Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Macine trips breaker between steps 2 and 3
By moving knob 2 or 3 notches program carries on
    Genius:
  • 1,036 Answers
It sounds like either the heating element is faulty (needing replacement) or the main motor is worn-out and needs replacement.
The only way to tell is to see which part is working correctly.
Posted on May 02, 2010
At end of washing machine fast spin the machine trips my electricity circuit and TV switches off along with other appliances. Can you tell me what's wrong with machine?
This tells me that you do not have an overload situation. There is a short, and/or one or more faulty breakers possibly including the main breaker.
Even an experienced DIY'er with electrical knowledge would probably contact an electrician at this point. If there is a potential problem with the main breaker then it is best to get professional help.
Why is my electric circuit breaker tripping
Common Causes for Tripped Circuit Breakers
Why Does My Circuit Breaker Keep Tripping
Jul 02, 2015 | Washing Machines
GE Profile JT912 keep tripping circuit breaker
see this steps and fix it. God bless you
. Top element
If the element only works partially or not getting red hot at the "Hi" setting, the problem might be with a burned out receptacle that the element plugs into. If this is the case, replace both the element and the receptacle.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
2. Infinite switch
Another reason, why the element would not start, might be a defective infinite switch (located behind the control panel, with the burner knob on its shaft). Replace the switch if found defective.
Read more: http://www.appliancepartspros.com/repair-help/rangeoven-repair-help.html#2-2#ixzz2aSmUeYiW
Jul 29, 2013 | GE Profile JT912 Electric Single Oven
My Hoover Duros (blue color, S3000 something model with the power brush) worked fine for 3 years, than it died. The other day I couldn't turn it on... What can it be? A fuse? Where's is the fist in...
manual > http://hoover.com/file/682/
To reset the breaker:
(1) Push the ON/OFF switch
http://hoover.com/file/682/completely
down. You will feel some
resistance when the switch moves
downward. The switch will also move
slightly upward on its own.
(2) Wait one minute.
(3) Repeat step 1.
(4) Turn the cleaner ON and continue
cleaning.
If the brushes continue to stall and
the breaker trips again, clean the
brushes to remove debris. (Figs. 4-1
through 4-4)
To reset the breaker:(1) Push the ON/OFF switch
completely
down. You will feel someresistance when the switch movesdownward. The switch will also moveslightly upward on its own.(2) Wait one minute.(3) Repeat step 1.(4) Turn the cleaner ON and continuecleaning.If the brushes continue to stall andthe breaker trips again, clean thebrushes to remove debris. (Figs. 4-1through 4-4)
Jul 28, 2013 | Vacuums
I have a Whirlpool LER4634PQ1 it was working just fine then all of a sudden the dryer just keeps running the knob on the dryer doesn't move and the air isn't warm. Any suggestions on what to s
there is a cycling thermostat in line with the high limit thermostat and timer circuit,on timed dry its disabled and the timer will run no matter what,on any sensor dry setting it uses the heat of the element to heat this cycling thermostat to move the timer as the clothes get drier as the heating element heats the timer doesn't move,when the heater cycles off from the high limit thermostat then timer moves again,you need to find out if its a bad heating element,thermal fuse or possibly even a circuit breaker in the homes electrical panel tripped out on one of the 2 phases that gives you the 240 volts required to operate the dryer element,the breaker may not show its tripped,so shut it off and back on and try this first
Dec 11, 2012 | Whirlpool Dryers
Model 4001-ov trips the circuit breaker.
Assuming you have Paragon 4001 40 amp 120Volt timer
By-pass the timer so only pool pump is connected to breaker.
To do this, move wire from terminal 2 and connect to terminal 1.
If breaker no longer trips, then replace timer with Intermatic T101
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Crossover wiring: Paragon terminal 1 goes to Intermatic terminal 1.
Paragon terminal 2 to Intermatic terminal 2.
Paragon terminal 3 to Intermatic terminal A
If breaker keeps tripping after bypassing timer, then tighten wires on circuit breaker and test again.
If breaker keeps tripping, then move wires to another same-size breaker.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Breakers trip when they sense overheating.
If motor is causing problem, you might need electrician to track down source of overheating.
Jun 19, 2012 | Paragon 4001-0G Defrost Timer
Powerstar 115 tankless tripping reset ontop of #2 heat chamber #1 does not get overly warm mainly because of incoming water temp. but #2 seems to be heating after water flow stops to hot to touch and...
I don't have specific suggestion for tankless tripping breaker or if that is a circuit breaker problem or a tankless problem.
1) Move wires to another same-size breaker and see if problem persists.
2) Compare amp draw on tankless label with wire size and breaker size amp rating.
For example 30 amp breaker using 10ga wire is rated for 80% of listed amps or 24 amps.
3) If you are drawing full 30 amps, then 30 amp breaker is getting hot. Breaker trips with heat. Older breakers can trip more easily.
4) Before calling service technician, open following link for Bosch troubleshooting steps.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
5) Be sure to read manual for yearly maintenance requirements.
6) Add a tempering tank for incoming cold water problem.
http://waterheatertimer.org/Tempering-tank.html
7) All gas tankless brands can be repaired by homeowner for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Apr 22, 2011 | Bosch PowerStar AE115 Tankless Water...
Breaker installed on generator. Keeps tripping under no load after approx. 1 minute of generator running
A tripping circuit breaker is an indication of an overload. You say there is no load on the breaker - how are you making this determination? Are you using an amprobe or some other meter?
A circuit breaker with NO load shouldn't ever trip. Likewise a circuit breaker carrying up to 80% of of the current it is rated for shouldn't trip either. Circuit breakers that carry more than 80% of their load will trip - if the load remains connected long enough. This is called "duty factor" or "service factor" The greater the load is in excess of 80%, the less time that the breaker will carry it before tripping.
An example of a 100 amp breaker with different loads on it (this 100 amp value was chosen for ease of doing the math):
80 amps - never trips
85 amps - trips after 48 hours
90 amps - trips after 16 hours
95 amps - trips after 8 hours
100 amps - trips after 4 hours
105 amps - trips after a few minutes
120 amps - trips after a few seconds
150 amps - trips instantly
This is only an example to show how a certain circuit breaker might trip under a load less than the rating stamped on the body or handle.
A circuit breaker that trips with no load or a load equal to or less than 80% of its rating is most likely defective. You need an amprobe or ammeter for amp readings. If the load is found to be 80% or less, there may be an issue of harmonics that is causing the tripping. You'll need to have special equipment and qualified persons to check harmonic problems. Most harmonic problems occur when the loads are not linear device (transformers). Examples of non-linear devices are "switching" (or solid state) power supplies like those in computers.
I hope this helps and good luck. Please rate my reply. Thank you.
Apr 07, 2011 | GE Tjk436f000 3pole 400a 600vac Circuit...
Whirlpool electric solid element range model RS677PXV. The oven does not seem to heat over 250 degrees. What is the possible fix?
1. Pull the oven temperatre control knob straight off. 2. Loosen the locking screw. (note the position of the notches) 3. To raise the tempature, move the tooth a notch closer to HI. Each notch equals about 10F (5C). (Tighten the locking screw and replace the control knob.
If this doesnt increase the temperature of your oven you may need to look replacing the heating element.
Hope this helps.
Feb 13, 2011 | Whirlpool Kitchen Ranges
No hot water
You posted under Rheem 40 gallon electric water heater, which is two-element 240Volt heater.
If this is not your heater, add a comment.
If you suddenly have no hot water, that narrows the suspect list.
Step1:
Check for tripped circuit breaker.
Open top cover on water heater and push in reset button on upper thermostat.
If reset button is tripped out, and will not push back in, then replace upper thermostat.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Put ear against tank and listen for bubbly-fizzing sound that says heater is ON.
If reset is not tripped, then move to step 2
Step 2: use tester or multi-meter and test across top two screws on upper thermostat for 240Volt.
If heater is not getting 240V, then test circuit breaker.
Move water heater wires from 240V breaker to another same-amp 240V breaker and see if that restores power.
You may need to replace breaker:
If problem persists, then you might have a line problem between breaker and water heater.
Open cover on top of heater, and check connections on top of heater.
Step 3:
If heater is getting 240V, then upper thermostat or upper element is bad.
I suggest 30 minute troubleshooting which could save you a service call, and will be valuable information in the future:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 08, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My ge stove is dead. control panel is out, burners and oven will not turn on
The circuit breaker probably tripped. Usually it will be a 2 pole 40 or 50 amp breaker. Turn it all the way OFF, then back ON. Sometimes it's not easy to visually tell if a breaker has tripped, so do it anyway. If that doen't solve the problem post back please.
Dec 18, 2010 | General Electric Stove/Oven/Range Chrome...
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
167 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
