Sound on my Lg 20ls70 keeps blipping on and off
What is fatal error 762
Trying to test this plugin on XAMPP localhost test site. Nothing shows up so I looked for errors and found this: Warning: require_once(C:\Data\xampplite\htdocs\zinnia\wp\wp-content\plugins\blip-slideshow): failed to open stream: Permission denied in C:\Data\xampplite\htdocs\zinnia\wp\wp-content\plugins\blip-slideshow\blip.php on line 762 Fatal error: require_once(): Failed opening required 'C:\Data\xampplite\htdocs\zinnia\wp\wp-content\plugins\blip-slideshow' (include_path='.;C:\Program Files (x86)\xampplite\php\PEAR') in C:\Data\xampplite\htdocs\zinnia\wp\wp-content\plugins\blip-slideshow\blip.php on line 762 --------------- The code on line 762 is the require_once, but here's a few lines before // attempt to talk to WordPress $blog_header_path = preg_replace("/wp-content\/.*/", "wp-blog-header.php", getcwd()); if (file_exists($blog_header_path)) { require_once($blog_header_path); }
Feb 12, 2015 | Office Equipment & Supplies
BIKE CUTS OUT, BLIP THE THROTTLE AND ENGINE STOPS
sounds like fuel problem ! what bike have you got and is it carb or injectors , is it elec fuel pump or gravity fed and how old is the fuel in the tank ?
Mar 17, 2014 | Triumph 955i Speed triple Motorcycles
Cant enter download/recovery mode vm720
it work with prior version of windows not with all
Jan 25, 2014 | LG Cell Phones
Blips from Smoke Detector
When was the last time the battery was replaced in the smoke detector ?
Try replacing smoke detector battery with a new alkaline battery.
and see if bleep goes away.
Also if it is cold , the near flat battery will reach the level that the smoke detector will beep at intervals to warn you that the battery is almost flat .
May 24, 2017 | Cars & Trucks
LG Headset can pair with PC and I can hear but the mic is not working
I have this sale problem. I am using a rocketfish micro dongle to connect my LG tone to my PC and I can hear fine. However, when I set the bluetooth mic to default, I only hear these random blips and pings and it shows nothing received in the audio bar.
Feb 04, 2013 | LG hbs-730 Tone Stereo Bluetooth Headset
Susuki baleno 4cyl 1.6l blowing smoke
It sounds like a piston oil ring is broken considering the valve stem guides and seals have been done, oil is definately getting into the combustion chamber there are only two places that can happen through the valves or through the rings, black smoke is always too much gas, blue smoke is always to much oil in combustion chamber. Hope this helps even though it's not the best news.
Jul 22, 2009 | 1996 Suzuki Esteem
LMVM1935SB - Over the Range LG - fan keeps coming on, beeping
The fan will come on if you are cooking below and the area gets hot.... is this when it happens? Sometimes random beep could be a power blip... not long enough for a reset of all things electrical
Apr 19, 2009 | LG LMVM1935 Convection/Microwave Oven
91 kx 250 stock carb setup.
Low speed screw 1.5 turns out from bottomed. Middle position for clip #3 position.
I never rely on the factory settings for the low speed screww, set it to factory and keep adjusting it 1/8 turn at a time until idle sounds best and quick throttle blips dont sound "stumbly" the later being the most important.
The needle position is for low altitude.
Jan 24, 2009 | kawasaki KX 250 Motorcycles
Blu-ray problems from blu-ray computer drive.
Vista takes significantly more procesing power from your CPU than XP did. The colored squares, or pixellation, are a result of your computer's processor having a bit of trouble keeping up with the demands of the Blu Ray video. To resolve this, you can do several things: Upgrade your CPU(You can upgrade the the highest CPU your current motherboard will allow) Upgrade your RAM, (RAM is fairly cheap for the bang you get and will be the cheapest upgrade option.) Max it out if you can. Reinstall XP back on your computer. (Cheapest option, period). This time, use Ghost or some other imaging program to image your Hard Drive once you get it working correctly so that you can recover in minutes as opposed to reformat-reinstall next time.
Jul 10, 2008 | Computers & Internet
Televison & Video Logo
178 people viewed this question
Top Televison & Video Experts
