Question about Amana 24 in. ADW862EAS Dishwasher
Glasses are cloudy, appears the shine on china is being
Eaten away, also black cooking utensils are white and cloudy
  • 901 Answers
Check and fill the rinse aid compartment.
Posted on May 03, 2010
We have a dishwasher that has cleaned great for six or seven years but all of a sudden we have started seeing a white film on all of our black plastic utensils, like spoons and the such. Now some is on...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Feb 13, 2011 | Jenn-Air JDB3610 Built-in Dishwasher
Recently the dishes have a grainy feel and the glasses have white smears on them. Some of my kitchen cooking utensils which are made of a black material are all coming out coated in a white file
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Feb 13, 2011 | Dishwashers
There is a white film on the inside of the door plus glasses and utensils.This problem just started a few weeks ago.(the dishwasher is just about two years old). We use cascade and jet dry rinse agent,
Feb 09, 2011 | KitchenAid KUDS03FTBL Dishwasher
Hi the problem we are seeing is the glasses are covered with a film of what looks like soap residue dried up and cooked on. it takes alot of scrubing to get some off. i have new jet dry in and use...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
Dec 23, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
Is our dishwasher no good? We have hard H20 and practically rinse clean our dishes, untensils & glasses before we load it. We never use it for pots & pans. There's a sort of soap scum on the...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
Nov 28, 2010 | Maytag Dishwasher
Doesn't clean properly, Leaves dry residue in washer
My dishwasher had the same problem. glasses were cloudy, inside the dishwasher was coated with a film, drawers were hard to pull out. tried rinse agents and vinegar and nothing worked. Found lemi-shine at WalMart (it's next to the dishwasher detergent) and the white stuff is gone! no more residue and glasses sparkle again. I was ready to buy a new dishwasher I was so frustrated. get some - it's amazing! a couple bucks and it's back to normal. I was SOOOO happy!
May 21, 2010 | Siemens 24 in. SL84A305UC Built-in...
Cloudy Glasses
The problem is hard water and jet dry will not solve that. There is a new product out called The Dishwasher Filtration System. It filters the water going into your dishwasher leaving your dishes spot free with every load. It is very affordable and fits right under the sink. You will be amazed how sparkling your dishes look just after one load. You will love this product. Get it at www.dishwasherfilter.com.
Jun 01, 2009 | Dishwashers
Hazy cloudy glasses and utensils
Use dishwasher salt as required to keep the glasses clean.
Jul 23, 2017 | Dishwashers
I got a layer of white cloudy film on my dishes after normal wash
Doing a full vinegar cleaning of the diswhasher is a good start, and every 6 months or so if you have hard water.
But, I have proven that using ultra-cheap dishwasher powder will cause this problem too. Recommend after you do the cleaining with white vinegar through a quick cycle with no detergent, you use only a brand name powder (like Cascade or Electrosol) and see if problems persist.
If problems remain, the heating element has probably failed. Once it is replaced, you will see a dramatic improvement. Good Luck!
Mar 29, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Open Questions:
Amana 24 in. ADW862EAS Dishwasher Logo
131 people viewed this question
Top Amana Dishwashers Experts
Cleverer2
Mike
Kolbrun...
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
