Question about Maytag MES5770 Electric Kitchen Range
This is a flat top electric range, Maytag mes5770aaq
This is a flat top electric range, the large burner only comes on high no matter what you set the dial to, low, medium whatever. It only comes on high.
Any ideas?
jsrock516
  • 5911 Answers
SOURCE: Burners not working on a Maytag Electric Range
The top of the range will open if you remove the three screws under the front edge of the top. You will need to open the oven door to see them. But first, unplug the range or turn of the circuit breaker. There's still live voltages (240VAC) even with the range turned off. Also use care not to lean on the oven door or you could damage the springs. If the top does not have any brackets to hold it up you may need to find something to prop it up, or use a second set of hands. The elements are easily removed by removing a couple of screws and the some wires. Write down the wire colors and where they go to assist in making sure you reconnect them correctly. Also, pay particular attention to the numbered holes on the back of the element. Make sure you reconnect the retaining brackets in the same numbered holes as you removed them. Last of all, do not handle the ceramic material or element coil with your bare hands. They are fragile and the oils from your hands could create hot spots and potentially ruin the element. I do not know the arrangement of your elements, but I suspect you have one of each size burned out. The part numbers are as follows: 6" element: 1032743 9" element: 1035285 The prices are about the same ($40 ea.) with the larger element costing slightly more. I hope this helps you.
Posted on Sep 03, 2007
ngafm
  • 166 Answers
SOURCE: maytag gas range
Peace,
ngafm here at your service,
Try turning off the power and after a few minutes restarting an it should reset the system.
Bless you,
ngafm
Please give me a good rating in at this site before you sign off!
Thank You
Posted on Sep 05, 2008
  • 86 Answers
SOURCE: Whirlpool Electric Range coil element gets red hot at low setting
Hi, Your problem is with the regulator switch! This is just a simple replacement of the switch unit. The tricky part is getting it to pieces to install the new one. If you can send me the model i might be able to assist you with taking it apart....
Get back to me if you need any further help......
Posted on Jan 02, 2009
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
Kgt1962
  • 59 Answers
SOURCE: viking range - gas flame on one burner does not change
It sounds like the repair man was correct. The only variable is the valve, if the rest of the burners are fine then it will be the valve
Posted on Mar 09, 2009
Dual top burner will only heat up on high.It is only the large ring burner GE JBP79
Does it go straight to full heat even though it is on the low setting. If this is the case the hotplate controller is faulty and requires replacement.
Feb 24, 2011 | GE Spectra JBP78 Electric Kitchen Range
I have a Kenmore Electric Range (Model C970-629934) and one of the large burners only works as high heat - doesn't matter if I set at low the burner gets blazing hot??
This is usually the infinite switch has failed. They are easy to check and inexpensive. Here is a video that will walk you thru testing an infinite switch. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Nov 18, 2010 | Kenmore Kitchen Ranges
Right large burner cooks on high no matter what setting.
This is usually the infinite switch has failed. They are easy to check and inexpensive. There is a video at http://appliancehelponline.com/infiniteswitchvideo.html that will walk you thru testing this. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Jun 08, 2010 | Hotpoint RB787BHBB Electric Kitchen Range
Hello My gemini top burners cycle on and off,
The burners are designed to cycle on and off, it is technology that helps to keep from burning food. If you are using the correct pan to burner size ratio and high setting on your burner, the water should boil in the normal time. Don't watch the pot (just kidding)
Nov 30, 2009 | Maytag Gemini 30" Self-Cleaning...
Electric stovetop gets VERY hot
LIFT TOP FROM FRONT ABOVE OVEN DOOR. TURN OFF POWER BEFORE SEVICING.
Oct 20, 2009 | Maytag MER5775Q Electric Kitchen Range
Problems with Maytag MER6772 Gemini Electric Kitchen Range
may tag gives 5yer worenty if not still under worant get rid of it
Apr 05, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Schott Ceran cooktop on Maytag range
try clr from a local supermarket.it comes in a green plastic bottle.wipe the burner generously but not soaking wet with it and turn the burner on the lowest setting.then use a metal scouring pad and LIGHTLY scour the burner.
Aug 11, 2007 | Maytag MER5775Q Electric Kitchen Range
Open Questions:
See all Maytag MES5770 Electric Kitchen Range Questions
Maytag MES5770 Electric Kitchen Range Logo
144 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
