Question about Aiwa Audio Players & Recorders
I have apair of sx-wna909 and don't know which wire
I have apair of sx-wna909 speakers and no schematic so i don't know which wire DOES WHAT, each speaker have two wire pairs coming out.
  • guitardanno
    guitardanno Jul 08, 2013
    I too have a pair of these speakers and am unsure how to wire them
dsom
  • 56 Answers
SOURCE: Cabling car speakers as home speakers (is it really that stupid?)
If you wire the speakers as a pair in parallel; (For two 4ohms car speakers) 1/R=1/4 + 1/4 1/R=2/4=1/2 R=2 ohms (the resistance value you'll get) (don't even think of trying it!) in serial; R=4+4 R=8 ohms (this mostly fits to home amplifiers, however, they provide 6ohms as well) I recommend that you use reasonable 8ohms speakers for the home theater amplifier you have. Despite the fact that the impedance value fits to 8ohms when you wire two car speakers as a pair in serial, this type of connection will tire your amp as well as the capacitors of the car speakers. Furthermore, you can get unwanted peak sounds from car speakers.
Posted on Apr 26, 2007
thesoundman
  • 41 Answers
SOURCE: aftermarket 6 x 9's
What type of car is it? You can purchase speaker harnesses at any car audio shop that will allow you to snap into the factory plugs. Also, beware if your system was designed for 8 ohm speakers - using 4ohm speakers instead could cause some problems. Most aftermarket stereos are designed for 4ohm speakers, but some factory stereos designed for 8ohms could be damaged if you give them a smaller ohm load.
Posted on Sep 21, 2007
  • 14 Answers
SOURCE: Rear deck speaker install
I'm assuming that you have left the original wiring intact? If this is the case then it's a pretty simple thing to do. There should only be 2 cables one for each speaker & each cable will have a positive & negative polarity. Once you have securely fixed the speakers into place (usually screwing into place through the mounting holes provided) you just need to attach the wires to the speakers. If your car has manufacturers plugs on & don't match the speaker ones (quite often the case now) simply cut them off & replace with spade connectors of the right type/size. The most important thing is to get the polarity the same way round for both speakers!If you get them reversed you will NOT get any bass. Also remember with any new speakers they need time to run in & sound their best....so take it easy with the volume control for the first 20hrs or so of play if you want them to sound great & last longer!
Posted on Dec 28, 2007
TJBENGR
  • 121 Answers
SOURCE: Tweeters & Midrange Speakers
If you have a Ohm Meter, check the resistance to the speakers. If it is very high, the speakers are burned, (or the crossover is (just capacitors, and resisters...cheap)). If it is close to 4 ohms check the wiring and connectors..to and at the speakers, most likly the receiver/amp is not blown.
Posted on Apr 20, 2008
SOURCE: speaker wiring
hi mat
you should have four terminals two plain and two with dots
to get the best power cut two inches off good speker wire
tear apart now place one wire from
plan black to red with white dot then
plain red to black with white dot
this is how set then up with my directed 1100d mono amp .. very loud at half gain
well hope this helps.............. ..benjaminsarmy..
Posted on Mar 23, 2009
Does anyone know the wiring schematics to the factory radio in a 1999 Avalon XLS with the 7 speaker system
Only the electric wiring diagram has 360 pages. Impossible to post anything of that here. Sorry
Mar 13, 2015 | 1999 Toyota Avalon
How do I hook up a powered subwoofer to a pioneer sx-316?
Many subwoofers accept both line level (RCA jacks) and amplified inputs (+ and - speaker terminals). The Pioneer SX-316 does not offer line level output, only amplified outputs via the PURPLE + and - speaker terminals. This means that in order to use any subwoofer with an SX-316, the sub woofer will need to accept a + and - speaker wire connections for input Your manual speaker connections are on page 11 of the manual which can be found here: http://www.manualslib.com/manual/260358/Pioneer-Sx-316-S.html#manual
Starting at the rear of the SX-316; run a speaker wire from the PURPLE + and - terminal (SUBWOOFER) to the + and - speaker input terminals on the subwoofer. See your subwoofer manual or experiment (at your own risk) with connecting the speaker wire from the SX-316 to the subwoofer's + and - LEFT only, RIGHT only or BOTH left and right speaker inputs. Do not connect wires from the SX-316 to the speaker OUTPUT terminals of your subwoofer.
Finally, adjust any variable low pass filter knob or setting on the subwoofer to the lowest frequency that your main speakers are capable of producing. If you're not sure what that value is, try setting the subwoofer to 100Hz and judge how it blends with the main speakers. If it seems a little too bass heavy and thick then reduce the setting to 80Hz. On the other hand, if the sound seems to be slightly thin and lacking weight, try increasing the setting to 120Hz. By careful listening and a bit of patience you will be able to get the sound to seem balanced and well blended.
Apr 06, 2014 | Audio Players & Recorders
Aiwa speaker system model no sx-wna909 2 sets of wires coming out speaker which is which
This is a dual voice coil setup. You can use a two channel amp (stereo) or connect them in series to a mono amp.
Mar 31, 2014 | Audio Players & Recorders
Pioneer SX-315 Speaker Problem
The bump may have broken or disconnected speaker wires.
May 17, 2017 | Pioneer SX-315
When a type some wods, apairs others words o letters
First check the printwheel for bent or broken spokes. Try it with the correction tape out they get loose and tangle in the P/W.
DickyO
Oct 31, 2012 | Brother SX-4000 Electronic Typewriter
Trying to hook up the receiver to pre-wired speakers in master bath and bedroom and deck outside house. The wiring consist of 2 cables that break off into 4 wires (black,white,green & red). Not sure...
Well get yourself a digital volt/ohmmeter and trace them out. Plus and minus are not absolute. Just don't touch one to the other with power on. Reversal of them on a given speaker only changes its phasing. Web search: speaker phase test
With no attachment to any electronics - short the pair at one destination together ONLY for this test. Go back to the source end and use the ohmmeter to see which two conductors they represent. Mark them. Disconnect the short. Repeat for other speakers.
Sep 03, 2011 | Pioneer SX-255R Receiver
I am trying to hook the speakers to the audio. I
the gray marked wire is positive one.
rate the solution...
Oct 09, 2009 | Pioneer SX-315
Need apair passive crossover for pair of maxp64 600 watts
You can easily make one yourself. All you need are two non-polar capacitors of about 1 Farad each. Radio Shack and any respectable electronic component store have them. For a high pass filter (AKA crossover) connect in series with the speaker wires. For low pass operation like a sub-woofer, use it in parallel with the speaker.
Oct 02, 2009 | Car Audio & Video
Is this amp safe at mid to low volumes with a pair of polk Lsi15s
Hi there. This should work for you. Use only one speaker per side.
Thanks
Paul
Jul 11, 2009 | Audio Players & Recorders
My pioneer sx-315 audio reciever turns on for a few seconds and then automatically shuts off... Is there something wrong with the power supply? Does anyone have a schematic?
The problem you are having is the unit is going into protect.
You can try disconnecting all the speakers and then see if it turns on. If it does turn on you may only have a bad speaker.
Then just turn the unit off and plug in one speaker at a time. If it still turns on, that speaker is good. Keep doing this with each speaker until it goes into protect again, and then you know the last speaker plugged in is the bad one. Make sure you turn it off after checking each speaker.
If it still goes into protect with all speakers disconnected you most likely have a problem in the amplifier circuit.
I have the complete service manual in PDF format with parts list and schematics, but it cost $10.00
Let me know if you want to purchase it and I will give you instructions for that. I can give you a direct download link after purchase using PayPal.
If you would like any further help just let me know.
Dave
Jun 27, 2008 | Audio Players & Recorders
302 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
