Question about GE JES738 Microwave Oven
Microwave panel display works but fan and
Have JES738 Microwave. Panel display works but when I press the start button nothing happens. Only the time starts to count down. Help please.
  • GE Master
  • 9,047 Answers
See this file.
We're happy to help and appreciate your thoughtful rating.
Posted on May 02, 2010
My sensor touch buttons don't work....any ideas why?
With Power on Microwave There is Light Blinking It Means Is Normal Power Supply Supply Problem,Not Reaching Front Panel Power Supply
Feb 07, 2014 | LG LMV2015ST Microwave Oven
The problem is that when I press the 'Start' button, nothing happens. The clock is working, the fan is working, but I cannot cook anything even after I have entered the time and the power level
If when you press the start button the turntable starts but no heat then magnetron is faulty otherwise if nothing happens then the touchpad itself is faulty.
Oct 10, 2013 | Samsung 1.8 Cu. Ft. Over-the-Range...
On my GE Profile Microwave the led is lighted and shows the time correctly and displays the led buttons. When I press on the led buttons nothing seems to happen. Also, after some idle time, the led panel...
The touch panel has malfunctioned, Suggest replacing microwave unless you want to attempt repair. If so you will need a replacement touch panel for it.
Jun 14, 2017 | GE Microwave Ovens
I have a 2 year old ge micrwave. I shut the breaker off to change a furnace filter and now the microwave is not working and just says to "press clock". When I press the clock button, nothing...
If you press clock and nothing happens your keypad has shorted out and needs to be replaced. Try to unplug the unit one more time and try to turn the unit on again. If you have the same problem replace the control panel.
Dec 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Vent fan has stopped working. the keypad says vent fan off. when pressing help, it says press this pad. nothing happens.
A low tech solution worked for me.
I too was getting the "Vent Fan Off" message, and despite the fact that everything else worked fine with the microwave, I turned the breaker off and back on from my electrical panel. The fan works fine now.
Oct 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven push buttons not working no sound not functioning
You have a failing membrane keypad.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
It is part number WB07X10950 and you can get it here for $89.59 (compared to over $135 from from GE!).
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Oct 07, 2009 | GE JES738 Microwave Oven
Viking microwave has digital lights but will not turn on to cook?
Hi the problem will be with the touch panel membrane or the controller. if yoiu can hear a click when the start button is pressed then the touch panel is OK asnd you should look at the controller which can be replaced as a unit or if you are up to it it's probably the main cook relay that has failed.
Jan 29, 2009 | Viking DMOC205SS Microwave Oven
Complete functioning control panel but nothing works.
This is a problem with the control panel assembly, which we repair nationwide for $32.50 postpaid. Sometimes the bulbs short when they fail, and that damages the control board. This also can happen when bulbs are removed or installed without first unlugging the oven or turning off the breaker. For critical safety & disassembly info and other details of our service, see http://tinyurl.com/yzjozk
Jan 16, 2007 | Whirlpool MH1140XM Microwave Oven
GE JES738 Microwave Oven Logo
95 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
