Question about Canon D320 imageCLASS Digital Copier
Line in paper lengthwise right of center
I had a paper jamb and removed toner on right side of copier to access jamb. I removed paper and also found a wire clip approx. 4" long with a loop and catch. I do not know where it came from. The copier functions but has a line as described above. Thanks for your help.
  • 26 Answers
You need to re place the drum.
Posted on May 05, 2010
C5180 jam in carriage - removed paper but not printing
Check at the cartridge end of the machine. I found a piece of paper jambed in that kept the carrige from parking on the right side. I had to turn off printer. take the paper trqy out and turn the machine on it's right side and use a flashlight to find it and get it out.
Dec 31, 2014 | HP PhotoSmart Office Equipment & Supplies
Paper will not feed, goes in crooked. gets caught on right side
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.
Try cleaning the rollers with methylated spirits
Jul 07, 2011 | Dell 725 InkJet Printer
I have a ricoh fw830 copier with a paper jamb symbol error, where are the sensors to clean?
Open all possible covers and trays from all sides and try to find some tiny bit of paper with your eyes and hands (it could be well hidden). First of all these places:
1) Paper tray/cassette, especially place where the paper gets pulled inside the system. 2) Under the toner cartridge. 3) Duplexer 4) Try to figure out the complete way which paper moves from the paper tray till it comes out.
If every paper seems to be removed, just try to turn off the power, then turn it on again.
Unfortunately there is no manual available digitally as the printer is quite old.
Mar 05, 2011 | Ricoh FW 780 Black and White Copier
JAM E, UNNABLE TO CLEAR ERROR
Jam E normally cause by the paper path sensor came off during when you clear a paper jam.. the sensor is located at middle side , to fix it back you will need to remove the E cover..and remove the transport unit...4 screws.. but putting it back will need to have some technical know how as fitting it back wrongly will cause you unit not able to feed paper due to the plastic blocking the paper path.
Will upload some instruction later...
Apr 14, 2010 | Epson Aculaser C1100 Printer
Error: open upper cover exit jam
Feed Jam or Exit Jam ecblank.gif ecblank.gif dot.gif ecblank.gif 1. Remove the tray and clear any misfed sheets as given above.
2. Open the top cover.
WARNING! The fuser area will be hot. This area is clearly marked. Do not touch it.
CAUTION! Never expose the image drum unit to light for more than 5 minutes. Never expose the image drum unit to direct sunlight. Always hold the image drum unit by the ends or from the top. Never touch the surface of the green drum inside the image drum unit.
3. Carefully lift out the image drum, complete with the toner cartridge. Be careful not to touch or scratch the green drum surface.
4. Remove any jammed sheets from the paper path.
5. Re-install the image drum complete with toner cartridge, ensuring that it correctly locates into the slots on each side of the printer.
6. Close the top cover and press down to latch it closed.
7. The printer will warm up and commence printing when ready. he page lost through the jam will normally be reprinted.
NOTE If the edge of the jammed paper protrudes (or can be seen) from the exit, reinstall the image drum, close the top cover and switch the printer on. Remove the jammed paper from the exit when the exit roller begins rotating after a few seconds after switching on. However, if the jammed paper cannot be removed, contact a service representative.
Mar 12, 2010 | OKI B4350 Laser Printer
E020 IN CANON 6050
This an error for out of toner. Make sure there is toner in the hopper. Do this by pushing down the hooked shaped clips on top of the hopper and at the same time move the slide to the right. Using a flashlight look into the hopper see if there is toner. There was also a mod kit for cleaning the toner sensor that should have been done. Return the slide back to normal position. Add toner if needed. If there is toner you will have to remove the developer unit , access from the bypass door. Unscrew the top of the developer unit, look to make sure that there is toner inside. Return to proper position when through. You will also have to reset the error after toner checks ( service mode ). Do this by inserting a straightend paper clip into hole located below control panel on left side. You should see a $ on control panel. Press * 4 *. Look for " ERROR ". Use arrows on screen to move through the different screens. Touch screen on error to highlight. Press OK. Turn off and back on main power switch ( lower right side ). To refill developer unit if needed is to go into service mode and *4* and look for INSTALL. Look for TONER-S. highlight and press OK. Copier will run and time down until developer is filled correctly. Reset key serveral times and copier should be OK. Run several 20 copy sets to test that toner will hold.
Dec 14, 2009 | Canon NP 6050 Copier
Smoke emanates after printing a few copies please help
Not a good sign. Is it a paper smoke smell or an electrical smell. If it is an electrical smell then the printer is faulty. I suggest you get a new printer.
If it is a burnt paper smell then it most likely a paper jamb at the fuser unit. Remove the toner cartridge to get access to the fuser and remove the paper (let the printer cool down first because the fuser unit is very hot).
Nov 26, 2009 | HP LaserJet 1010 Printer
Paper feed not straight, causing jambing
You need to look inside the slot where the paper is loaded with a flashlight and small mirror. Usually the only reason that happens is when something has fallen in where the paper goes. I usually find pins, paper clips, candy wrappers, or jewelry dropped inside. A paper clip straightened out can help remove the objects.
Oct 02, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printer starts to grab paper then paper jambs.
Hi, Follow these steps:- 1.Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred. 2.Turn off the printer. 3.Remove any paper trays. Inspect them for wrinkled or damaged paper. 4.Open any other doors that give access to the printer's paper path and to the toner or ink cartridge. 5.If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it. 6.If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly.The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. 7.If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. 8.Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. 9.If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Thanks! mannu_rakesh
Sep 09, 2009 | Brother HL-2170W Laser Printer
Paper light says on.. wont reset after jam is cleared
We have a few of the HL-2070N's and I have seen this issue on a few of them. Usually it indicates one of several instances that can be found on Brothers website in the FAQ's about what does the LED indicate area.
The main solution I have found is that depending on where the paper jammed it has affected the drum/toner cartridge assembly somehow or another.
  • I recommend taking the Toner Cartridge out of the drum unit
  • clean the corona wire by moving the blue tab at the front of the drum unit back and forth several times
  • I have even used can air here to get it even better all around the drum unit not just at the corona wire area
  • After make sure all is clean put all back together
This has cleared up most all of my paper jam LED issues and allowed for further printing.
Mar 28, 2008 | Brother HL-2040 Laser Printer
49 people viewed this question
old marine
old marine
