Question about Husqvarna Chain Saw Handle Models 181 281 288xp
Not starting getting to much fuel - Husqvarna Chain Saw Handle Models 181 281 288xp
    Brigadier General:
  • 4,088 Answers
Likely, the carburetor lower chamber fuel-control metering-valve is bad or the diaphragm that controls the valve is hard/cracked. Either will need to be replaced. Hope this helps!
Posted on May 05, 2010
1992 F350-7.3 4wheel drive is hard to start after changing fuel filter and fuel pump. Why is it hard to start?
indicates fuel leak back and fuel pressure drop
check filter installation for seal not sitting properly, loose fuel line fitting , pump installed correctly (flow wise ), filter installed correctly (flow wise)
air getting in to fuel lines
the thing you are looking for is indicated by the initial hard start but when started runs ok ( good fuel to the engine eventually) and then by the fact that if the engine is allowed to sit for a long period the problem returns meaning that the fuel pressure is not being held
could even be a problem fuel pressure regulator allowing the fuel to bypass ( no pressure =hard starting) then gets enough pressure to run ok but allows that pressure to drain off over time
Oct 29, 2016 | 1992 Ford F350
Saw wont start, getting fuel and spark
Try starting it with the air filter removed. If it starts, clean the air filter. It could also be the fuel filter. If you replaced all the fuel lines, make sure you didn't get the oil line mixed up with a fuel line
Jan 25, 2015 | Poulan Garden
Fuel Open Question 2000 Camaro fuel pump/ fuel
is the gas tank vent recirculate hose clogged?
bad gas cap?
Aug 17, 2013 | 2000 Chevrolet Camaro
Starting troubles
it sounds like its not getting enough fuel on the first try! check all in fuel system. fuel pressure regulator, fuel filter, and fuel pressure if need be. also make sure fuel pump is ok. but you said after it starts its fine. so check all in fuel system, because fuel is not getting to engine on the first try.
Apr 10, 2012 | BMW Cars & Trucks
99 Durango will not start. It is getting fuel and spark. Poured small amount of fuel in trottle body and it will start, and then die when that fuel runs out.
If you have to put fuel in the throttle body to get it to start then its not getting fuel from the gas tank, a clogged fuel filter can cause this problem as can a failing fuel pump or pump relay.
May 29, 2011 | Dodge Durango Cars & Trucks
Engine not getting gasoline
CHECK TO SEE IF YOU HERE THE FUEL PUMP START AFTER YOU TURN THE KEY ON. FUEL PUNP, FILTER, FULE PUMP RELAY.
Apr 29, 2009 | Pontiac LeMans Cars & Trucks
Car turns over but won't start
It sound as though you are not getting any fuel. Check to see if you are getting fuel. If it is not getting fuel replace fuel filter,check for blown fuse. If still no fuel replace fuel pump.
Aug 28, 2008 | 2003 Oldsmobile Alero
Husqvarna Chain Saw Handle  Models 181 281 288xp Logo
81 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
