Question about Whirlpool Refrigerators
1981 refridgerator model eht 141ak
Need age of Whirlpool Refridgerator - 2 Dr Top Freezer
Model EHT 141AK
Serial S13716165
5 Suggested Answers
SOURCE: Refridgerator and freezer is no longer cold
evaporator freezer fan motor has low voltage. Amana M # SCD22NW S # 9403120669. Could use some help. Thanks
Posted on Apr 09, 2008
  • 51 Answers
SOURCE: water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Posted on Jan 09, 2009
SOURCE: maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Posted on Sep 05, 2009
TheMobilian
  • 8220 Answers
SOURCE: Refridgerator is warm, freezer is freezing
Defrost problem. Most likely the defrost heater or defrost thermostat.
Posted on Jul 02, 2010
Whirlpool refridgerator with top freezer. Water leaks and pools at bottom of refridgerator under crisper. How do I fix the leak?
Here is a Utube video that will do the trick. Might not be your model, but same gig.
https://www.youtube.com/watch?v=VHD556AQ894
Dec 22, 2014 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a whirlpool refrigerator Model GI5SVAXVL01. (2 door upper- Freezer on bottom). SN K01668079 About once a week there is a puddle of water on the floor right front side of refrig. I cannot tell where...
After looking carefully at the exploded views of this refridgerator
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Refrigerator-Parts/Model-GI5SVAXVL01/1198/0161000?pathTaken=&prst=0&shdMod=GI5SVAXVL01
I believe your problem is caused by a leaking hose or fitting for the water dispenser
Pay close attention to items # 11 and 19 on the diagram labeled Refridgerator door parts
Try turning off the water supply to the dispenser and see if the problem is resoleved... if so you know thats where the problem is
Jan 21, 2011 | Whirlpool Refrigerators
I have top freezer refridgerator. where the fan is in the freezer is frozen behind the plastic. Could this be what is cause the bottom of the refridgerator not to be col because there is no air coming...
Yes , you are correct . If ice is NOT blocking the fan motor , replace the motor and all will be ok . Take your model number ( very important ) with you , so you get the correct motor . Easily replaceable with only 3 wires ( 1 ground , 2 power ) . Doesn't matter which terminal on the 2 power wires ( ac voltage ) as long as on the 2 larger terminals .
Sep 22, 2010 | Whirlpool Refrigerators
Whirlpool refridgerator-model#ETICHMXKOO4-We have
There is ice buildup in the drain and maybe under the seperator. Remove the back panel in the freezer and the botom floor of the freezer and remove the ice. Be careful of the styrofoam ducts. Eric
Aug 10, 2009 | Whirlpool Refrigerators
Refridgerator won't cool, freezer is OK
if it is a bottom freezer and top refrigerator it is low gas in the system need to be topped up
May 12, 2009 | Samsung Refrigerators
Whirlpool Model ET14JKYGW02, Serial # VSJ1300145. Freezer stopped working after 2 months, Refridgerator is working.
Is the freezer froze up? It suppose to auto defrost but the defrost timer might be bad.
Mar 16, 2009 | Refrigerators
Water drains from freezer compartment into refridgerator
Jan 09, 2009 | Refrigerators
Broken retainer bar on freezer of whirlpool eht-181zk refrigerator
Hello aerobatkat
Welcome to Fixya
You said, Broken retainer bar on freezer of whirlpool eht-181zk refrigerator
Are you looking for parts???????????????
Try one of our sponsors for parts.
Repair Clinicwww.RepairClinic.com
Please remember to leave a rating.
Oct 03, 2008 | Whirlpool Refrigerators
Model EHT-201ZH
Check to see if the condenser is clean. Also that the compresser is getting enough clean air.
Apr 24, 2008 | Whirlpool ART535 Top Freezer Refrigerator
Whirlpool Freezer doesn't freeze?
insulated or not, garages are generally too cold for new energy efficient frigs to operate. ambient temp needs to be above 60 to work efficiently.
Mar 07, 2008 | Refrigerators
Refrigerators Logo
226 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
