Question about HP DeskJet 5550 InkJet Printer
Printer won't print
  1. hp deskjet 5550 won't print. cartridges on the left. fresh ink. middle and bottom lights flashing. uninstalled and reinstalled. what next?
  • Anonymous Apr 04, 2008
    Cartridge cradle stuck, green and orange light flashing.
    Removed cartridges, removed back of printer, unhooked all cables.
    Problem Solver:
  • 6 Answers
Did you peel the piece of paper on the ink cartridge?Or if that doesnt help do this get the cartridge out and then dip some water on the ink leaking part with a piece of paper and well see what will happen.
Posted on Apr 08, 2008
SOURCE:
I have hp deskjet 5550 printer,when i was trying to print a document there is no print out, two lights are blinking
Hi, This could be Low-Ink or paper Jam. Try turning off The printer, Unplug from The Mains Electric, for 3-5 Minutes. Turn back On, if Lights Are Still There. Check The Ink-Levels. And Replace Cartridges, if necessary.
Mike.
Jun 02, 2011 | HP DeskJet 5550 InkJet Printer
Tip
Bottom Two Lights Flashing
Was printing recently and paper tray ran empty. Then cartridges jammed to the right side and bottom two lights flashed continuously, in spite of disconnecting power, restart, etc. Finally, in attempt to change ink cartridges, pushed down on housing for ink cartridges and heard a click. They were jammed in the far right position. Restarted printer and all worked fine. Not very techy, but it worked!
on Jul 28, 2008 | HP DeskJet 5550 InkJet Printer
HP5550. Color ink ran out. Replaced with refilled cartridge, ink light still flashing. If I use an original cartridge this does not happen. Shop tells me cartidges are fine and proved it
some HP printers do this after a non original cartridge used The printer should still be able to operate even with the light flashing. If this does not work you may require to replace the print head.
Mar 21, 2011 | HP DeskJet 5550 InkJet Printer
HELP PLEASE
Remove one cartridge and close the access door. If the cartridge light goes off, the bad cartridge has been removed. If the light continues to blink, remove the other cartridge and reinstall the first one. If the light goes off, the cartridge in the printer is the good one.
May 31, 2010 | HP DeskJet 5550 InkJet Printer
Hp 5550 print cartridge light flashing.power light on,not flashin
All HP ink cartridges are dated. If you are using the remanufactured ones the date is not changed and will not work properly at all. By HP ink only and you will never run into this again.
Sep 03, 2009 | HP DeskJet 5550 InkJet Printer
Lights flashing, printer won't print as a result of a paper jam
Hi Girlemom. Just had the same problem here. Lift up the lid and slide the ink cartridges to the left. If they are stuck in the middle, this will prevent the printer from starting properly. Then, unplug it, plug back in, and turn on. It should restart normally.
May 08, 2009 | HP DeskJet 5550 InkJet Printer
Hp deskjet 5550-prints a ''hp deskjet 5550 Series'' page
Hi all of you
your problem sound as you have hanged Button, try clean it and refit it.
thanks,
Hamedo
Nov 19, 2008 | HP DeskJet 5550 InkJet Printer
My hpdeskjet 5550 printer is not printing. lights are flashing
Hi all of you ,
Since the cartridge drive not stop in center when open the to door, you have ffurther problem
try use the old one, if ok , clean your printer.
thanks
Hamedo
Nov 17, 2008 | HP DeskJet 5550 InkJet Printer
Can't find ink levels on my printer
I just had this same problem on my Deskjet 5550 printer. The orange light (ink indicator) was staying on. I found out that all you need to do is just open the front cover to the printer. If your printer is running out of ink, the print cradle will move to either the far left or far right side. If it moves to the far left side, the BLACK cartridge is low or empty and should be replaced. If the print cradle stays on the far right side, the COLOR cartridge should be replaced. Normally, when you open the front cover, the print cradle should move to the center. Hope this helps!
Aug 11, 2008 | HP DeskJet 5550 InkJet Printer
Help
1st page prints perfect but the 2nd page comes out with very light and skipped printing.
Oct 22, 2007 | HP DeskJet 5550 InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
181 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
