Question about Maytag Neptune MDG5500AW Gas Dryer
Inside tumbler is loose - how do you tighten - Maytag Neptune MDG5500AW Gas Dryer
    Novelist:
  • 145 Answers
If the tumbler is loose and you can move it from side to side the bearings in the rear of the drum may be going bad. The bearings aren't an expensive part, the job is just time consuming because you need to remove the outer casing of the dryer and take the drum out. The sides of the dryer stay together the front should come straight off and if the top doesn't come straight off it will tip back on hinges so the wires stay intact. You may need two people to replace the bearings once you get the drum off because they are generally screwed in from inside the drum.
Posted on May 02, 2010
Inside the drum one of the tumblers is loose how do you tighten it up?
You can tighten those baffles by getting to outside of drum to thighten the screws that hold them to drum. to get access to outside of drum;
Remove screws from door hinge
remove screws from other side of inside door as they are exaclty opposite the ones for hinges
pull off from panel by putting putty knife/screwdriver in seam between front panel/cabinet just below the sloped part of the top and pop off front panel
in the upper corners of the top/front panel is a clip that looks likea inverted "7" or if ya will a up side down "L" remove screws from the clips and remove the clip
now ya can raise top to get to outside of drum
rotate drum by hand in CLOCKWISE direction to turn drum so ya can get to each baffle
Thanks for using FixYa.com,
Gene
Aug 22, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Fin that tumbles clothing inside dryer coming loose, how can I tighten it?
These fins are usually screwed on from the outside of the drum. If you're up to it this is a simple but time consuming fix. Take the cabinet off the front of the dryer, the top will come off as well. be careful of the wires from the control console, they will stay attached to the dryer. Tighten the tumbler fins on the drum and then re-assemble the cabinet. Typically the screws you need to access are the same used for the door latch and hinges. They go back together easy ........
Feb 14, 2011 | Maytag Neptune MDE7500AY Electric Dryer
I have a Kenmore dryer. The fins are real loose, make alot of noise, catch socks, etc. How can I fix it.?
If the first three digits of the model number are "110." remove the lint filter from the top and remove the two exposed screws. Then you can insert a putty knife or similar tool into the gap between the front panel and top, about 2-1/2 inches in from the sides, and push in on the retaining clips. While pushing on a clip, simultaneously lift on that corresponding top corner, and the top will release to swing up.
This will expose the outside of the tumbler. As you spin the tumbler, each spot where a baffle is attached will come into view. After making sure there are no items inside the baffles (coins, pins, etc.), tighten the holding screws.
Dec 30, 2010 | Kenmore Dryers
Tumblers inside drum are loose need to take top or rear off and i can not fined manul
This service manual will show how to release the top lid and tighten the drum vanes.
http://136.166.4.200/contents/Laundry/DLG2524/DLG2524_Service_Manual.pdf
Apr 18, 2010 | LG DLG5932W Gas Dryer
Short baffle is loose
You can pop the top with a drywall putty knife there is two tabs on each side. This will allow you to access the drum. Then tighten the screws holding the baffle in place.
Jan 22, 2010 | Maytag Dryers
One of the "fins" inside the drum has become loose. It hasn't come off, it's just loose...how can I fix it? Thank you!!
hoping it is a neptune.........
remove the screws on the door hing to cabinet
and the two opposite
lift and remove the door
once the door is off
you can pull the front panel off
grab the thin sides and twist in and pull
onvce tat panal is off you will see two 5/16 screws on each side
remove those
you should be able to lift the top
once you do you should be able to see the top of the tumbler
turn till the loose fin is on top and just tighten the screws back out and your good to go
Oct 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Rattle inside dryer drum
remove the front cover and then you can access the top cover screws to open top then you can locate and tighten screws
Jul 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Tumbling bar is loose and getting looser
youll need to lift the top of the unit, and and form there youll gain acees to the outside of the drum assembly, the "tumbler bars" are secured by 5/16 screws from the outside ofthe drum assy
Feb 12, 2009 | Maytag MDG7600AW Gas Dryer
A tumbler fin
This isn't much help, but those fins will break off. I have had them break off. I am ordering some new ones, called "baffles" and will be installing them. I hope I can the top open on the machine.
Jun 16, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
146 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
