Question about DEI Valet Keyless Entry System
Bought truck with Valet alarm, where can i get a 474t manual
Small clear box bundled under dash with zip ties to wiring. Do they all have remote start?
4 Suggested Answers
  • 63 Answers
SOURCE: We just realized that the previous owners of our
Any valet switch will work. Then simply program your remote. As long as you have a DEI remote there should be no problem unless you are trying to program a two way remote (pager) to a one way system (non pager)
Posted on Jan 10, 2011
doin12volt
  • 233 Answers
SOURCE: car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
Posted on Dec 19, 2008
  • 4 Answers
SOURCE: i needto know whwt wires go where???
Ok I know I have been bouncing around. My truch wants to start. I have had it in at leist 3 modes.
1. Valet. And didn't start.
2. Out of Valet.
3. Armed
4. Disarmed
still would not start. I can rule out the 95%. EGR, good, Fuel pump,New Fuel filter. New. Relay New. Fuse for cig lighter. New. All fuse at alarm Good .
Posted on Oct 31, 2011
How do I disconnect alarm from2002Chrysler sebring
if its stock alarm, owners manual should have directions for "valet" mode. If its aftermarket, try to find the "box" under the dash (look for bundle of wires) and get manufacturers name and model number. internet should have instructions for "valet" mode.
May 29, 2016 | 2002 Chrysler Sebring
Where the **** is the Viper valet button?
Consider how the switch will be used before choosing a mounting location. Check for rear clearance before drilling a 9/32-inch hole and mounting the switch.The GRAY wire in the two-pin plug may also be used as a (+) ghost switch input and can be connected to any (+) switch in the vehicle. (See Feature Descriptions section of this guide.)
This is from the installation manual for the Viper 300. To answer your question, it is probably camoflaged. They only needed to tie +12vdc to the input line. What does this mean? Well, my best guess is, they are using one of your switches on your dash to act as the Valet function. Look for where the Gray wire, from the wiring harness of the Viper goes to: that WILL BE your hidden Valet switch. Best of luck!
Viper 300 ESP Installation Manual Plug in Harnesses Super Bright Led Valet...
Feb 15, 2016 | Remote Start System
Wiring diagram 06 impala
Read the alarm installation manual carefully and keep the support number handy if you have any questions as every alarm manufacturer uses different connection and mounting techniques. Open the hood and disconnect the positive battery cable. Connect the alarm power wire to the positive battery cable and run it to the driver side of the firewall.
Locate an open area in the engine bay and mount the siren, facing the engine to limit water exposure while driving. Run the siren wires to the driver side's of the firewall and feed all of the wires through the firewall and into the dash area of the Impala. Drill a small hole in the firewall if necessary, directly in front of the steering wheel.
Remove the lower dash panel if necessary and mount the shock sensor per the manufacturer's instructions. Locate the power lock relay if the car is so equipped and connect the alarm's power lock module.
Find the starter wire in the ignition harness and attach the start disable relay. Drill a small hole in the dash for the LED light and snap it into place.
Connect all of the wires to the alarm control module by plugging them into the module and secure it as far into the dash as possible with zip ties.
Reconnect the positive battery and test the alarm on the Impala. Adjust the sensitivity level as desired and secure any loose wires with zip ties.
Original Mercedes Benz NEC PRO57 Support Online Update
Aug 14, 2014 | Cars & Trucks
I need to deactivate the alarm on my 52 scenic
the only alarm that "sounds" when installing a new battery is an aftermarket alarm and the only way to resolve it will be if you have the remotes for the vehicle
search under the dash for a little black box
it should look like is was installed with zip ties
simply unplug it and your good to go
May 12, 2010 | Cars & Trucks
I needto know whwt wires go where???
2. Out of Valet.
3. Armed
4. Disarmed
Oct 07, 2009 | 742T Car Alarm - Keyless 2-4but Rem 4ch...
Hi ... My hyundai sata fe has a Prestige Keyless Remote ... and I bought the used car about 10 days ago... Just now when I treid to start my car it dose't start ...adn the alarm goes of randomly and my car...
What you need to find is the valet button which i believe is the blue blinking LED that should be in the dash and it blinks when you arm the system. So try this.. disarm the system and get into the car like normal than put the key into the ignition turn the key to "run" and press and hold the blue LED button till it turns solid. You are now in Valet mode which means the alarm is OFF. Now try starting the car and see if it starts all the time. If it doesn't start and the little blue light is on solid than we have other problems. Because with the alarm in Valet mode the starter disable feature is turned off. However if it does start all the time and gives no problem you might have a loose ground that has to be tightened up or other wiring issues. Now for the alarm going off at random times, you have whats called a "shock sensor" that is adjustable. What this boxs job in life is is to wait for any "impact" like a breaking window or something hitting the car. Notice i didn't say motion. The shock sensor is adjustable and this could be the random going off problem. The shock sensor would be a little box zip tied to a wire loom under the steering column. let me know... mark
Aug 15, 2009 | APS20B Prestige Keyless Remote Alarm
Valet Switch/Button
Contact a dealer for the location of switch
May 02, 2017 | 2002 Mitsubishi Galant
Disarm car alarm
Simply disconnect the power leads to the alarm...........sodeep
May 11, 2009 | Vehicle Parts & Accessories
Need to turn the valet switch off On 1999 Nissan Maxima
Look for alarm Brain box and look for wires coming out black and red going to valet switch. to turn valet on turn ignition in ON position and press-switch or flip depending on the type of switch. If it a basic alarm just disconnect the main wiring harness to alarm box- unplug and the car should start. Good luck and thanks for using FIX YA
Jan 26, 2009 | 1994 Nissan Maxima
Security alarm
usualy there is fuesed main wire connected to battery positive. undo it. or follow boot swich wire to alarm unite box and un plug it.
Jan 17, 2009 | 1992 Toyota Camry V6
DEI Valet Keyless Entry System Logo
707 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
