Question about PNY 4GB USB 2.0 Flash Drive - Grey/Black
TRANSFERING INFO ON TO MEMORY STICK
WHEN I PLUG THE PNY 4 GBUSB2 FLASHDRIVE NOTHING HAPPENS SO IT MEANS I CAN NOT TRANSFER DOCUMENTS WHAT DO I NEED TO DO THANKS
  • 5,184 Answers
First you need to figure out what is wrong. Is the USB drive bad, the ports not responding or what?
If the drive works on another computer, then we check the computer. 1) Are the ports turned off for power savings (look for the Screen Saver, then the Advanced settings)) or security (check the device manager in Windows). Check that the right drivers are loaded. If auto-run is disabled for USB ports, a similar effect can be seen. Check if the drive shows up in the File Explorer. Try different ports on the computer and see if the connection is tight (if the drive wiggles in the port, good contact is missing).
I hope this helps.
(if the drive doesn't work in any computer, it may have failed. If it is under warranty, you can get it replaced. However getting the data off it will not be covered by the warranty.)
Posted on May 02, 2010
Can I use my PNY 2G on my tablet and what it will do ? Ihave a Acer tablet Android
Most tablets dont have the option to plug in an external USB stick. Your best option to transfer data is to either plug them directly into a computer or use email.
Dec 29, 2014 | PNY 2GB NEW ATTACHE USB FL DR
Is it ok if my PNY 16GB flash drive is flashing red but working fine?
You should first read the documentation to see exactly what the flashing read light means. It could mean that the drive is near full capacity. Try removing/transferring a few files to your hard drive to see if the flahing read stops. As long as it works ok, I wouldn't be too concerned.
Jun 24, 2014 | PNY Attach? 16GB USB 2.0 Flash Drive
I NEED TO TRANSFER THINGS FROM ONE COMPUTER TO A NEW COMPUTER I DON'T WANT TO MOVE EVERYTHING JUST CERTAIN THINGS LIKE MY PICTURES AND DIFFERENT DOCUMENTS THAT I DO NOT WANT TO LOOSE
Hi sks846
Create a new folder in the old computer , rename it ( " old computer documents " or whatever you wish ) and copy your selected files to it . Copy the completed folder to your flash drive . Disconnect the flashdrive and connect it to the new computer . Copy the content to the new computer . Copy of your documents are now saved on both the flash drive and the new computer . You are now 100 % safe . If necessary , the originals can be found back on the old computer .
Best regards ,
fanaudi .
Aug 07, 2011 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Hi I purchase the PNY 8G and my son told me a short cut of how to use transfer items out of my recycle bin to my USB but I forgot can someone please tell me once I plug it into my laptop what are the steps...
if you need to save something from the recycle bin the you need to go into recycle bin right click on the file and click restore which will move it back to where it was when you deleted it then you can just drag it into your memory stick
May 30, 2011 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
I bought a 4 gb PNY flash drive and i used it to transfer music from one computer to another. after dragging the music to my itunes i deleted all the files on the flash drive. i went back to transfer more...
Plug in the drive -go to my computer and find it right click and go properties - look for folder options -choose show hidden folders -- you will probably find a folder called( trash) delete it and you should get your space back
Apr 13, 2011 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
How do I download pictures from photo gallery in windows vista to a memory stick
First, you need to connect the memory stick into the computer. Make sure that the computer could detect it.
Next, open the "Computer" icon on your Desktop and see what is the drive letter assigned to the memory stick (i.e. E: F: G:).
Then go to the photo gallery, right-click the picture > Send To > select the drive letter.
The picture should be transferred to the memory stick after that.
ANOTHER WAY:
1. Double-click the drive letter that's assigned to the memory stick and a window should come up.
2. Go to the photo gallery > right-click the picture > copy
3. Open the window for the memory > right-click the window > paste.
The picture should be transferred.
ANOTHER WAY:
Just simply drag and drop the pictures to the memory window.
Nov 11, 2009 | PNY 2GB microSD Memory Card
Error on flashdrive
format the USB once then transfer the data
Oct 14, 2009 | Electronics - Others
I have a pny 4gb usb 2.0 flash drive black.instructions needed.
Most USB drives are "plug n play" meaning you just plug it in to a USB 2 port and your operating system will recognize it as a drive. If you're using Windows ME/XP/Vista, just plug it into a USB 2 port and once its recognized you'll be able to send files and folders directly to it by right clicking the file or folder and moving your mouse over SEND TO and selecting the drive from the list.
Nov 18, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
PNY 4GB USB 2.0 Flash Drive - Grey/Black Logo
97 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
