Question about Jandy Stealth 2 HP UR Pool Pump SHPM2.0 SHPM20
Jandy/Stealth Pool Pump motot
We have a Jandy Stealth pool 1.0 hp pump motor (Stealth/Jandy model#jhp1.0 serial #D03FC1186...it runs great when the basket area on it is full of water so u can not see air thru plastic cover......but for some reason ...which i hope you can help me with its not doing that there seems to be air in the basket area and its not working? HELP!! Basket has been cleaned, filters cleaned, new gasket in filter cover for filters. Where to check for a air leak im guessing I have!
    Guru:
  • 351 Answers
Hi .. If ypou are gtetting air in the basket, then ytou have a leak somewhere in the system. start by closing off the skimmer, bottom, cleaner one at a time and see when the air stops gettingt in. Is there enough water level to cover the skimmer? have you checked the seal on the strainer at the pump? you might be able top hear hissing if it is at the pump.
Posted on May 04, 2010
Pump will not turn on
check to see if voltage to pump motor if you have voltage bad motor or capacitors if no voltage check switch or relay
Aug 16, 2013 | Jandy Stealth 1.5 HP UR Pool Pump SHPM1.5...
Is there a reset button for a jandy stealth 1.5HP pool pump
it kicks out breaker try turning the motor shaft if still doesnt work need new motor
Jun 27, 2012 | Jandy Stealth 1.5 HP UR Pool Pump SHPM1.5...
I have a Jandy stealth series pump and this morning it was not running. The breaker was tripped and when I reset it and turned it on the motor only hums for a few seconds and then the breaker trips...
This sounds like the motor has seized up. You will most likely need to replace at least the motor and maybe the complete pump assembly.
You can take the pump into a local motor shop and see if they can rebuild the motor for you.
US Parts Center
Aug 21, 2011 | Jandy Stealth 2 HP UR Pool Pump SHPM2.0...
Pump has power at back of motor and I can turn shaft at the back of pump. It is not running.
this motor has a run capacitor, have it tested. search your area for your local pool pump motor repair guy with free testing.. ask him how to remove it, caps can hold a charge and make for a nasty surprise.. THIS IS IF THE MOTOR HUMS OR MAKES A BUZZ NOISE if not, you will need to check the power at THE BACK OF THE MOTOR. no power check, timer, breaker, main breaker ..
Jun 06, 2011 | Jandy Stealth 1.5 HP UR Pool Pump SHPM1.5...
Jandy mhp pump wiring connect
Hi, The connections for the pool pump motor should be described on the motor name plate, inside the cover of the wiring cubby, or on the wiring base near the terminals. Questions?
Jun 19, 2010 | Jandy Stealth 1 HP UR Pool Pump SHPM1.0...
My jandy stealth pool pump stopped working. it just hums when turned on. The model # is JHP1.0.
ONE OF THE CAPACITOR MAY BE BAD CHANGE THEM BEFORE MOTOR REPLACEMENT .CHECK IMPELLER FOR ANY DEBRIES BLOCKING
Sep 23, 2009 | Jandy Stealth Pump 1 HP 115/230v
Jandy Stealth 2 HP UR Pool Pump SHPM2.0 SHPM20 Logo
334 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
