Question about Canon PIXMA iP90 Mobile Printer
Getting Waste Ink Asborber is Full message, What do Ineed to do to fix it?
  • Canon Master
  • 5,127 Answers
The waste ink absorbers are usually small pads at the bottom of the printer. You need to pull them. This is usually messy and can require basically taking apart the printer. Then either replace (contact a service center) or rinse clean the pads (just running water works). Once the pads are dry (if reusing them), reinstall them.
Then reset the counter:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Do not do the reset until the ink absorber is cleaned. The waste ink will get everywhere in the printer and the pages you print.
I hope this helps.
(most ink jets are really designed to be replaced if the waste ink absorber is full - the other parts may soon fail too.)
Posted on May 02, 2010
How do I undo unable to clean 46 message
This error is for the Waste Ink Station.
The Waste Ink Station is full. This requires a full dismantle of the machine to clean out and then a reset process run to clear the waste ink counter.
Sep 09, 2014 | Brother MFC-790CW Multifunction Printer
Getting a false error message that the ink/toner is empty and wastebin is full when i print to my phaser 8860 from a macbook on 10.6 (networked printer)
The waste bin full error can occur if the waste bin was not removed from the machine for over 10 seconds when it was emptied. Please remove the waste bin and wait for a full 10 to 20 seconds before replacing the Waste bin.
If the message still displays turn off the machine and leave it off for 1 minute then turn the machine back on.
Then run software update to make sure you have the latest OS updates.
Then delete the printer and re-add the printer.
Aug 04, 2011 | Xerox Phaser 8860MFP Printer
How do I fix the waste ink nearly full problem
Here you go:
http://www.fixyourownprinter.com/forums/printer/46473
Dec 07, 2009 | Canon i9100 InkJet Photo Printer
I have been getting the following message from my Canon iP90 portable printer: ''Waste Ink absorber is full'' What do I do to fix the problem? Harvey
If you peel apples, the apple-peel becomes "waste", and you put the waste into a bin. When the bin is full, you have to do something, i.e., empty the bin into a composter, or send the bin to the land-fill, or you get another bin.
Similarly, when your printer "wastes" ink, the ink is retained inside the printer, until the waste-absorber unit becomes full.
Take the printer to a qualified technician, to either "empty" the bin, or to "replace" the bin.
Nov 13, 2009 | Canon PIXMA iP90 Mobile Printer
At first I was getting the message to check the ink waste and then I got the message the ink waste tank is full and now it reads check printer 5600. what does it mean and what do I do, toss it in the...
Waste ink amount
setting
EEPROM settings)
- At logic board replacement To set the waste ink amount to the
waste ink counter.
None.
Perform in the
service mode.
1min
Oct 11, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Stopped printing after 'waste ink full message' how to I fix it.
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 20, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Waste ink asborber i almost full... how do I fix
I am providing you with a link that will provide you with everything you could possibly need as the owner of this printer. This link on Canon's Web site will give you access to user guides/manual, driver and software downloads, support, specs for the system and much, much more.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=10442
This link will take you directly to the Support & Service tab on the Canon Pixma MP130 page.
(If not, simply click the tab labeled Support & Service).
Type "waste ink absorber" in the text box then click Search.
Click 1. ERROR LCD: WASTE INK NEAR FULL which will result in 4 solutions to this problem:
  • Ink absorber replacement options - mp130
  • Press ON/OFF switch to reset the multifunction device
  • The mp130 may require repair
Try 1 and 2 first. You must click on the solution to view the details.
This should also be helpful in the future event that you may need to download drivers or access the manual to troubleshoot/fix an issue. Drivers and Guides can be downloaded from the Drivers & Software tab.
Hope this helps! Share your experience by rating this solution.
Thanks for using Fixya!
Mar 28, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink absorber on canon iP 1600
Try reading THIS .
Hope that fixed ya...
Geno
Apr 04, 2008 | Office Equipment & Supplies
u have to clean it mannualy by opening it. if u r not expert give the printer to qualified proffesional
Apr 01, 2008 | Office Equipment & Supplies
Canon PIXMA iP90 Mobile Printer Logo
208 people viewed this question
old marine
old marine
