It could be,, moisture is caused when a dryer can't vent properly,, so clean out all the vent lines from the machine, and include the outside vent cover
It needs a new Humidistat Moisture Sensor. That is the part that senses how much moisture is in the garments and decides when to go to cool down cycle. That part is not used in Timed Dry.
If your
dryer seems to run forever, it could be because of a clogged vent or
internal ductwork. Your dryer may have an automatic cycle that turns
off the dryer when the clothes are dry. It does this with a special
thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When
the dryer reaches the pre-set temperature, the thermostat tells the
timer to begin advancing. (If there's a moisture sensor, the timer
advances only if the moisture content of the clothing is low enough.)
The
timer advances until the interior cools, then the thermostat tells the
timer to stop advancing, and tells the dryer to start heating again.
This
cycle continues until the clothes are dry. But…if the vent is clogged,
the dryer may never reach the proper operating temperature, so it
doesn't send the signal to the timer and the dryer continues to run
indefinitely, even if the clothes are completely dry. To fix the
problem, clean the vent and/or internal ductwork.
A timed drying cycle uses the timer alone to stop the drying cycle. Once it times out like an egg timer a set of contacts open up shutting off the dryer. Or a set of contacts closes to activate a relay which in turn shuts off the power.
Auto dry usually uses a moisture sensor which would do the same thing as the timer. Once it doesnt sense moisture in the load for a predetermined time it in turn triggers a relay which shuts the power off. Some auto dry cycles just use the timer alone and guess-timate the drying time by the selection.
If yours does not use a moisture sensor then most likely it is your timer/cycle switch. There may or may not be a relay involved.
Most dryers have a basic wiring diagram on the inside somewhere on one of the panels which will help.
Since yours is acting up on both cycles Im guessing you have a bad relay or connection to that relay somewhere IF it uses a moisture sensor.
Clogged Vent If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork. Heating Element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat. Please take time to rate me Bud
Hello there: A lot of the times the problem lies with in the Cycling thermostatthat is going out Although
temperature in your dryer may break and cause the dryer to heat poorly.and can make the dryer stop working after it is working for a given amount of time
If so, you need to replace it. Next is the The thermostat is usually a small, round,
the internal ductwork with two screws.It overheats and shuts down due to a bad thermostateUsually
when an electric dryer overheats it's because of a defective cycling
thermostat or a clogged vent system. Clean any lint from the internal
and external ductwork, and/or replace the cycling thermostat (read about
cycling thermostats in "Drying is too slow," above).It seems to run foreverIf
thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle:The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When
advances only if the moisture content of the clothing is low enough.)The
Normally if you have an automatic cycle that turns off the dryer when the clothes
are dry, it will do it with a special thermostat or moisture-sensing
system. The thermostat tells the dryer to heat until the interior of the dryer reaches a "pre-set" temperature. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. If there is a moisture sensor, the timer advances only if the moisture content of the clothing is low enough. The timer advances until the interior cools, then the termostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But... if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix this problem, clean the vent and/or internal ductwork and make sure the vent is not compressed or kinked. If that doesn't work, then your thermostat, moisture sensor or timer could be the culprit. .
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
The dryer requires cycling of the heat to advance thhe timer on auto dry cycle. see ,link provided parts and repair guidance. Always remove from power supply first.
This is caused by the dryer vent being blocked and not allowing the moist air to be removed from the dryer. To confirm this. Dry a load of close in a timed dry setting. Set the time on a specific time and then start the dryer. Wait for about 5 min. See if the timer has moved. If it has then the problem is not the timer. It is the exhaust vent being plugged up somewhere. Moisture how the auto dry setting works. The dryer sences moisture and runs longer to dry your clothes. With the dryer exhaust vent blocked, wet moist air is comming back into the dryer and fooling the sensor into believing the close are not dry and runs for a very long time. It is not uncommon for this problem to cause a dryer to never shut off. Your dryer exhaust vent is plugged up with lint somewhere.
On auto dry cycles, the cycle is controlled by moisture sensing bars located on either the rear or front bulkhead, ( visible inside dryer ) if the moisture sensor bars are shorted together (normally by wet clothing) the dryer will continue to run. If the dryer continues to run when the clothes are plenty dry, check and see if there is anything stuck between the sensor bars, (sometimes a metal sequin will cause this) or see if they are damaged. If not, you may have a problem with a timer contact, if the timer advances and stops moving at the same spot each time, I would suspect the timer. If this is an EvenHeat dryer, examine the control board located to the right of the timer in the control panel, for any burned components. Hope this helps.
