Sound is not coming from attached speakers I have window xp and ''zoltrixound'' speakers
    Scholar:
  • 53 Answers
There can be more than one reason, why the computer can’t play any sounds. These are discussed below:
So, where do you start, when you can’t hear any sounds from your computer?
Before we start with the solutions, did you try the simplest solution first? Reboot or restart the computer. The sounds may just work after a reboot.
Can you hear the Windows startup sounds from the computer? If you can hear the Windows startup sounds, the sound card is working fine. If you can’t hear any startup sounds, enable the System Sounds in the Control Panel, if they are disabled. If you aren’t able to enable the system sounds and they are grayed out, you may need to install the sound driver.
Are you trying to play an audio CD, and not getting any sound? If you can hear the System Sounds, but can’t hear anything from the audio CD, even though your audio player software tells that it’s playing the disc, the problem is most likely with the digital cable that goes from the CD/DVD driver to the sound card (or to the motherboard).
Are the speakers connected to the proper sound port / jack, at the back of the computer? Are they powered ON? External speakers generally have a separate power adapter, which plugs into the wall socket or any other power source. Is the speaker volume control, set to a comfortable level? If not, turn it to the middle position.
If in doubt, test your speakers by connecting them to another sound device like CD/DVD player or a radio/tape player, or any sound source. If you can hear sounds from the speakers, they are fine.
Check that the speaker pin is connected to the green jack on the back of the computer. Also, check that the sound (check speaker icon in the system tray) isn’t muted. Such a simple thing, which can happen accidentally, can confuse some people when they can’t hear sounds from their computers. This can get overlooked because the speaker icon may be lost between many other icons. Click it and un-mute the sound, if it’s muted.
Note: If you can’t see the speaker icon in the system tray, you may need to enable it from the Control Panel. From the Control Panel, double-click “Sound and Audio Devices” and check the box that says “Place volume icon in the taskbar” and click OK.
Try plugging in a pair of headphones in place of the speakers, to check whether you can hear anything. Play a song or music CD or any sound file, which you may have on the computer. If you don’t have one handy, you can run a command to test your sound:
Click the Start button, and then click Run (or Search, in Windows 7 / Vista). Type the following command and then press the Enter key: dxdiag
Click on the ‘Sound’ tab to see the details of your sound card. You can also test your sound card from this tab. Note the name of the sound card and the manufacturer, on a piece of paper.
If you can’t see the name of the sound driver, or aren’t able to hear the sound by using the ‘Test DirectSound’ button, or you get an error, the problem may be with the sound driver. If the sound worked sometime ago and now it isn’t working for some reason, the simplest solution for re-installing the sound driver is to do a System Restore. Restore the system to a date that you know, when your sound worked. Check out the following links for a short tutorial on System Restore
Note: Current documents, files and e-mail are not affected by System Restore. If you get an error like “Restoration Incomplete. Your computer cannot be restored“, undo the last action by selecting “Undo my last restoration”.
Here’s a youtube video on how to restore a system with System Restore: http://www.youtube.com/watch?v=mU5yqvye57E
Here are step-by-step tutorials on System Restore:
For Windows XP: http://www.howtogeek.com/howto/windows/using-system-restore-in-xp/ http://www.5starsupport.com/faq/xp-system-restore.htm
For Windows 7 or Vista: http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/ http://www.vistax64.com/tutorials/76905-system-restore-how.html
For more information about System Restore, visit the following links: http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/systemrestore.mspx http://support.microsoft.com/kb/306084http://en.wikipedia.org/wiki/System_Restore http://windows.microsoft.com/en-US/windows-vista/System-Restore-frequently-asked-questions
If System Restore didn’t help or you get a message that System Restore couldn’t be completed, try the following:
Start the Device Manager (Start -> Run -> devmgmt.msc and hit the Enter key). In Device Manager, Click the + sign next to “Sound, video and game controllers”. See that the sound driver that you noted from dxdiag above, is listed.
Doube-click this sound driver. Device Manager should give a status message that the driver is working fine. If the driver isn’t there or if it shows a yellow exclamation mark, shows under other devices, or gives any other kind of status message, reinstall the driver. In any case, it doesn’t harm to uninstall and reinstall the driver.
From this sound driver properties page, you may also click the Troubleshoot button, to open the Sound Troubleshooter in the Windows Help and Support Center.
You can also visit the following link about tips for fixing common sound problems:
http://windows.microsoft.com/en-US/windows-vista/Tips-for-fixing-common-sound-problems
Hope that helps,
Regards,
Raspal
For Windows XP Driver Files and How-to Resources, visit XPDrivers.
Posted on May 04, 2010
  • Raspal Seni May 04, 2010
    If your motherboard has built-in sound support, make sure that it’s enabled in the System BIOS/CMOS. However, if you have a separate sound card, and your motherboard’s built-in sound is also enabled in the BIOS/CMOS, there can be a conflict between the two sound cards. In this case, disable the built-in sound support from the BIOS/CMOS, if it’s not already disabled.
    Here’s a video on how to enter the System BIOS/CMOS:
    http://www.youtube.com/watch?v=VLaoajhiN...
    And here’s another one:
    http://www.youtube.com/watch?v=Tc1t3c5Yk...
    If your motherboard’s built-in sound isn’t working, even after re-installing the sound driver, doing a System Restore and re-installing Windows, you need to add a separate sound card. The easy option for non-technical people is to get a USB sound card. Such a card is also helpful, if your motherboard has no free expansion slots for an add-on sound card.
    What are USB Sound Cards? USB sound “cards” are actually external boxes that plug into the computer via USB. The sound is produced in the software which runs on the computer. These boxes only provide for connectivity from the pc via the USB bus to an external device like a microphone or line in/out connector. It’s more appropriate to call them as audio interfaces.
    Here’s an easy way to download and install/update your sound card driver:
    If you have a separate sound card, it’s also possible that the drivers are correctly installed, but the sound card was displaced a little bit from its slot, which caused a loose contact between the card and the slot.
    If you suspect this, you should open up the computer and pull out the card. Then, re-insert it firmly into the slot or insert it in another slot, if you have another one free. Make sure to tighten the screw, which fixes the card to the case, and put one there, if it’s missing. Here’s a youtube video about installing a sound card:
    If none of the above methods worked, open up the computer, pull out your sound card and test it in another computer. You can also download and boot from an Ubuntu Linux disc, just to test the card, in case you don’t have access to another computer. You’d need to burn the ISO file with the “burn image to disc” option, in your CD writing software. To know more, how to burn ISO files, visit these links:
    http://pcsupport.about.com/od/toolsofthe...
    http://www.petri.co.il/how_to_write_iso_...
    You can also try re-installing Windows.
    Here are some youtube videos about how to re-install Windows:
    For installing/reinstalling Windows XP: http://www.youtube.com/watch?v=P_932T4FA... http://www.youtube.com/watch?v=7usco-1nX...
    For installing/reinstalling Windows Vista: http://www.youtube.com/watch?v=VeBjxHm19... http://www.youtube.com/watch?v=puY4vRhAK...
    If you have to re-install Windows, you may want to backup any critical data files on to CD/DVD discs or USB flash drives/portable hard drives, before starting the installation.
    If you tested your sound card and it worked with another system, and you have Windows 7 on your computer, it’s most likely that Windows 7 doesn’t support your sound card yet. Here, you have two options – downgrade to Windows Vista or XP, or get another sound card which is supported by Windows 7.
    If the card didn’t work even with another system, try another sound card.
    If the card is a USB sound card, try connecting it to a different USB port, especially the ones at the back of the computer, if you tried only the front USB ports. If you can’t get the card to work, try it on another computer. If it works on the other computer, the problem may be with the USB ports on your computer.
    Test by connecting other USB devices. You may try removing the USB drivers from the Device manager and let Windows re-install them upon reboot. If your computer doesn’t recognize any USB device, try the solutions in “Troubleshooting USB connections”
    For more information, visit the following link:
    http://answers.microsoft.com/hi-in/defau...
My computer has windows xp on it and it plays system sounds but it tells me there is no sound device on it. How do i fix this free?
first u need to check that system sounds comes from your external speakers or internal speaker inside your cup box.if it comes from internal speaker then u need to install your sound driver . which is on the cd that came with your pc when u purchased it our u can download it from your system manufacturer's website if u have model number of your pc
Mar 19, 2011 | Microsoft Windows XP Home Edition
Installed windows xp pro now i got no sound coming out vof my speakers
You need a driver most likely. You can find the type of sound ard that you have by going doing a right click on "Your Computer" and selecting properties. After properties, select the hardware tab. On the hardware tab, select device manager. Select sound and see what type of card you have. You can then go to that providers site and download the correct driver.
Another possibility is that your speakers have become disconnected. Check to make sure that the wire is connected.
May 14, 2010 | Microsoft Windows XP Professional for PC
Connected to laptop with vista via USB connection to speakers - NO sound
A letter from Altec: E-mail from Altec Lansing explaining how to use the ACS 495 speakers with Windows XP and Vista: "These speakers require no special drivers or software to work properly. At the current time we do not have AMS software or an USB audio device driver compatible with Windows XP or Vista. There are no plans at this time to develop this software. Your speakers will work with Windows XP & Vista. Just make sure you use the audio cable from the back of the subwoofer to the audio or sound out port of your sound card. Do not use the USB cable. Sound does not come through the USB port The USB cable just allows you to use the AMS software. This software gives you some control over some of the sound features. The same functionality of the AMS software can be gotten by using the buttons on the speakers and the volume control software that comes with your Windows system. If you double click the speaker icon from the system tray, that will open this software up. With the USB connector removed or the computer turned off, STEREO or PRO LOGIC modes can be selected by depressing and holding the center control down for approximately three seconds. The mode selected will be indicated by the color of the LED on the front right speaker. When the light glows yellow it is in the STEREO mode. When the light is green it is in the PRO LOGIC mode."
Nov 09, 2009 | Altec Lansing ACS 495 Computer Speakers
Sound only playing out of one speaker in Windows XP
Go into Sound Settings under control panel. There should be a left-right audio control setting in there.
If that doesn't work, try updating the sound driver for your computer.
Jun 01, 2009 | Intel Motherboard
After using recovery disc for windows xp there is no sound
You need to update the sound drivers, Find out what sound card you are using and search the web for the drivers by either typing your motherboard model or your computer model. Use search functions to help you find what you are looking for. I hope this helps. You might want to provide more info on the devices attached to your motherboard. Use device manager for more info.
Mar 30, 2009 | HP Pavilion a705w PC Desktop
Sound Coming From BOTH SPEAKErs and headphones
Sound emanating from both the internal speakers and headphone/earphone while the later is engaged could mean a factory defect in your speaker device. Upgrading your OS from XP to Vista may not solve your problem. However, since the service center technician will probably insist on his diagnosis and recommendation, you may need to upgrade your OS just to prove your point.
Jan 25, 2009 | Broadcom BCM94306MP - IEEE 802.11b/g...
I had to reinstall my windows xp and my speakers are plugged in but no sound comes from them and my computer cant find them
If you are trying to re-install windows, you have to re-install the sound drivers also once the setup is complete.
You cannot hear any sound untill you install proper sound drivers.
Regards
Jan 17, 2009 | HP JBL Platinum Computer Speakers
Foxconn sound card drivers
same problem
I formatted my hard drive and reinstall windows xp but no sound comes from speakers I tried to install audio drivers from the motherboard CD "foxconn" but PCI driver can not be installed what should i do?
Apr 07, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
Speakers work for just a second when windows starts up
Try to uninstall the sound card, shut your pc off, take the sound card off, attach it again and turn on the pc. Then reinstall the drivers and see whether the same problem occurs or not.
Thanks,
Mary
Mar 31, 2008 | Dell A215 Computer Speakers
468 people viewed this question
 Grubhead
Grubhead
