Question about Hotpoint 24 in. DWF33 Built-in Dishwasher
Dishwasher is getting slow to clean
My dishwasher is taking a long time to clean its loads....
Please can you give me an answer for this problem..
  • 185 Answers
Check the timer
Posted on Mar 25, 2008
SOURCE:
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Smelly dishwasher and slow cycle
The fact your machine gives off an odour and a slow cycle seems to point to a blocked pump, Disconnect the machine from the main power supply, Remove the back and you will find the pump located at the bottom of the machine, Remove the large hose by squeezing together the retaining clip and you should find it is clogged. Clean all filters within the machine and it should clear the odour and help the machine to run better.
May 04, 2012 | Bosch 24 in. SHX46A05UC Built-In...
It does not get dishes clean even after running it few times and pre rinsing before loading into dishwasher.and does not smell clean when open door after cycle done
Hi psycho_child,
Please look at my Tip below, I believe you need to clean the bottom filter, as described in it:
DISHWASHER NOT CLEANING WELL....
Kind Regards
JEDEMEYER1
* If this solution helped you at all, please rate it
Jul 21, 2011 | Dishwashers
Top rack of dishwasher does not clean well
Hello, Thank You for using FixYa. I will be helping you today.Depending on your model some have a clean-out in the pump. Try looking up your model to see. If there is buildup it will slow the wash pressure.Also try running a bottle of dishwasher cleaner through it.
Thank You and please rate my answer if it was helpful..
Jun 15, 2011 | Dishwashers
Dishwasher will not drain water in tub get error message oe
The filter is probably blocked.
It is inside the base of the machine.
Take out the filter and clean it and also clean out the filter well as that can also hold quite a bit of debris.
Please dont forget to vote this answer was helpful
Many thanks
Feb 13, 2011 | LG LDS4821WW 24 in. Built-in Dishwasher
Ok so i play modern warfare 2 all the time.. and now when ever i go to multiplayer it takes like 4 secs. to load up the screen but it absolutly will not load now please help me!!
Hi elchambers11
Have you used all of your internet downloads up this can slow down your connection speed..Or mayb the server is running slow and you have alot of lag which is causing you very slow loading time...Cheers nikki
Please rate my answer.Thanks for using FixYa.
Jan 15, 2011 | Sony Playstation 3 (PS3) Console
Any game frezees after update 3.4, games just became so slow with lost of sound, slow load, etc. I cant play Oblivion or assasins creed 2, they are so slow and freezes constantly, help please whats...
yeah im having the same problem, i assume its to do with the new 3.41 patch people have said they can't even upgrade their hdd's anymore sony will probably fix this with a patch, i have a 500gb ps3 load times ont he xmb are slow takes longer than it did, best answer i can give you is the new patch is the problem, not your system or model so dont worry once sony figures it out then we can all breathe better
Jul 06, 2010 | Sony Playstation 3 (PS3) Console
Lower spray arm needs to be cleaned out.How do i take 0ff?
jocRDFAN43,
They do make a dishwasher cleaner that you can buy for about 5.00 and it cleans your dishwasher and also helps get rid of stains too!
This may solve you sprayer problem easier!
try it first with no dishes in the machine
bless you
huuum
please give me a good rating before you sign off
Sep 12, 2008 | Maytag MDB6000 Dishwasher
Top dishes don't come clean
Dear friend,
ngfam at you service! happy to assist!
Go into the user manual and read how to properly load your dishes to get the maximum cleaning potential!
there are certain ways to load the dishwasher that allows the spry to hit all the dishes.
Second check the bottom of the dishwasher if there are food particles left on the bottom at the end of the wash!
They can be the problem if they are recirculating back onto the dishes and then drying on them when the dry cycle goes on!
Third, They sell for about 5 to 8 dollars a small box of dishwasher
cleaner that you ad and run with no dishes in it 2 times a year!
And last, there may be a problem withe the drain or pump that its not pumping out all the wash water!
If this is the case you need service to check it out before some one in your family gets violently ill..!
We sell appliances for 65 years and I recommend this nation wide Factory repair service to all my retail customers!!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 29, 2008 | GE 24 in. Profile PDW7800 Built-in...
Hotpoint 24 in. DWF33 Built-in Dishwasher Logo
144 people viewed this question
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
