Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
I have a LG dishwasher that starts , switches off after 5 min on
I have a LG dishwasher that starts , nothing wrong with pump, works for 5 mins and switches off. it does it on all the programs, please help!!
    Genius:
  • 1,036 Answers
Test to see if the machine is heating water. If not - replace the heating element, then the thermostat if still not heating.
If the heater is ok, then it is the control board at fault, requiring replacement or repair.
Posted on May 02, 2010
Set my dishwasher on the wrong program pressed the start button then change mind it was on the wrong setting switch of changed setting now will not start
Try throw the breaker off for 15 min then back on. That may clear the program. If not restart it on the "wrong" cycle and let it finish out.
Feb 19, 2015 | Whirlpool GU2400XTP Built-in Dishwasher
Sine updating my lg bh6220s it has started to switched itself after 5 min can anyone help please
I would have to guess that the internal power supply has one or more bad capacitors. Time to take into a technician for repairs.
Nov 11, 2014 | LG BH6220S 3D Home Cinema System LG
I have a ADP5000MT, when I start a cycle it begins but after 5 mins switches to the bottom option - the =30''V symbol button and keeps flashing .. I cant find my manual
CODES: The Express program light Keeps flashing quickly
MEANINGS: Longer inlet time
Possible Cause: Faucets is not opened, or water intake is restricted, or water pressure is to low.
Jan 16, 2013 | Whirlpool Dishwashers
LG DISHWASHER LEAKING WITH E1 ERROR CODE.
Hi phtanner,
The E1 error can be fixed by following my Tip below:
L.G DISHWASHER E1 ERROR...
Follow these directions, and the problem will be fixed.
Kind Regards :-)
* If this solution helped you, please rate it.
Jul 28, 2011 | LG 24 in. LDF 7811 Stainless Steel...
In the middle of washing it shows 0E and shuts off. I open and closed the door it start working and does the same thing and middle of washing again. What is wrong?
Hi, it is a Drain Error OE
Which means it is not fully drained out in spite of 5 min. drain operation
The Drain Hose kinked or blocked. The drain outlet of sump is blocked. The Drain Pump/Motor or circuit is troubled.
Remove the cause of kink or block. Check the wiring connection. Measure the electric resistance of Drain Motor. (20-40 ) Replace the Drain Motor or repair the Circuit.
Jun 22, 2011 | LG LDF6810ST Stainless Steel Built-in...
Set dishwasher to start - sounds as if it starts but then 5 mins later beeps. When door is opened nothing has happened and instead of the i.e. P4 programme displayed E1 is displayed? Can you help on what...
Possible that there are no outputs from the program controller unit and so you will need to check with a multimeter the voltage to the inlet valve/motor while the washer starts. If there is no supply then the controller is faulty , if not check the inlet valve and the pumps for fault.
Make sure that the door switch is working as unless the switch latches the program controller will not work- safety feature.
Feb 14, 2011 | Smeg DWI614 Built-in Dishwasher
My LG dishwasher stops running 5 mins in
The LE code means there is a problem with the washer motor. ( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.
Remedy: Correct wiring connections. Replace the cause of restriction. Replace the washing motor. Replace the PCB.
May 02, 2009 | LG Dishwashers
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
181 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
