Question about Oster 6330 4-Slice Toaster
The button will not stay down on the toaster. I have the toaster taken apart but the button is not mechanical as I expected. The toaster still works if you hold down the button manually but the blue lights (selections) do not work. I'm wondering if the transformer part number S.T XB8226 might be bad? I just do not know how to test or troubleshoot. Our toaster has been good to us and I would like to fix it. Any help would be appreciated. Thanks, Ron
3 Suggested Answers
  • 30 Answers
SOURCE: Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Posted on Aug 05, 2009
mc1bean
  • 3053 Answers
SOURCE: toaster lever does not stay down, heating elements
Hello, csle
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about toasters andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances1.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
Toaster sticks in down position and won't shut off until pushed up. Seems to be gummy in there but I can't figure out how to get to the mechanism to clean it. Any ideas?
The name of the game is to remove the outer cover so you can while the unit is unplugged observe the mechanism and locate the area that is full of gunk and jamming it up. If absolutely no screws anywhere then unit has snap on parts and you have to pull them apart.
It was put together by man - it can be taken apart.
Aug 06, 2015 | Kitchen Appliances - Others
Lever won't stay down. Have removed all screws and could take off top but handle on lever prevents this. How do I remove the end of the lever in order to get the top off to check latching mechanism?
My toaster turned out to have an electromagnet that makes its lever and the toast carriage stay down. It turned out that the problem with my toaster was that it was plugged into a faulty outlet. Unfortunately, I destroyed part of my toaster's darkness mechanism trying to understand its latching mechanism before I realized that it was not made like traditional toasters. So my first recommendation to you: try plugging it into an outlet that you KNOW works.
Feb 13, 2015 | Kitchen Appliances - Others
Handel wil not stay down the model no. is 24559 32
Go to the Hamiton Beach website to see if your series has been recalled. I have same model, can't get base off and found recall notice looking for help. My series wasn't but yours might be. Good luck, might get a new toaster!
Oct 23, 2013 | Hamilton Beach Kitchen Appliances - Others
The lever button does not stay down,so the toaster does not come on. Even if I hold the lever button down,the toaster does not come on.The toaster is cleaned on a regulas basis.
My toaster did the same thing. I cleaned the contacts on the mechanical switch with emery cloth and that problem was solved. Now I'm trying to figure out how to stop the breaker points on the mechanical switch from arcing - which I assume caused the problem in the first place.
Jun 26, 2011 | KitchenAid KTT340 2-Slice Toaster
Toaster latch does not stay down on Cusinart CPT-120 compact two slice toaster
for Cuisinart cpt160: If the latch will not stay down it is because the electromagnet at the base of the toaster, which is supposed to activate when you push the handle down, is burnt out. I pulled my toaster apart and did a test of that mechanism and found that the solenoid was fried (open circuit). There are no replacement parts.
Jan 09, 2011 | Cuisinart CPT-160 Metal Classic 2-Slice...
6331 will not stay down
I have the 4-slice oster, but I bet the control mechanism is the same. When you take it apart you will see a small steel bar held by two plastic fingers. When you push the lever down the steel bar moves down and contacts a small square electromagnet. The electromagnet holds the lever down during toasting and releases the lever when done. On mine there was a compressed layer of bread crumbs covering the electromagnet. Cleaned it off and now it works again.
To take the toaster apart, pull the down lever straight out and then unfasten the screws on the bottom base (5 on mine) and pull the top off carefully. There are wires connecting the control face to the base, but they have enough slack to let you separate the top/bottom and access the mechanism.
Nov 24, 2009 | Oster 6307 / 6309 2-Slice Toaster
Aug 04, 2009 | Kitchen Appliances - Others
Toaster will not stay down in toast position
uh, don't think there's a good chance, you could try to send toaster in for repair, but buying a new toaster is probably cheaper.
Nov 24, 2008 | Back to Basics TEM-500 Egg & Muffin...
Bread won't toast
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down.
My husband took the cover off and found that a magnet is what keeps the lever down when the toaster's on, and allows it to go back up when the toasting is done. It's an electro magnet that works only when the toaster is on. It seems that when I turned the unit upside down and rightside up again, crumbs landed on the magnet's contact plates (which are about 1/4" x 1/2") and would not allow the magnet to engage. Because the magnet wouldn't engage, the lever would not stay down, and the toaster shut off. Brush off the magnets, replace the cover and toast away!
Dec 27, 2007 | Kitchen Appliances - Others
Toaster lever
I have sunbeam model AGW toaster level is not staying down and no power. the spring work, i want to know what part hold it down. please help or there any repair company i can take it (s. california) thanks
Dec 17, 2007 | Kenmore KTES4 4-Slice Toaster
Oster 6330 4-Slice Toaster Logo
124 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
