Question about Neff U1721 Double circotherm Electric Oven
Oven no heat
Integrated oven, grill works fine, fan is working fine but no heat generated in oven mode. actual model is B1320
oven went "pop"then no heat, is this element ?
  • 1 more comment
  • Anonymous May 11, 2008
    the product name is Nardi the oven dont heat up but the grill still works.
  • Tarzantony May 22, 2008
    I have replaced my Neff Fan Oven element a couple of times with no problem, this time however it wont work. The element supplier said that it is unlikely to be the new element but the thermal overload connector. where is this, can it be reset, do I need a new one?
    Cheers
    Tarzantony
  • sparky208 Jul 07, 2008
    hi can you help please i have a neff u1420n0gb the top grill and oven work ok but the botton dosent the clock keeps flashing not even the bottom oven light comes on can you give me a few pointers pleas kind sir
    President:
  • 1,462 Answers
For king louie
fault is the circular element round the fan. take off the back plate inside the oven and you can often see the damage but not always. to get at the terminals, remove the rear cover and test for continuity across the element with a multimeter - remove any connections before doing this and note down where they go
for tarzantony.
i can't remember where the cutout is but probably on top of the oven or close to the fan on bthe back. just trace the wiring from the element and it should lead you to it
Posted on Jul 06, 2008
I have a parmco ar900leg gas stove with a multi function oven power. Its been cooking a treat for the last six months when we bought it. was installed by a gasfitter and correctly. Now, the bottom...
u say element not working? so its a gas and electric? If so check the element with a multi meter for continuity. I would say check ur gas safety valve also but u say it does work in grill?
Mar 08, 2015 | Ovens
Top oven temp display shows 4444
Control panel needs to be replaced. It may also be an error code for the repairman.
Jul 22, 2012 | Neff U1661 Double circotherm super...
My cooker won't heat up
remove the rear panel covering the fan (4 screws) from inside oven. The element is round the fan. you may see where the element has burnt through or split or distorted the element.
Jul 23, 2010 | Electrolux Ovens
Have had 4 Neff oven elements in 2 years, why does this keep happening ? B14241 single oven element keeps blowing, grill and light are fine, any ideas please ? is it time for a new oven ?
If you are not fitting genuine
elements, this is probably the reason they are failing so quickly.
You will pay a lot more for the genuine article, but they will last a lot longer.
Also make sure the fan is working o/k, as this can cause premature element failure.
please rate my solution.
Thanks.
Feb 07, 2010 | Neff B1421 Electric Single Oven
Oven not working - rest of appliance fine
It is most likely that the oven heating element has failed and will need to be replaced.
This not an overly expensive part to have replaced and should be much less than the cost of buying a new oven although you would need to compare actual costs in your area.
Jan 17, 2010 | Ovens
NEFF B1320 OVEN DOES NOT HEAT UP. POWER ON FAN WORKING
For all Free appliance repair videos visit our VIDEOTUTORIALS neff video
1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Dec 25, 2009 | Neff B1641 Single circotherm super...
Not heating in fan forced mode
Possibly your fan element has blown. Try and take the cover off that coves the fan inside the oven itself and use a torch to look at the element to see if it looks out of shape etc.
Jun 15, 2009 | Fisher and Paykel OS302SS, Stainless Steel...
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Smeg oven
How long is the oven in operation before you check the air flow ? Most Smeg ovens are electronically integrated and sensitive.
Jan 24, 2008 | Ovens
Oven no heat
check fan element hasnt blown remove back plate in oven after switching off from mains of course and remove the retaining screws and you will see a fan and around that the element it will be obvious to see if its blown as there will be a hole on the casing if so replace and viola.
Jan 16, 2008 | Neff B1641 Single circotherm super...
Neff U1721 Double circotherm Electric Oven Logo
253 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
