jack or the microphone jack on your computer ? Usually those 2 jacks are next to each other and it is easy to confuse them. If this is not the problem, maybe the headphones have a switch to turn them on (this would be unusual, but you never know...). Hope this helps.
Nov 16, 2014 | Compucessory Audio Players & Recorders
When I plugin my headphones The sound dosn't go to the headphones.
First, try plugging in different headphones. If those work, then your headphones are broken and you need to replace them.
If those don't work, then please check to make sure you're not plugging them into the microphone jack - you'll see two identical plugs, usually the headphone one is marked with a pair of headphones.
If you're plugging known working headphones into the correct port, then your computer must logically be the broken thing.
Dec 20, 2013 | Motorola Mobility S9 Headphones
Headphone jack does not work
The headphone jack on the computer connects to the sound card, a hardware device that controls audio input and output on the PC. The card contains a digital-to-analog converter that converts analog audio into digital signals and visa-versa. The performance of the headphone jack, therefore, depends on how well the sound card functions; if the card doesn't work, then the headphones connected to the PC won't output sound. Reconfiguring the audio settings will often fix problems with audio output on the headphone jack, but if the former fails to resolve the issue, replacing the sound card in its entirety is sometimes the only means of repair.
Click "Start." Enter "sound" into the search box. Select "Sound" from beneath Control Panel. Double-click "Headphones." If no "Headphones" option is available, double-click "Speakers." Click "Properties" on the General tab. Check the Device Status field for errors. Look up the message on Microsoft Support for more assistance, if applicable. Close the window if the Device Status field reads "This Device Is Working Properly." Go to the "Levels" tab. Click the speaker button to unmute the volume if the icon contains a red circle-backslash symbol. Drag the top slider to the right to increase the headphone volume. Go to the "Enhancements" tab. Check "Disable all Sound Effects." Go to Applications, and then clear "Allow Applications to Take Exclusive Control of This Device." Click "OK" to close Headphones Properties or Speakers Properties. Test the audio. If the headphones fail to output sound, unplug the headphones from the computer. Reconnect the headphones to the PC. Headphone jacks are color-coded lime green on most PCs. Look for the headphones symbol if the jacks are not color-coded. Plug the headphones into the line-out port on the back of the computer if the headphone jack on the front of the PC fails to work, or visa-versa. Test the headphones. If headphones still won't emit sound, the sound card most likely requires replacement. b> Replacing the Sound Card b> Shut down the computer. Remove the power cord from the back of the PC. Disconnect the keyboard, mouse, monitor and all other peripheral devices. Loosen the screws found on the back of the case, then slide the cover panel off of the case. Touch the chassis to protect the hardware from electrostatic discharge, or ESD. Set the computer on its side. Locate the sound card found on the opposite of the audio jacks and loosen the screw that secures the card to the computer. If no expansion card is located opposite the jacks, the computer uses an integrated sound card which can't be removed. Remove the new audio card from its protective packaging. Line up the card with an available expansion slot on the motherboard, then push the card down into the slot to install the new audio jacks. Screw the card to the computer case. Reassemble the computer. Turn on the PC. Boot in to Windows and insert the CD that came with the new expansion card. Follow the onscreen instructions to install the sound card software to the computer. Plug the headphones into the new line-out jack. Hope this helps.
Jan 21, 2013 | Acer Aspire Computers & Internet
Htc headphones distorted in computer
Have you tried using your HTC headphones in the other computers?
You can also try checking the connection or the jack if it really fits in correctly.
David
Jan 03, 2013 | Cell Phones
Sound through headphones only.
Try the speakers on another computer, to see if they work at all. If they do, then the problem is the audio-interface on your computer (or DVD-player, or home-stereo system).
Apr 05, 2010 | M-Audio Studiophile DX4 Computer Speakers
I bought my rca headphones a long time ago and haven't used them in years. I was wondering, how do I hook them up to my computer. And what all I need to do to hook them to my computer.
Just plug the RCA Headphones Base Station into the headphone or speaker jack on the back of your computer (the headphone or speaker jack usually being green in color), and turn the volume up in Microsoft Windows to about 75%, then adjust the volume control on your headphones to a comfortable level. (p.s. even if you don't use Microsoft Windows, turn the volume up to about 75%, as most computer sound chips are very similar in their output level.)
Nov 13, 2009 | RCA WHP150C Consumer Headphones
My headphones won't work!
look at the headphone jack, if it has 3 band, it is a stereo jack. the computer is mono.
you need a 2 band jack.
if you look at the jack on the computer, you will see blue(left) and green (right). you canna try to use the green jack.
go to any electroic shop and get a stereo to mono converter.
Dec 05, 2008 | Sky Hawk Computers (PSR5601W-SL) ATX...
Acer Aspire 5102WLMI speakers
Make sure you have the correct headphones for your computer stereo not mono the inner connector on the computer socket and the headset connector must align exactly if the speakrs still play while the headset is plugged in you have the wrong type of headphones connected try logitech brand Headphones designed for computer listening
do you not have plug specifically designed for a headset on your computer?
Jan 13, 2008 | Acer Aspire 5102WLMi Notebook
Sony MDR-V150 Headphones
hi Mrguitar
Happy holidays
Depending on the conector size and for the computer, I suggest go to Radio Shack and buy a extention jack to the headphone for your particular sound card, and headphone. this should work. sometimes the new conectors don't fit well on the sound cards. so change for an extention I send you a link of example
http://www.become.com/headphone-extension-cables
Dec 08, 2007 | Sony JACK, HEADPHONE Computer Speakers
Right speaker malfunction
try blowing the headphone jack hole. One hard puff should do the job
Nov 01, 2007 | Logitech X-230 Computer Speakers
Intel D865GSA (BOXD865GSAL) Motherboard Logo
27 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
