Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
I have a old 87 ranger boat with factory wiring
I have a old 87 ranger 374v boat with factory wiring for the trolling motor. I have a motorguide f67 trolling motor . There are 4 wires in the rear compartment of the boat, both negative wires run straight to the front of the boat from each battery. The 2 positive wires go to 2 circuit breakers (replaced) in the rear, and then connect to the 2 hot wires going to the front. The motor works on 12v, but when I switch it to 24v on the foot pedal, it doesn't work. I replaced the switch 12/24 switch on the foot pedal, still doesn't work on 24 volt. What am I doing wrong, or is it just time for a new one.Thanks
5 Suggested Answers
SOURCE: wanting to install motorguide 24v trolling motor
I have installed a selectable 12/24 volt trolling motor on my boat. When in the 24 volt mode, the motor works well for about 3-4 minutes the loses all power. After about a 15-20 minute "cooling off period" the motor will work again for about 3-4 minutes. In the 12 volt mode, the motor works well all the time, only at about half the speed of the 24 volt mode. Why is my motor losing all power in the 24 volt mode?
Posted on Mar 30, 2010
  • 6 Answers
It should but may not run at it's intended potential. It may also run your battery down a lot quicker.
Posted on May 18, 2010
SOURCE: Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Posted on Sep 16, 2011
SOURCE: Wire going to prop of Motorguide trolling motor shorted
Unless you are mechanically inclined, dont attempt this. Take the lower unit apart by removing the prop and removing the two bolts that hold the forward and aft housing to the center housing. Fwd being the cone shaped part. Pull the aft housing away from the motor so you can inspect the connections to the board that holds the brushes and the soldered wiring terminals. You should find the solder missing from at least one of the terminals that connects the wiring from the foot switch to the speed control windings inside the aft housing. Clean up the terminal and wiring and re-solder. Also re-flow the solder on the other terminals. Clean up the seals and the area where the seals meet the housing parts. Replace seals if damaged. Reassemble the lower unit and torque the bolts 45-50 in-lbs and no more otherwise you will fail the seals. This problem is due to a "cold" solder joint that creates a high resistance to elec current flow and heats enough to melt the solder. This is a result of poor quality control at the manufacturer. Good luck.
Posted on Dec 29, 2011
My motorguide x15 trolling motorjust wants to spin around .. it has a remote foot control
Define 'wants to spin around'?
The propeller motor is supposed to spin around :>)
If the whole motor unit is spinning around you need to clamp the motor stem.
For factory support, you can get that from the website.
Xi5 Trolling Motor Xi5 Wireless Trolling Motor MotorGuide
Jul 19, 2016 | MotorGuide FW71 FB Freshwater Series...
24 volt trolling motor (motorguide) not working. Have 24 volts at receptacle in hull of boat but when I plug in the trolling motor and check the volts on the plug, I only read 6 volts. Any idea whats...
You have a high resistance short either inside the wiring or the lower unit. This will cause a voltage drop. I would be very careful not to keep it connected too long cuz the battery is trying to keep up with the current demand and may explode.
Oct 03, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
Need a relay for a MotorGuide Stealth 200 troll motor - part VF4-899F11
I have a Motorguide Stealth 200B trolling motor, works perfect but getting a new boat with a new motor. Trolling motor has original manual and paperwork with it, as well as 4 blade Ninja prop and prop wrench. Has some cosmetic scratches on motor. looking for $25.00
Feb 12, 2011 | MotorGuide Standard Motor Replacement...
I have a motorguide electric motor model # st 200 made in 1991 it is a perfect trolling motor but gears #1 &#2 are gone.This a superb little motor for fishing just the right speed on small lakes.I'm...
How about selling your friend's old Motor to me for some $ . I don't care about the "gone gears" as I 'am converting a gas Brushwacker 37.7cc, to a boat motor. Charles Craver 336 254 9276 quietus.charles@gmail.com.
Aug 27, 2010 | MotorGuide Standard Motor Replacement...
Motorguide t47 powerplus trolling motor
t 47 power plus motorguide prop wont turn but you can feel the power going to motor to try to turn it
Jul 06, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Wanting to install motorguide 24v trolling motor in boat will it work on just 12 v system
May 13, 2010 | Electrical Supplies
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
280 people viewed this question
Top MotorGuide Electrical Supplies Experts
Craig Butler
Craig Butler
Ian Summerfield
Ian Summerfield
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
