My M&S Systems model MC350A central intercom and radio system in my home is malfunctioning. The LED displays the word "LIST". The word "list" is not mentioned once in the Owner's Manual. I turned off the power to the unit overnight in an effort to reset the system, to no avail. What else can I do?
  • 3 more comments
  • mwalton459 May 02, 2010
    When I pressed the up, 2, and Display buttons simultaneously, releasing the display button first, the LED displays a 5. By the way, I disconnected all of the speaker wires before this process. I turned off the circuit breaker for 30 seconds to reset and the LED display now shos LIST again. Any other ideas?
  • mwalton459 May 04, 2010
    When I press the time/Auto button after following the prescribed procedure, nothing happens. Any other ideas?
    Still nothing.
  • mwalton459 May 05, 2010
    My M&S Systems MC350A control unit has "LIST" showing on the LCD display. I have disconnected all speakers from the unit and depressed UP, 2, & Display as the owners manual says. Now it has "5" showing on the LCD display. I have tried turning off power overnight with the same results. Any other ideas?
  • mwalton459 May 06, 2010
    The secret to getting my system to work again was to disconnect the BLACK speaker wires. I had disconnected the GREEN speaker wiresfrom the individual posts. Once the bad BLACK speaker wire was identified (and disconnected)the system works fine. I suspect the "DOOR/TALK" module is bad because I get "LIST" in the LCD display when depressed. That's OK because we never use that feature anyway. Thanks again for your help.
    President:
  • 563 Answers
Hello mwalton459.
There could be two problems with the word display 'List'. First, it can be one of the speakers that is causing this problem. So,you have to disconnect the bundle of black wires at the back of the master. Make sure sure that you've disconnect the separate patio black (if you have one).
If that solves the 'List' problem, I would suggest you to hook them up one at a time until you find the bad speaker.
Second, it can be that you have a bad talk/listen switch on the master which could cause the problem or you could have them both.
Hope it helps.
Posted on May 05, 2010
    President:
  • 1,554 Answers
Press and hold UP, 2, and DISPLAY buttons simultaneously then release the DISPLAY button first. The display will show "TEST" or "000o" then turn the circuit breaker off where the MC350A is connected for 15 seconds to properly reset it and the display will blink 12:00.
Posted on May 02, 2010
  • 2 more comments
  • Jahn27
    Jahn27 May 03, 2010
    Repeat the pressing of the given buttons then when the 5 is displayed press the TIME/AUTO SET button then try adjust the if possible. Press TIME/AUTO SET button again when the proper time is set. Do not unplug it after that.
  • Jahn27
    Jahn27 May 04, 2010
    A button or switch may have shorted in the master unit; slide the switches back and forth to remove any possible short circuit and repeatedly press each button then observe any possible stuck button and unstuck it. Make sure also to disconnect every speaker connected.
  • Jahn27
    Jahn27 May 04, 2010
    Grab a volt-ohmmeter, set it to the R X 1 scale, and check the resistance between the terminals where the speakers are connected to. There should be no short circuit (zero resistance) between the speaker output terminals. Have it serviced by a qualified technician if all else fails; electronic components may have failed internally.
  • Jahn27
    Jahn27 May 06, 2010
    The reason why I suggested resistance check of all the speaker is to eliminate a possible short circuit that cause the trouble. I
2 Suggested Answers
SOURCE: M&S Systems, #MC350A, central intercom system, malfunctioning
I'm having the same problem. I think LIST means it is in LISTen mode, listening to the outside door station. Why it is doing that is unclear.
Posted on Jun 05, 2010
Reset M&S mc350a?
In this case, it is best to disconnect all room stations from the system. This can help determine if a room station is causing the issue or if it is a bad master unit. Once the room stations are disconnected, go back and try to set the clock, turn on radio, etc. If the problem is still happening, it is a defective master. If the problem has stopped, try adding back wiring while continuing to test the system.
Here is a link if you need a replacement product or you have more questions.
Intercom Systems
Don't forget to visit and like our Facebook page
https://www.facebook.com/QualityHomeSystems
Aug 18, 2015 | Radio Communications
M&s intercom model 200 manual
Here is a link for the manual.
NuTone NM200 4 Room Intercom Kit NM200 4 Room Intercom Kit
Please visit our website if you need a replacement part or if you have more questions.
Central Vacuum Intercom and Whole House Audio Systems
Don't forget to like and visit our Facebook page
https://www.facebook.com/QualityHomeSystems/?ref=hl
Aug 16, 2014 | Radio Communications
Standby led but cant on power
Look like malfunction AMP PCB Board.Please open top cover, unplug flex cable attached to connector AMP PCB. Try now power- ON the unit.
Jul 24, 2014 | Panasonic Home Theater System System
Light fault
Go into the UPS display or the Software and list the fault. Display Menu -> Fualts & Diagnositics -> Faults
Please list the fault in order to help :)
Daniel • daniel@psihq.com • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Aug 19, 2013 | APC Smart-UPS VT 20kVA (SUVT20KF3B4S) UPS...
Novi doorbell intercom system won't work. Got it about 8 years ago, worked OK except for minor problems until recently. Now it malfunctions constantly. We finally had to disconnect the wiring o
If you are looking for new intercom system then I would suggest you to buy it from http://www.hulksecurity.com/ .Hulk Security System not only provides intercom systems but they also offer variety of access control system, CCTV and alarm systems. Well, I hope this would help you and have sorted the concern for intercom system.
Oct 24, 2012 | Novi Wireless Doorbell Intercom Security...
Hi, im looking for a original price for Evesham Navigation model: 7211, or where can i find the price list.Thanks
Don't make the assumption that GPS navigation systems are all expensive - the Evesham Nav-Cam 7700 device is one of the cheapest ones available, retailing for $160 with a $5 shipping fee. The specifications (available after the jump) might not amount to much, but if you're looking for a basic GPS system without the frills of MP3 and video playback, the Nav-Cam 7700 offers value for money in theory. After all, you already have your iPod for all your multimedia needs, so why purchase a device with redundant functions?
• Processor: Centrality Atlas II 300MHz
• Memory: 256MB Flash ROM, 64MB SDRAM
• Expandable Memory: SD/MMC up to 2GB
• Display: 3.5" 65k color TFT LCD with LED backlight
• Audio: Integrated speaker/Headphone socket
• Base Maps: USA & Canada maps
• Receiver: Centrality GPS Receiver
• Battery Type: Internal Rechargeable Lithium Ion 1320mAh
• Battery Life: 3 Hours Navigation
• Dimensions: 3.7" x 2.9" x 0.8"
• Weight: 5.5 oz.
Jun 24, 2011 | Evesham Nav-Cam 7700 GPS Receiver
M & S Systems MC350A - intercom dial if rotated will squeal
no, but I have exactly the same issue - did the original poster get a solution?
Jan 18, 2010 | Audio Players & Recorders
M&S DMC1 System- When I turn the power on it music does not play on the main station but does on the door stations. It only gives a humming sound.
Well it's not mainly the radio problem the problem occurs due to bad signals, anyway you can try a bigger antenna.
please check the below link for more information.......
http://webhome.idirect.com/~griffith/tdoa.htm
Good Luck!!
Thanks
Dec 24, 2009 | M&S Systems M & S SYSTEMS DMC1CDB Whole...
Oct 18, 2009 | Audio Players & Recorders
How do i use the intercom on my Uniden dect. 6.0?
March 25, 2013 - INTERCOM INSTRUCTIONS
Here is the answer! Press the INTERCOM button one time.
The INTERCOM display will show on the screen.
Use the UP or DOWN arrow button to select the HANDSET number.
Press the MENU/SELECT button to ring the HANDSET selected.
Press the END button when done talking
Sep 01, 2009 | Uniden DECT 6.0 Cordless Telephone...
1,759 people viewed this question
 Grubhead
Grubhead
