Question about Brother CS-6000
Stitches not catching with zigzag stich only one side catches.
I am trying to applique,but my machine is only making a line.
How do you adjust the tension on the bobbin?
Posted on Jul 06, 2010
What is the best stich to use when sewing a large round patch on my daughter's GI?
Use an applique stitch, which is a zigzag stitch set on a very short stitch length
Mar 02, 2017 | Singer Sewing Machines
My brother LS-2125 will not do zigzag stitch needle moves from side to side but only does occasionally zigzag
If you are saying the needle zig-zags but the upper thread is not catching the bobbin thread every stitch, then it could be a timing issue.
Jul 08, 2016 | Brother Sewing Machines
How to adjust tension janome 4400
Before you go changing settings... make sure you are stabilizing the fabric correctly. Towels especially requires a stabilizer on top AND on bottom.
Dec 06, 2012 | Janome MC 4400 Computerized Sewing Machine
Zigzag stitch not catching
try these suggestions and see if they help
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Oct 19, 2012 | Brother CS6000i Computerized Sewing...
Stitches not forming correctly
the material may not be thick enough to make a correct stich, you might try interfacing with the single layer of material & see if that helps
Mar 05, 2012 | Kenmore Sewing Machines
When buying a sewing machine that has blind hemming feature .what does this mean./
it means there is a foot included that will straight-stitch a certain number of stitches then do a zigzag stitch to the left that will catch the fold of the fabric at intervals. The fold is made at the width of the hem you want. When you finish and straighten the hem out, the hem stitches will barely be visible on the top side unlike straight-stitching across the top of the fabric. There will be a "hem stitch" option on the machine and the foot will possibly have a movable guide that runs along the fold of the fabric to where your zigzag "catching the folded fabric" stitch is consistent.
Mar 21, 2011 | Sewing Machines
Elna SU missing stiches and breaking thread
it sounds like the needle hook timing is out. You need to get the needle in the lowest position and measure the gap from the needle to the hook point on the bobbin shuttle. It should be 1/4". You will need to remove the foot and foot plate to be able to see. I use a 1/4" drill bit as a gauge. If you need to adjust it, you will need to remove the free arm cover to the right of the foot and loosen the 2 allen head screws that hold the drive gear. Adjust the gap, tighten the screws and retry. Usually if the needle catches the thread to early, it will make a bad stitch and the upper thread will break. If it catches to late, it will make thread loops and the machine will skip stitches. Good luck, these are a good machine and worth fixing. Phil
Oct 27, 2008 | Elna 1010
Necchi automatic BU supernova sewing machine
Hello! Hello!
Your machine is probably not 50 years old. I have one just like it that we purchased about 5 years ago. Necchi makes a very sturdy reliable machine. There are a couple of tricks, though. First, your bobbin thread has to turn clockwise. If it doesn't, it will either not sew, the stitch will look horrible or the thread will break. Second, threading it is pretty easy; however, I can't explain some of the parts. I would be happy to scan the diagram and e-mail it to you. E-mail: daridoll@yahoo.com. The tension should be set at 3 unless you are doing a ruffle or close zigzagging (machine applique). For applique, I find that I have to move it to 2. For ruffles or gathering, set it at 0 and your stitch width to 4. Another trick is to hold the top thread for the first 2 stitches. This alleviates a bobbin catch at the beginning. Other things you will want to know are in regard to the two knobs. One is pretty simple. It has a line that gradually increases in a zigzag. This knob basically adjusts the width of the zig zag. Obviously, for straight stitching, you would make sure the straight line is towards the top. The other knob determines the type of stitch you want to do. The red stitch options on top of the machine can be done with #1, 2, 3, 4 or 5 at the top; however, I usually use #1. The blue stitches are really fun! Simply decide which stich you want and make sure the corresponding number on the dial is turned towards the top. Also, it is very important that you adjust the other knob to the largest zigzag possible AND change the stitch length to 4. Don't pull on the fabric from behind the machine as you are sewing, because the machine will go forward and backwards while making many of these stitches. The green A, B, C on the dial are used for the automatic buttonhole feature. In order to use this, make sure you have the button hole foot. It looks like a long rectangular piece of plastic with measurements on it and hollow in the center. Not sure if that description makes sense. Anyway, the first step is "C." Make sure you begin with the button hole pressure foot measuring "0". Also, change your zigzag width to the desired width AND change the stitch length to less than 1. (You will notice that this area has a green line on it.) Begin stitching. You should be moving forward. When you have reached the desired length, make sure the needle is up, then turn the knob to "B" (sometimes I make my zigzag wider for this part), begin sewing. You should not go forward or backward. This step makes the bottom of the button hole. I only make 3 or 4 "B" stitches. When done, make sure the needle is up, adjust your zigzag back again if you changed it for B, and set it on "A". This will take you backwards. If you started your button hole with the foot on 0, it will automatically stop moving backwards when you reach 0 again. At this point make sure your needle is up again, then set the knob on "B" once more. If you adjusted B before, do it again. There you are! You can use twin needles on this machine. It also works well with a walking foot for quilting. Oh! To wind your bobbin (starting from the thread spool) you need to slide the thread under the little metal knob sticking out on top of the metal "?" right above the tension and then insert it into the hole in the bobbin spool. Push the bobbin to the right. This locks it into place. Next, hold the outer part of the flywheel (round wheel on right side of machine) while turning the inner wheel towards you. This will disengage the needle and allow the bobbin to wind. Now you can press on the "gas" and wa-laah. It will slow down and almost stop when it is completed. Cut your thread, slide the bobbin to the left to unlock, tighten the wheel and you're done. If you have any more questions, let me know. Hope this helps!
Jul 27, 2008 | Necchi 3537 Mechanical Sewing Machine
Brother CS-6000 Logo
127 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
