Question about Whirlpool LER4634J Electric Dryer
My Whirlpool electric dryer heats but do not roll
My Whirlpool electric dryer heats, and fan works fine but do not roll. Is it motor or belt broken? how do I open it to check inside?
    Problem Solver:
  • 9 Answers
Sounds like the belt is broken
Posted on May 02, 2010
Whirlpool Duet WED9150WW dryer heats up but does not spin. The belt is not broken and door switch appears to be working.
If the dryer is on and everything is working except the drum is not turning, then the motor is bad. Here is the new motor to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 10, 2012 | Whirlpool Duet WED9150WW 6.7 Cu. Ft....
My whirlpool duet electric dryer electrical systems and heat work fine, but drum won't turn and belt is in tact.
Check the motor capacitor,sometimes the capacitor could be faulty or the motor is faulty or check if the motor is receiving power,if it's receiving power try to replace the capacitor if the is any in the system,if still it's not working then the motor could be burnt.
Also check weather the timer is perfecty.
Sep 29, 2012 | Whirlpool Duet High Efficiency Electric...
Dryer will heat but wont turn
your drive belt may have come off or broken if the drum is not turning,could also be the motor, but if you can hear the usual sound of the motor then its no doubt working.
you really would need to take the panels off to have a look inside, you will see right away if the belt has come off or broken
Jan 02, 2010 | Whirlpool LER4634J Electric Dryer
WHIRLPOOL ELECTRIC DRYER.MODEL # LEQ9508PW1. DRYER IS NOT SPINNING. MOTOR IS HEATING AND RUNNING FINE. I OPENED TOP AND BELT IS ON BUT LOOSE. BELT IS NOT BROKEN JUST LOOSE. WHAT COULD THIS BE?
You will have to go farther and remove the drum.
I believe your problem is that the belt has slipped off of the motor, or has slipped off the idler arm with pulley brackett.
Good Luck,
I hope this helps
Oct 31, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Electric Dryer, model LER7648KQ1. The
Check your previous post. I left additional info for you.
Sep 11, 2009 | Dryers
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Dryer heats but wont tumble/electric
Broken belt due to bad rollers or idler or simply rotten belt. GUIDE
Jun 30, 2009 | Kenmore 63942 Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Whirlpool Dryer Motor Removal
stand that baby up!!! acess is from front, try removeig 2 screws from under lint filter and then pop top with screw driver lean top back.. youll see the tub and belt(if not broken right there),no belt??? order a 341241 whirlpool dryer belt. 2 5/16screws on either side of iside facade remoivefront caver, disconnect door switch and remove front panel. belt slips over drum , you need to reset tension pulley and wrap around motor shaft. .
Feb 26, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
94 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
