Question about Champion International Champion& Small Engine Spark Plug 8 Pack
I have a 1994 club car golf cart its real sluggish when you start it it spits and sputters for a while you can feather the gas pedel and sonner or later it will take off and run fine i have changed the spark plug and fuel filter and the gas what else might it be
I have club car golf cart. I get to start,later it won't start,looks like no gas is coming in to carb
if is is fuel problem check the fuel filter and or carb needs to be repaired or replaced possible debris or float valve sticking
Sep 13, 2016 | Golf
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Jan 24, 2016 | Golf
Find the year serial nimber A9649-548612 club car golf cart was manufactured
Since 1981 Club Car Golf Carts have positioned their serial numbers just under the glove box on the passengers side of the vehicle. The first two numbers (not letters) indicate the last two digits of the year of manufacture.
On Club Car Golf Carts prior to 1981, you can find the serial number by raising the seat and locating the aluminum, I-beam frame section closest to the batteries on the driver's side of the car. If the serial number plate has been removed, you can confirm it is a 1975-1980 model if it has two brake pedals and one accelerator pedal.
Oct 20, 2014 | Golf
Club car golf cart running slow
Check fluid levels and individual voltages.
Nov 24, 2013 | Golf
48v club car 2004.speed issue
the module on the end of the motor should do the trick.
Nov 06, 2013 | Dual Pro 48V 18Ah Club Car Golf Cart...
Club electric golf carts
Resister coil pack....Look up Buggies Gone Wild. Tons of info.
Sep 08, 2013 | Golf
Club car brake light not working
2008 precedenmt golf cart dash light keep coming off an on
Mar 02, 2013 | Power Equipment Solutions 2002 Club Car DS...
Golf Cart (Gas Powered) Stereo Installation
What I did was to buy a good blue tooth speaker and connect to my cell phone. 3 hrs on the golf course and 10% of the cell battery
Jul 06, 2017 | Cars & Trucks
Champion International Champion& Small Engine Spark Plug 8 Pack  Logo
431 people viewed this question
Top Champion International Garden Experts
JohnPaul Robertson
chuck ringwood
chuck ringwood
Dennis Key
Dennis Key
Are you a Champion International Garden Expert? Answer questions, earn points and help others
