Question about Karcher Garden
Karcher pressure washer motor buzzes when switched on but does not run - help !
I am no electrician but open black plastic case and check capacitor .If it does not show burnt signs then smell it to see if its burnt.It could be a number of other things if it is not a capacitor.
remember to short the terminals on the capacitor with an insulated screwdriver . a capacitor sort of acts like a battery and can sometimes store a nasty charge .BE careful or have a sparky check it for u .They should not charge u much to do a 5 second test with a meter
Posted on Feb 10, 2011
Dealer list in zip 32162
Motor seized up! You can try turning it manually. If it moves freely then yes motor has burnt out! If it has resistance, try turning it until it moves freely then try to run the washer! Best of luck
Sep 25, 2014 | Karcher K3.49M 1,800 PSI 1.5 GPM Electric...
Karcher pressure washer doesn't work
it;s normally a switch interrupter must replace with actual with for motor protection.
Aug 14, 2014 | Karcher Garden
My karcher k7.85 has lost pressure and the motor runs constantly when switched on ,motor only used to run when trigger pulled in on lance ,there is no leaks. Can any one help please.
Sounds like the pump seals are bad. The manual says to only use these a few minutes at a time, most people try to clean the patio etc with them, run them too long, and burn out the pump seals - don't ask me how I know this.
Feb 17, 2014 | Karcher Garden
Karcher pressure washer 620m motor only runs with switch held down but will not water pressur is the same as tap pressure out the nozzle
it is not uncommon that the switch is bad? if the switch controls the pressure telling it their is water and to start working? then i would just replace the switch.
Dec 17, 2013 | Karcher Garden
Karcher K2.94 intermittent pumping and buzzing
try the machine with the lance removed from the gun.
buzzing is usually the noise made by the motor when it cant turn. if the pump start to pruduce pressure but the pressure builds up too high then the motor will stop turning... faulty lance or faulty spill valve (dump valve)
If you have a Karcher then you should always post your machines barcode.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 05, 2013 | Garden
Karcher K2.36 Pressure Washer I've just fired up my Karcher for the first time since last year and the motor started running fine, I then switched on the tap to allow the water through and the motor cut...
The water must be switched on, and seen to be running freely from the nozzle for a few seconds before switching on the power - suggest you check the fuse in the plug, and then try the above.
Apr 17, 2010 | Karcher K2.26 Electric Power Washer
Karcher K2.36 motor cut out and won't restart
Yes, the water should be turned on first but if it only ran for a minute or two it should be OK. Most late model pressure washers have an automatic shutoff when the trigger on the wand is released. Turn on the water and then the machine and then squeeze the trigger on the handle of the wand and the motor should start as soon as the air is cleared from the line by the flowing water (about 10 seconds). If the unit was put away wet last season you may need to clean the nozzle with a piece of wire too.
Apr 16, 2010 | Karcher Garden
Karcher K2.91M nlets water in and out but won't
wot like a buzzing noise if so try and turn the fan at the rear of the motor if you can do this it is more than likley the capacitor
Dec 04, 2009 | Karcher K2.26 Electric Power Washer
Karcher k7.91 pressure washer /loss of pressure
if the motor will not turn on ,thers a problem with the current excess switch , which is situated under the main power on of swith hi needs to be replced
May 04, 2009 | Karcher PSI Electric Pressure Washer
My karcher hds 745 has started blowing fuses. it switches on the power light comes on and it makes a buzzing noise for about five seconds and then blows the mains 13amp fuse. i have replaced it twice but...
you have an electrical short in the motor windings. you'll have to either replace the motor or buy another washer. also check to see if the motor isn't locked up with a piece of trash. to do that you'll have to dissassemble housing until you get to the motor. it should turn easily by hand. if so you have a short.
Apr 19, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
426 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
