Question about Malibu Intermatic Inc. ML300RTW 300-Watt Power Pack with Timer and Ground S
Timer pegs I need timer pegs red and black were, can I buy them
  • Malibu Master
  • 5,245 Answers
SOURCE: Malibu light timer. I have 2 black and 2 red timer
red is on, black is off how can I get additional pegs to replace lost ones?
Posted on Dec 09, 2009
gotgeek2
  • 565 Answers
SOURCE: Where can I find timer peg replacements?
Scroll down a bit:
http://landscapelightingonline.com/low_voltage_accessories.html
Posted on Jun 02, 2010
gotgeek2
  • 565 Answers
SOURCE: looking for replacement pegs for my malibu timer
scroll down some on this page:
Posted on Jul 09, 2010
SOURCE: am replacing an old wall
I've tested these timers.
Here's what to do:
1) Connect green to bare copper
2) Switch has 2 wires. For now, connect these two wires to timer-black and timer-red. Choose either one.
3) In back of wall box are white neutral wires twisted together and covered with wire nut. Timer-white wire connects to these white neutral wires. This action gives power to time clock.
4) If wall box does not have white neutrals described above, then connect timer-white to bare ground wire. Bare ground connects to neutral busbar in breaker box.
5) Turn on power and click manual override button or switch. If lights turn on, timer is wired correctly. If lights do not turn on, then reverse timer-red and timer-black wires.
Posted on Nov 16, 2010
SOURCE: Need to set the timer properly. No instructions
Experiment with the timer.
Hook up the lights and timer. And read resource link below.
Put the trippers on the dial. Put red at 6pm and black at 6am.
Then manually rotate the dial two revolutions.
Turn the override knob to different setting, and then manually rotate the dial two revolutions.
Watch what the lights do as you rotate timer dial.
Then rotate dial two revolutions until current time lines up with stationary arrowhead located on inner dial.
The clock motor located inside timer rotates the dial, and trippers move small switch that turns lights on-and-off.
More resources with important tips for power pack:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
http://waterheatertimer.org/How-to-set-timers.html
Posted on Sep 27, 2011
Cannot get new digitical timer to work have 2 black wires in wall box but new timer has black, blue,green,red, and white
Red wire is used for 3-way only... cap off for single pole
White is neutral, black is hot, blue goes to load, green is ground
Copy following link for wiring your timer:
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
If box does NOT have white wires twisted together and covered with wire nut: then suggest to buy Ei600 or ST01 battery operated timer
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ST01C
Gene
Apr 18, 2014 | Intermatic Hardware & Accessories
Need to set the timer properly. No instructions to follow. Want lights to come on at 6PM and off at 6AM. the timer has red and black pegs on the timer, HEL:P
Sep 27, 2011 | Malibu ML88TL 88Watt Low Voltage Power...
Problem starting lighting
Are you sure the Peg is in the right way around? usually there is a short side and and a long side on the Pins?
May 21, 2010 | Intermatic & Malibu& 300 Watt Power/Pack...
Black Peg on timer
We just used to use a sliver of bamboo, just make a piece and sand it down, bit by bit, until it is a Tight fit in the hole you want about 5mm to protrude, through the bottom, that is what "Trips" the "Contacts" inside. So anything similar will work too. Just remember whatever you use, has to protrude a little bit inside the face of the Dial. & be strong enough, not to break when pushing the Contact.
Mar 28, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Have a new woods tn300 light timer. if lift the
Anywhere that pegs are pulled up is where the outlet is off if the pegs are down then the outlet is on. Hope that helps!
Jan 09, 2010 | Kitchen Appliances - Others
Just as someone else wrote, I too have the Malibu light timer and have the blue & red pegs set to turn on (red peg) at 7pm and off (black peg) at 11pm. The lights will not automatically turn on...I...
The clock motor has gotten weak and is now overheating, and will soon stop turning. There are no replacement clock motors for ML series power packs.
Open following for Power Pack troubleshoot checklist and warranty information and other tips to keep power pack working longer:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Nov 09, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
Malibu Intermatic Inc. ML300RTW  300-Watt Power Pack with Timer and Ground S Logo
301 people viewed this question
Top Malibu Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
