Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
I have a whirlpool dishwasher that won't start even though there is power going to it. I was told by someone at Lowes ro shut the breakers off for 15 minutes and that would no doubt fix the problem. it did not change a thing ,can you help? the model number is DU1145XTPBA the machine was purchased in 2007.
    Genius:
  • 1,036 Answers
Check there is no water in the tray under the machine.
There will be a switch that turns off everything if there is a possible leak - so may be that. Just blot up any water and try again.
If there is a slight leak - trace it.
Posted on May 02, 2010
My Samsung Dishwasher, model DMR78AH5 will not run. The heavy, delicate, quick and smart lights are permanently on. I cut off the breaker for one minute but that did nothing.
How to Fix a Dishwasher That Won't Start ' Dishwasher Repair
www.partselect.com/Repair/Dishwasher/Will-Not-Start/
If your dishwasher won't start the problem could be the door latch or door latch ... On manual timer models the timer is used to supply power to the pump motor, ...Missing: samsung ‎dmr78ah5
Samsung Dishwasher Won't Start - Model DMR57LFS ...
www.repairclinic.com/...Dishwasher/...-/Samsung-Dishwasher-won-t-start...
The door latch ensures that the dishwasher door latches shut. If the door does notlatch properly, the door switch might prevent the dishwasher from running.
What to Do When the Dishwasher Won't Start - YouTube
? 5:43
https://www.youtube.com/watch?v=L-bMqVb9kX0
Aug 15, 2013 - Uploaded by doityourselfstan
The problem could simply be a blown thermal fuse inside the control panel. ... Maytag Dishwasher Repair ...
Dec 16, 2015 | Samsung Dishwashers
Washing machine wont start
Try unplugging the machine for 15 seconds. After it is plugged back it open and close the door several times. I know this sounds weird but it resets the safety circuit that sometimes shut these machines down. There may be some other safety reset sequences specific to the machine (you can search these on the net) if the one I told you doesn't work. Please rate my answer so I get points for it.
Jan 20, 2012 | Whirlpool Washing Machines
Is there a fuse on the Whirlpool 24 in. DU910PFG Built-in dishwasher? ... it just stopped working!
Good evening, There is no fuse that would shut down everything.Check for switch under sink or your home circuit breaker.Then it could be your door switch which shuts every thing down .It may be stuck open.Sometimes a door slam will get it going but still needs replacement.$40 part though.Switch is located behind console and can be checked with ohm meter.Sears Parts Direct shows blow up of your machine.
If it was your circuit breaker and it blows again ,you have a short and you'll need tech. to troubleshoot or maybe there is another load on that circuit (like toaster etc)
hope this helped
Aug 16, 2011 | Whirlpool 24 in. DU910PFG Built-in...
No power to dishwasher; checked breakers they seem
you need to check the power only:
1- check the power come to the wall right ,if not
get elecricity man to bring it to plug in the wall
2- check the cord of m/c if it has fuse check it
and replace with same values ampers,....so on
3- if problem still check electricity reach at end of cord if not ,chang cord
4- if you still have problem inform us
>be ware of electricale chock it is your your life> thanks from me m abba
Jul 10, 2009 | Whirlpool Dishwashers
Whirlpool Gold 1500 XTL dishwasher
Try shutting off all power to the DW by going to your house's main fuse or circuit breaker box, and shut off the breaker or fuse that services the DW. Wait 30 seconds, restore power, and see if the CANCEL LIGHT clears. If not, you may have a probkrm only a repairman can solve.
Jul 20, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Quiet Wash Plus Dishwasher is not despensing the detergent properly. After a wash cycle there is still some left.
My Whirlpool Quiet Wash plus dishwasher seems to have died. No power. None of the buttons work, it quiet mid-cycle. No breaker issue, my garbage disposal runs off same breaker and is working fine. Any ideas? I was thinking the comp. board that the buttons work off of is fried. If this is the case any idea how much to replace it? Would it be cheaper to buy a new dishwasher?
Apr 21, 2008 | Dishwashers
Whirlpool Quiet Partner II
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 26, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Jan 09, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
282 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
