Question about DeLonghi DCR902T Coffee Maker
How to stop the digital clock blinking?
How to stop the digital clock from blinking? When I set the clock the colons between hours and minutes won't stop blinking.
How to set the clock Model NN-SA651S
To set the clock, press Timer/Clock twice when the microwave is not in use. The colon between the hour and minutes should start to blink. Type the current time (12-hour clock) with the appropriate number key pads. To save the time and exit the clock set mode, press Timer/Clock once more. Note: if you take too long to begin typing the time, the microwave may exit the time set mode. In that case, the colon will stop blinking. None of the other features of the microwave will work when the colon is blinking.
This is shown on page 11 of the manual which is available on the Panasonic NN-SA651S support page: http://shop.panasonic.com/support-only/NN-SA651S.html . The direct link to the manual is currently ftp://ftp.panasonic.com/microwaveoven/om/nn-sa631_nn-sa651_nn-sa661_en_om.pdf .
I hope this helps.
Mar 16, 2018 | Microwave Ovens
The colon between the numbers on the clock, example 8:00 won't stop blinking even after I set the clock and hit the clock button again.
Sometimes the correct procedure for setting the clock is to press the CLOCK or TIME OF DAY button, then enter the time on the keyboard, then press the START button instead.
Otherwise, as long as you can enter a cooking time and your oven operates normally, then don't worry about it. On some models it is normal for the colon on the clock display to blink all the time.
Good luck.
May 11, 2011 | Microwave Ovens
How do i change the time on my '99 pontiac sunfire?
Setting the Clock for AM-FM Stereo
Press SET. Within five seconds, press and hold the SEEK down arrow until the correct hour appears on the display. Press and hold the SEEK up arrow until the correct minute appears on the display.
Setting the Clock for All Systems Except AM-FM Stereo
Press and hold HR until the correct hour appears. Press and hold MIN until the correct minute appears. There will be a two-second delay before the clock goes into time-set mode, and the colon on the display will blink while in this mode.
If this is helpful, pleas rate this answer well.
Aug 05, 2010 | 1999 Pontiac Sunfire
Operation manual is lost, how do I set the clock?
The manual for the Magic Chef MCD1311ST Microwave can be downloaded in pdf format from the following site (follow the link then click the "Manuals" tab):
http://www.mcappliance.com/mwodetailpage.aspx?ModelName=MCD1311ST
If you don't have time to download, here's what the instructions state:
SETTING THE CLOCK
When the oven is first plugged in, the display will flash ":0" and a tone will sound. If the AC power ever goes off, the display shows ":0" when the power comes back on.
1. Touch CLOCK pad.
This is a 12 hour clock system.
2. Touch CLOCK pad once more.
This is a 24hour clock system.
NOTE: This oven has multiple clock system. If you want 12 hour clock system, omit this step.
3. Enter the correct time of day by touching the numbers in sequence.
4. Touch CLOCK pad.
The display stops blinking, and the colon start blinking. If you selected 12 hour clock system, this digital clock allows you to set from 1:00 to 12:59. If you selected 24 hour clock system, this digital clock allows you to set from 0:00 to 23:59.
5. Touch STOP/CLEAR pad.
NOTE: If you attempt to enter an incorrect time, the time will not be set and a error signal tone will sound. Touch the CLOCK pad and re-enter the time.
Jun 28, 2010 | Magic Chef MCD1311ST Microwave Oven
Set hourly chime
Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524. You will find manual for your watch there.
Apr 29, 2010 | Timex Ironman 53151 Wrist Watch
Hold the hours or minutes button down on the clock display for several seconds until you see the numbers or colon (:) blink. Press the button until you get the correct hours and minutes respectively. Once you ahev the correct time, it will return to the normal display with the adjusted time
Feb 28, 2010 | 1992 Buick LeSabre
Blinking dots
The blinking colon indicates seconds are being counted. It is a normal display function.
Feb 05, 2018 | Averatec Computers & Internet
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
NOTES:
- To reset the present time in the display window when the oven is off, press the CLOCK button and
reset.
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Emerson MW8107WA Microwave Oven
I have an Emerson Microwave Oven MW8997W and cannot change the hour (time) on my clock. How do I change the clock? Debbie
If your keys do not work at all, you probably have a bad keypad, in which case I'd ask you to reply back. In the meantime:
SETTING THE CLOCK
show the present time. After the clock has been set,
the time will appear with blinking colon, unless
You can actually download your owner's manual here
Mar 10, 2008 | Microwave Ovens
DeLonghi DCR902T Coffee Maker Logo
680 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
