Question about Dishwashers
I have the same groaning noise with my dish washer GSD2200G02WW
I have the same groaning noise as reported by some one else earlier, during the early part of the wash cycle with my dish washer GE model GSD2200G02WW;
Could any body help with this by providing any reasons and solutions?
    Genius:
  • 1,036 Answers
Remove both spray arms, and try a cycle with the washer empty.
If the noise changes or dissapears - replace one spray arm and try again. Replace the spray arm that creates the noise.
If there is no change, then replace the drain pump.
Posted on May 02, 2010
Rear end groan
similar problems occur with Subaru AWD systems, the problem might be the centre diff, or a rubbing mudflap, or you have put the wrong aspect ratio tyres on and the drive system is complaining.
Jan 25, 2014 | 2004 Jeep Grand Cherokee
Makes noise during wash cicles and dishes are not cleaned
Hi Kenneth Cho - I will suggest verifying that there is enough water pressure coming into the unit. Is the unit making a grinding noise? If it is, then the dishwasher seems to have a defective drain motor. When was the last time the filter was cleaned? Do you noticed if the spray arm will rotate freely or if it is damaged? If so, you might have to remove and replace the spray arm assemblies. If any proves to be ineffective, it could possibly have a communication problem coming from the main control board, I would suggest contacting a professional technician to diagnose the unit accurately.
Nov 24, 2012 | Frigidaire FGHD2433KF Builtin Dishwasher
My washer makes a groaning noise when spinning. any advice on what the problem might be?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Jan 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Power overload swith in the house has started tripping when the dishwasher is started
Is this happening only now! If it was working OK earlier and tripping now only it may be due to some electrical fault inside the machine.
Switch off all the high power appliances and try the dish washer. If it works you have to check the breaker overall power rating!
If it trips during dish washer ON, the fault could be in the heater circuit of your machine. Heater Insulation would have become weak etc.
May 17, 2010 | Dishwashers
COLD WATER IS RUNNING SLOW INTO WASHER. THERE IS PLENTY OF FLOW IN THE HOSE AND NO KINKS AND THE SCREEN IS CLEAN. HOT WATER FLOW IS FINE. WASHING MACHINE MAKES A GROANING NOISE WHEN COLD WATER IS ENTERING.
Based on your description, the selenoid is bad.
The same device feeds both cold and hot water - so locate your machine model number and year.. and look up the replacement incoming water selenoid part number. You will need to purchase it and replace it.
If your machine is under warranty, call their Customer Service line and report the water flow/noise problem.
Please let us know your findings...
-Jim
Oct 17, 2009 | Washing Machines
Noise
Check if ADEQUATE water is present during the wash. (open the door and observe the level midway in the wash)
Also verify water is coming in for the rinse. Problem here only would likely be with the timer.
Check that the spray bar is free to rotate. Too high a load can keep bar from turning.
Sep 22, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Noise during wash and rinse cycles
Got a response from another site - the noise was due to the recirculation pump (situated low down at the back on the other side from the drain hose) which was working, but clogged with a nasty grey 'porridge' of limescale and powder residue in the pipes either side of it. Dismantled, cleaned out pipes and ran a wash cycle to clear any remaining crud out. Seems ok now and wash jet working, noise gone.
Mar 28, 2008 | Zanussi WJD1457W Front Load Washer / Dryer
Groaning noise in Maytag 4000 washer
yea probly passed warr from manu , if its rear bearing issue gonna run alot ot fix BIG JOB!
Feb 23, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Dishwashers Logo
314 people viewed this question
Top Dishwashers Experts
