Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Hotpoint built in dishwasher
Does not drain at end of full cycle
    Genius:
  • 1,036 Answers
I would replace the drain pump as a first attempt at a fix. They're only around £15, and wear out first.
Posted on May 02, 2010
Water not draining after last cycle
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
May 13, 2010 | Hotpoint 24 in. HDA3740G Built-in...
Dishwasher not draining. full of water after
You will have to lay the dishwasher on its back to access the PUMP
Jan 09, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Hotpoint BF162............. Water left, not draining
Open the bottom panel of the washer and see if it is full of water, if it is drain it away and clean all of the filters inside the washer and reset.
Mar 04, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint dishwasher model BFI62
water leaking into base of machine. tip dishwasher back and drain out water. then check all seals intact, i.e. around arms, around salt holder etc
Dec 23, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint sdw dishwasher
It is possible drain pump blocked, you need to empty d/washer manually, check inside drain pump which is at end of drain hose, always isolate d/washer from power before attempting any work on it.
Aug 14, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Does not drain
take the front cover off and have a bucket and towels ready ,, remove the hose clamp off the drain line and remove it slowly to keep up with the water that will seep out of the line after it stops draining run water theu the drain and flush the system the take the hose off and run water thru it ,, out side,, then check if it goes into an air gap clear both sides of the air gap and all hoses,, if after doing all of this and it still won't drain, you will need to change the pump
Feb 26, 2008 | Hotpoint 24 in. HDA3400G Built-in...
Hotpoint Superplus 7822 dishwasher
At the beginning of the cycle the dishwasher is attempting to pump out any residue water in the waste pipe and sump. It could be that the motor is sticking but you would probably also suffer from it not draining properly.
It may just be noisy pump. I have a similar model and it is also quite noisy but nothing extraordinary.
When the dishwasher is pumping out at the end of the washing cycle it may be quieter when there is water in the pump/pipes but then gets noisy as it 'pumps air'.
Jan 29, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Drainage problem
cycle switch on the front is most likely bad
Jan 09, 2008 | Hotpoint 24 in. HDA3740G Built-in...
Check your air gap on your kitchen sink. If equipped, you will most likely find it clogged. Pull off the metal cap, then unscrew the white or clear cap. You should find your clog there. Replace both caps and remember to pre-rinse the dishes better before loading.
Oct 01, 2007 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Cycle doesn't finish
Its the timer you need a new one they arent hard to get just ring up your local apliance man and tell him (or her) you model number and brand and he will order it and fit it for you
May 30, 2006 | Hotpoint 24 in. HDA1000Z Built-in...
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
50 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
